I Missing proof of the Shell theorem in General Relativity
The discussion centers on the validity of the shell theorem in the context of General Relativity (GR) and its relationship to the Schwarzschild solution. It is clarified that while the second part of the shell theorem holds in GR, the first part, which pertains to the gravitational effect of a point mass, is not meaningful within GR. The derivation of the Schwarzschild solution does not involve replacing a spherically symmetric object with a point mass, as this would lead to circular reasoning. Additionally, the Schwarzschild solution is valid outside an object only if its radius exceeds the Schwarzschild radius, and the singularity at the center is not a point mass but rather a spacelike singularity. Overall, the conversation emphasizes the distinction between Newtonian gravity and GR, particularly regarding the treatment of mass and spacetime geometry.
Bosko
TL;DR
Is there a proof for the shell theorem used in Swartzchild's solution?
In the classical Newtonian theory of gravity, the shell theorem holds. ( https://en.wikipedia.org/wiki/Shell_theorem )
Isaac Newton proved the shell theorem and stated that:
  1. A spherically symmetric body affects external objects gravitationally as though all of its mass were concentrated at a point at its center.
In the beginning of the derivation of the Schwarzschild solution, the spherically symmetric object is replaced by a point mass.
The proof that this can be done in curved space-time is missing.
If the proof of this statement were to use the Schwarzschild solution directly or indirectly, it would not be logically valid. It would be so called "circular reasoning".
Is there a proof of the shell theorem for GR independent of the Schwarzschild solution?
No, it isn't. That's not how the Schwarzschild solution is derived.
  • Skeptical
Likes bhobba and Bosko
The second part of the shell theorem holds in GR, in the form that the sptacetime geometry of a vacuum region inside a spherically symmetric matter distribution is flat.
The first part isn't even meaningful in GR: there is no meaningful GR solution that I'm aware of for the spacetime geometry surrounding a point mass. Nor is that what the Schwarzschild solution describes (or how it's derived, as I noted in my previous post).
Likes bhobba and PeroK
How then?
Is there a point mass?
Bosko said:
How then?
Where did you get that it is? What are your sources?
Bosko said:
How then?
Where have you looked to find out? Most GR textbooks discuss how the Schwarzschild solution is derived.
In the Schwarzschild solution? No.
The first part can be derived from the second part .
E.g. The array of shells with the same mass and with 1/n radius . By subtracting results of the consecutive elements of the array you can get equivalence with the point mass.
Of course it is not the physical object any more but the mathematical model of the spherically symmetric mass.
Any.
Some are explicit with the point mass as the represent of the spherically symmetric object
and other are using the equivalent form in one of the steps in derivation.
It might be better to ask an equivalent question:
Let two spherically symmetric objects of the same mass of radius ##r_1 \lt r_2## be given.
Is the spacetime for ##r \gt r_2## the same in both cases?
So a larger sphere can be replaced by a smaller ... etc ... arbitrarily smaller ... the point mass.
Edit:
Is there a proof of this claim for GR independent of the Schwarzschild solution?
Perhaps it can in Newtonian physics. That doesn't mean it can in GR.
Not in GR, you don't. Long before you get to that point, you will have a configuration that violates Buchdah's Theorem and therefore is not stable.
As I've already said, there is no consistent mathematical model of a point mass with a gravitational field in GR. GR is not Newtonian physics.
Not in GR, it can't. See my comment about Buchdahl's Theorem, above.
Moderator's note: Thread moved to the relativity forum as the topic is well within standard GR.
Bosko said:
Any.
Sorry, but this isn't a responsive answer. You need to cite a specific chapter/section/page in a specific textbook or peer-reviewed paper that gives such a derivation. If you can't do that, this thread will be closed as there is no valid basis for discussion.
Bosko said:
Any.
Ok then it would be easy to provide one. For example, I have about 10 GR texts, spanning publication dates from 1921 to 2015. All derive the Schwarzschild solution and none mention a mass point - because it is impossible. The interior of the horizon of the Schwarzschild solution contains(ends with) an axial singularity, not a mass point.
Likes dextercioby and PeroK
PAllen said:
The interior of the horizon of the Schwarzschild horizon is best described as an axial singularity, not a mass point
And note that the singularity (the locus ##r = 0## in the Schwarzschild geometry) is spacelike, not timelike, so it's "axial" only in the sense that it's a one-dimensional line, not in the sense that it's a line sitting in space and existing for some length of time.
