Mobius Transformations-Complex Analysis
  • Thread starter Thread starter WannaBe22
    Analysis
The problem involves Mobius transformations in the context of complex analysis, specifically focusing on mapping an annulus defined by \{ z: r<|z|<1 \} to a region bounded by two discs. The original poster seeks to determine the value of r.
  • Exploratory, Assumption checking
  • Some participants question the definition of the annulus, noting potential errors in the bounds. Others suggest exploring properties of Mobius transformations and their effects on the unit disk.
The discussion is ongoing, with participants providing hints and questioning the initial setup. A suggestion has been made to find a specific value of α that would facilitate the mapping of the defined regions.
There is a noted correction regarding the definition of the annulus, indicating that the original poster may have provided incorrect bounds. The discussion also hints at the need for further clarification on the properties of Mobius transformations.
WannaBe22
Mobius Transformation copies the annulus \{ z: r&lt;|z|&lt;1 \} to the region bounded by the discs \{ z : |z-\frac{1}{4}| = \frac{1}{4} \} and
\{ z: |z|=1 \} .
Find r
Hope you guys will be able to help me!
Thanks a lot!
Got no idea...Hope you'll be able to help
There seems to be an error in the definition of the annulus, since the lower and upper bounds for z should be different.
You're right... I'm sry... I've corrected my typo
OK, here are some hints:
Do you know, or can you prove, that if z and \alpha are complex numbers such that \overline{\alpha}z \neq 1. then
\left | \frac{z - \alpha}{1 - \overline{\alpha}z} \right | &lt; 1,
if |z| < 1 and |\alpha| < 1, and
\left | \frac{z - \alpha}{1 - \overline{\alpha}z} \right | = 1,
if |z| = 1 or |\alpha| = 1.
From this, it follows that the transformation
T(z) = \frac{z - \alpha}{1 - \overline{\alpha}z}
maps the unit disk to the unit disk. Now find a value of \alpha such that T maps {z: |z| < r} to {z: |z - (1/4)| < 1/4}. That should do it.
Please post again if you have any other questions.
Petek
  • · Replies 17 ·
