Missile with Coriolis force, air resistance and variable gravity
  • Thread starter Thread starter aldom
The discussion revolves around modeling the motion of a missile considering factors such as Coriolis force, air resistance, and variable gravity. The participants are exploring the dynamics involved in the missile's trajectory, particularly focusing on the equations of motion and the implications of different forces acting on the missile.
  • Participants discuss the appropriate coordinate system for modeling the missile's motion, questioning the direction of gravity and the representation of forces. There is an exploration of simplifying assumptions, such as turning off drag to analyze the effects of gravitational and Coriolis forces independently. Additionally, there are inquiries about the correct formulation of altitude-dependent density and the choice of drag coefficient.
The discussion is active, with participants providing insights and suggestions regarding the modeling approach. Some have proposed specific coordinate systems and simplifications, while others have raised questions that indicate a deeper exploration of the problem's assumptions and parameters. There is no explicit consensus, but several productive lines of reasoning are being developed.
Participants are working under the constraints of a homework assignment, which may limit the scope of their analysis. There is an emphasis on understanding the physical implications of the equations rather than deriving a complete solution.
aldom
Make a model the motion of a missile in a case when it's high enough that gravity has to be taken as variable, Earth rotation effects are significant, and there's drag
I am modeling the missile as cylindrical for simplicity.
I understand that the equation modeling this should be
$$m\frac{d\mathbf{v}}{dt}=-\frac{GMm}{(R_E+z)^2}\hat{k}-\frac{1}{8}\rho_0e^{-\frac{z}{H_1}}\pi D^2C_d(\mathrm{Re})|\mathbf{v}_R|\mathbf{v}_R+2m\mathbf{v}\times\mathbf{\omega}+m\mathbf{\omega}\times(\mathbf{r}\times \mathbf{\omega}),$$
where:
$$\mathbf{v}$$ is the time derivative of the position vector with origin at the Earth's center, $$\rho_0 = 1.2\ \mathrm{kg/m^3}$$, $$H_1 = 8.4 \ \mathrm{km}$$, $$\mathbf{v}_R=\mathbf{v}-\mathbf{\omega} \times \mathbf{r}$$ and $$|\mathbf{\omega}|=7.3\times10^{-5} \ \mathrm{s^{-1}}$$.
I'm confused about what should the ##x##, ##y## and ##z## components of this equation be. I'm also confused about what ##C_d(\mathrm{Re})## should I use in this case.
Why is gravity in the ##\mathbf{\hat k}## direction? Don't forget that the Earth is approximated as a perfect sphere and "up" is the direction away from the Earth's center, i.e. the radial direction ##\mathbf{\hat r}.##
I would put the ##z-##axis along the axis of rotation and write ##\boldsymbol {\omega}=\omega~\mathbf{\hat z}##. I would label as ##xz## the plane defined by vectors ##\boldsymbol {\omega}## and the position vector ##\mathbf r = r \sin\theta ~\mathbf {\hat x}+ r \cos\theta ~\mathbf {\hat z}## where ##\theta## is the angle between the angular velocity and the position vector. Of course, I would also rewrite the force of gravity as a radial vector ##\mathbf F_g= F_g(r)~\mathbf{\hat r}.##
If I were solving this problem, I would "turn off" the drag (##C_d=0##) just to see how far I can go with the mathematical handling of the radially-dependent gravitational force and the Coriolis force by themselves. I have not attempted to solve this problem, but I suspect that getting an analytical solution without approximations, even in the absence of drag, is not easy.
I have finally figured out. I was looking at this article; they are dealing with the same problem just without the drag. I then saw that the way to go was to use the same coordinate they are using: taking gravity to go along the radial direction and setting the ##z## axis to be direction of Earth's rotation, so that ##\vec{\omega}=\omega\hat{k}##. As for the drag, from this article I was convinced that I could take ##C_d## to be constant in within a certain set of values for the Mach number, so I decided to do so for to make computations easier. I also figured out why I should use the ordinary velocity in the drag term instead of ##\mathbf{v}_R##. With all of this, the components of the equations are
$$m\ddot{x}=-\frac{GMm}{|\mathbf{r}|^3}x-\frac{1}{2}\rho_0e^{-\frac{r-R_{\text{Earth}}}{H_1}}C_dA|\dot{\mathbf{r}}|\dot{x}+2m\omega\dot{y}+m\omega^2x$$
$$m\ddot{y}=-\frac{GMm}{|\mathbf{r}|^3}y-\frac{1}{2}\rho_0e^{-\frac{r-R_{\text{Earth}}}{H_1}}C_dA|\dot{\mathbf{r}}|\dot{y}-2m\omega\dot{x}+m\omega^2y$$
$$m\ddot{z}=-\frac{GMm}{|\mathbf{r}|^3}z-\frac{1}{2}\rho_0e^{-\frac{r-R_{\text{Earth}}}{H_1}}C_dA|\dot{\mathbf{r}}|\dot{z}$$
A couple of questions and a comment.
1. Why is the altitude-dependent density ##\rho_0e^{-\frac{z}{H_1}}## instead of ##\rho_0e^{-\frac{r}{H_1}}~?##
2. Now what? Are you going to find the trajectory using machine code or are you going to try solving this analytically? If by code, how are you going to test that it gives the right result?
For in-line LaTeX rendering, enclose your expression in double hash marks (#) not single dollar signs ($).
Example: ##z## not $z$ to get ##z##.
  • · Replies 0 ·
  • · Replies 21 ·
