Mixing Tank, Differential Equations Problem
11 replies · 6K views · last reply
bdh2991
a larg tank is filled with 500 gals of water with 400lbs of salt. pure water is pumped into the tank at a rate of 3gal/min. the well mixed solution is pumped out at a rate of 7 gal/min.
I need help finding the Differential
I tried coming up with the D.E. and this is what i got dA/dt = 3 - 7A/(500-t)
except after i did solved the d.e. i kept getting more salt than i started with which makes no sense...
Please Help lol
Please Help lol
Your denominator is wrong. How is rate out defined?
not sure lol...i went off of a similar problem that was gaining instead of losing...
i know that it is supposed to be the flow rate out multiplied by the concentration out but i don't understand how to get the concentration of salt exiting the tank...
[tex]R_{out} = -t(7gal/min - 3gal/min) = -4t[/tex]
Where you have 500-t. I didn't check over the rest of you equation but that was what was immediate obvious.
ok so instead i should have A/(-4t) rather than A/(500-t)?
No, why would you disregard the amount of solution?
i guess I'm misunderstanding what you are saying...it would help more if you just showed me what the equation should look like
I could have phrased it better.
When you are dealing with mixtures, you denominators is
[tex]\frac{A}{sol+(R_{in}-R_{out})t}[/tex]
When inflow and out flow are the same, we just have A/sol in gallons.
Your R_{in}=3 and out=7 so (3-7)t = -4t.
So what is the denominator?
it can't be that because i just tried it and it didn't come out right
500+(-4t) = 500-4t
ok i made some dumb mistakes but i finally got what i needed thanks!
