Mirrors, Polaroid Films, Light/Wavelength help needed
  • Thread starter Thread starter riseofphoenix
    Mirrors Polaroid
19 replies · 3K views
riseofphoenix
:(:(:( Please ease my aching soul by helping me with this...
I submitted this assignment online and I don't know the answers yet or however many I got wrong.
I chose 45 because I know unpolarized light becomes this after going through a polarizer:
That single line is 180º, so I did 0.25 x 180º = 45º.
Is E the right answer?
I chose E…but after seeing this diagram below just now, I think I got the answer wrong and that it's supposed to be B… Is E not the answer?
I chose D…but I don't think it's right…
I did this:
Given:
R = 10 cm
f = -R/2 (since it's convex) = -10/2 = -5
do = ?
M = +4 x (image is upright)
di = -? (image is virtual)
M = -di/do
4 = -di/do
di = -4do
1/f = 1/do + 1/di
1/(-5) = 1/do + 1/(-4do)
-0.2 = 1/do - 1/4do
-0.2 = (4/4)1/do - (1/1)1/4do
-0.2 = (4 - 1)/4do
-0.2 = 3/4do
4do = 3/(-0.2)
4do = -0.6
do = -0.6/4
do = -0.15
Is the answer C? (I chose D originally and I can't change my answer….but now that I've worked it out step by step i think the answer is C)
It is not, and there is no reason to multiply 180° by anything. Using the same argument, 90° would let 50% pass through, which is obviously wrong.
You can analyze this with polarization vectors and projetions on the polarization axis, or with existing formulas (Wikipedia, book, ...).
I did this:
Your result is very small (0.15 cm), there has to be some error in the calculation. I found one here:
4do = 3/(-0.2)
4do = -0.6
So basically all three of them are wrong?
Also, what about question number 3?
Take a spoon and test it.
The graph below is not a concave mirror.
Ok but my answer is still wrong though...
The answer for 3 would have to be D.
Think about which side of the concave surface the image lies in.
If it lies on the left (the same side as where the object resides), it is real. If on the right, then the image is virtual. The focal equation is based on the reference of the surface of the mirror. Positive distance means real and negative distance means virtual.
mfb said:
Did you take the right ("inner") side of the spoon?
What do you mean?
mfb said:
I don't know what is unclear about that question.
Like this, but with an object closer to the mirror.
So the answer IS E.
real (image on front), enlarged, inverted.
riseofphoenix said:
So the answer IS E.
Not for an object lying inside of the focal point.
Why don't you try drawing out a a simple ray diagram?
I did not find an image of an object closer to the focal point. The inversion is not there in your problem.
I forgot how to because I did this back in high school and my teacher (in college) just gave us a simple chart to follow and didn't emphasize the fact that we had to draw a ray diagram. :(
The answer has to be B then...
Ok well since I know I got those top 3 questions wrong...I wouldn't mind moving on to the other questions I wouldn't mind you guys checking for me...
I did this:
Given:
R = 10 cm
do = ?
____________________________
M = -di/do
4 = -di/do
di = -4do
1/f = 1/do + 1/di
-0.2 = 1/do - 1/4do
-0.2 = (4 - 1)/4do
-0.2 = 3/4do
4do = 3/(-0.2)
4do = -0.6
do = -0.6/4
do = -0.15
I did this:
Given:
R = 10 cm
do = ?
M = -di/do
4 = -di/do
di = -4do
1/f = 1/do + 1/di
-0.2 = 1/do - 1/4do
-0.2 = (4 - 1)/4do
-0.2 = 3/4do
4do = 3/(-0.2)
4do = -0.6
do = -0.6/4
do = -0.15
Your magnification is wrong. It's 4x smaller, which means ##\frac{d_i}{d_o}## should be less than one since ##\frac{h_i}{h_o}## is reduced.
Oh goodness...
So what should M equal?
riseofphoenix said:
Oh goodness...
Well, it's 4x smaller so what do you think?
I'm sure you can figure this out. Other than that there seems to be nothing else wrong with your calculations.
Well, there is a calculation error in the first post, I mentioned it in post 2:
4d0 = 3/(-0.2)
4d0 = -0.6