Edit:
Up to the stability issue raised by @PeterDonis (Buchdahl's theorem), there are many sources that prove this, even in, e.g. the case of a radially vibrating spherically symmetric mass. That is, outside the outer bound of vibration, the solution is uniquely determined to be Schwarzschild with some mass parameter. One example is chapter 7 of J. L. Synge's book "Relativity: The General Theory".
More generally, search for "Birkhoff's Theorem", and several rigorous presentations in arxiv may be found.
Likes PeroK and PeterDonis
Never intended to imply that. Adjusted the wording slightly, hopefully for the better ...
Bosko said:
TL;DR Summary: Is there a proof for the shell theorem used in Swartzchild's solution?
No it isn’t. The usual derivation starts by assuming spherical symmetry and a vacuum solution and then proceeds to solve the EFEs under those assumptions.
There is no parameter of a spherically symmetric object in the solution. For example, the radius .
The solution does not depend on the size of the object.
Let's find some detailed explanation of the formula and see when the radius of the object vanishes .
Is this from Wikipedia good for analysis?
https://en.wikipedia.org/wiki/Derivation_of_the_Schwarzschild_solution
I'm looking for a detailed derivation available on the internet.
Can we agree that the solution does not depend on the radius of a spherically symmetric object?
I think that this is some form of the shell theorem.
The Schwarzschild solution is valid outside an object, as long as the radius of the object is greater than its Schwarzschild radius. For a fixed mass M, therefore, there is a minimum radius for which the solution is valid. If the mass is contained within the Schwarzschild radius, then you have an unstable collapsing scenario.
The full vacuum solution has a characteristic mass, but that mass itself is not part of the spacetime. Instead, you have a singularity, which is not a point in space.
In any case, in GR you cannot consider a gravitating body as a point mass - although you may consider test particles as point masses.
First you claimed that it is used at the beginning of the derivation, then you say it follows from the solution. These are two different claims.
As others said: That a solution doesn't depend on a parameter, doesn't necessarily imply that it is valid for any value of that parameter.
In other words, for any ##r_1## and ##r_2## the solution is the same outside of ##max(r_1,r_2)##.
Am I right, even if one of ##r_1## or ##r_2## is smaller than ##r_s## (Schwarzchild radius)
That's exactly what I thought.
Edit: That is valid
Thanks. I put the topic in "Beyond the Standard Models" so as not to violate the forum rules in case someone offers non-standard thinking.
If ##r_1 < r_s##, then you don't have a Schwarzschild solution. Note that for ##r < r_2##, the ##r## is a time-like parameter. It's not a spatial radius (or anything like it). Note that for ##r > r_s##, ##r## is technically not a Euclidean radius, but an areal radius.
PeroK said:
What are ##r_1## and ##r_2##?
Two objects of the same mass but different radii.
Bosko said:
Two objects with the same mass but different radii
Sorry, I didn't read the earlier post. See my updated reply. ##r_1 < r_s## is not valid as the radius of an object.
Do you think that for ##r_1 < r_s## the mathematical model does not correctly represent physical reality?
For ##r < r_s##, the coordinate ##r## is timelike. Just because you use ##r## as a coordinate doesn't mean it's a radius. The Schwarzschild coordinates have a coordinate singularity at ##r = r_s##.
The region of spacetime represented by ##0 < r < r_1 < r_s## for any ##\phi, \theta## and fixed ##t## is not a spatial volume. It cannot be the volume of a massive object.
There was another student confused about this recently. See this thread:
This is not a good way to choose a subforum. "Non-standard thinking" in this context means personal speculation, which is off limits here. The issue we are discussing in this thread is standard GR and does not require going beyond that.
Likes Motore and bhobba
You clearly do not understand how the Schwarzschild solution is derived. I suggest reviewing the derivations in Wald or MTW. Both of those clearly state the assumption of spherical symmetry and what it implies mathematically.
You clearly do not understand what the Schwarzschild solution we are discussing represents. It represents a vacuum solution. For a spacetime containing a spherically symmetric mass, it represents the vacuum region outside the mass. The geometry of the vacuum region does not depend directly on the radius of the surface of the mass (it does depend on the mass itself), but that radius still has to be larger than the limit imposed by Buchdahl's Theorem, which is 9/8 of the Schwarzschild radius corresponding to the mass, i.e., outside the horizon.
No, it isn't. Nothing I said above has anything to do with the shell theorem.
  • · Replies 27 ·
  • · Replies 30 ·
