Minimum work needed to climb to the top of a peak
  • Thread starter Thread starter derpydashie6167
    Minimum Peak Work
The discussion focuses on calculating the minimum work required for a 71.5-kg hiker to ascend from an elevation of 1300 m to 2680 m. The relevant equations include the work-energy theorem, where work (w) is defined as w = (Fcos[theta])d, and potential energy (PE) is calculated using PE = mgh. The key insight is that the angle θ in the work equation is not 90 degrees, as it represents the angle between the force applied and the displacement, which is crucial for accurate calculations. The minimum work is achieved when the climber's kinetic energy remains constant during the ascent.
  • Understanding of the work-energy theorem
  • Familiarity with gravitational potential energy calculations
  • Knowledge of vector components in physics
  • Basic algebra for manipulating equations
  • Study the work-energy theorem in detail
  • Learn about gravitational potential energy and its applications
  • Explore vector analysis in physics, focusing on angles between forces
  • Practice solving problems involving work done against gravity
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in climbing scenarios.
derpydashie6167
A 71.5-kg hiker starts at an elevation of 1300 m and climbs to the top of a peak 2680 m high. What is the minimum work required of the hiker?
w=(Fcos[theta])d
F=ma
PE=mgh
f=ma=71.5*9.8 = 700.7 I know this is not right because he is also going up against gravity but I don't know what else to use for acceleration. I don't know the angle but I assume it is a 90 degree cliff.
w = (Fcos90)1380 = 0. But zero is not the correct answer.
The angle of the cliff does not matter. The angle theta is also not the angle of the cliff, it is the angle between the force applied and the path taken, and is thus definitely not 90 degrees. The work done is then the path integral of the inner product between the force applied and the displacement. However, in this particular case you don't need to know any of those. Think about how work and energy are related.
derpydashie6167 said:
Homework Statement:: A 71.5-kg hiker starts at an elevation of 1300 m and climbs to the top of a peak 2680 m high. What is the minimum work required of the hiker?
Relevant Equations:: w=(Fcos[theta])d
F=ma
PE=mgh
In my opinion this is a poorly stated problem, but I understand what its author wants you to do. You need to find the minimum work done by the climber against gravity. Presumably that is minimum when the climber's kinetic energy does not change as (s)he climbs. Does that help? Think work-energy theorem.
Also, you seem to have a serious misconception about work. If the cliff is vertical, that means a 90o angle with respect to the horizontal. Angle θ in the expression for work is the angle between the force and the displacement vectors. Do you see why that angle is not 90o?
