Modelling an Exponential Curve
ProPM
Hi guys,
I need to model a curve and I am trying to come up with an exponential equation. I have several points I can work with and this is what I tried so far. (I want to know if this is the correct method or if there is a more precise way to go about this)
I am working on something of the format: a*bt
My first point in the graph will be when t = 0, hence, I presume the best pick for my value of a would be my first y coordinate point in the graph: 554.8
My doubt arises from this point on:
When I have 554.8*bt should I set up a pair or simultaneous equations or can I say that b is equal to the "rate of growth of my graph"? That is, if my y coordinate points are 609, 657.5 my rate of growth would be (657.5/609)
Since my graph is not a perfect exponential fit I was thinking of adding a constant:
a*bct
But that's something different.
Thanks,
ProPM
I'd probably use y = aebt and use two points to determine a and b. A trick is to take the natural log of both sides so you end up with a linear equation. A more elaborate method (if the points have noise and don't fit a curve perfectly) would be a least squares approach, but that's much more involved (especially in the category of precalculus).
