vipers120
- Messages
- 2
- Reaction score
- 0
- TL;DR
- Numerical modeling of a system in which there is a mass rotating freely up to a certain point at which there is a preloaded spring.
I am trying to model numerically the following system:
A rigid body mass is rotating freely around an axis (no rotational stiffness/damping) within a range, let's assume plus-minus 3 degrees for now.
Case A. The external forces on the mass are low and keep changing which results in the situation the angle of the rotating mass is within the range.
Case B. When the external forces on the mass are increasing, we hit a kind of end-stop at 3 degrees. From this point onwards, there is a (rotational) spring which is preloaded relatively high, let's say we have 10 000Nm of pre-load. After this pre-load, the spring stiffness is very low which means there will be not so much more than 10 000Nm given back to the mass.
I'm having issues modeling Case B, especially the time of hitting, i.e. the impact.
My thinking is:
If the incoming velocity (and thus Kinetic Energy) is high enough, the energy is higher that is stored in the pre-loaded spring and thereby will start to deform.
If the incoming velocity (and thus Kinetic Energy) is low, the energy is lower then stored in the pre-loaded spring and thereby will not deform.
1. Is this thinking correct in the first place? I was also thinking trying to approach this problem in terms of moments, because the pre-load is in terms of moments. However, then I don't know how to obtain the moment related to the impact.
2. How to calculate the energy stored in a pre-loaded spring?
3. If the incoming velocity is low, how to approach the impact: how do I model the impact correctly?
I've been trying to look into this topic online and on this forum but did not find similar problems.
My thinking is:
