Modelling Taxy Duration Distribution & Deriving Probability of Occurrence
The discussion focuses on modeling taxi duration distribution for airline flights, emphasizing the need to analyze variables such as flight number, aircraft type, and month of the year. The data does not conform to a simple normal or chi-squared distribution, necessitating a regression analysis to derive taxi duration probabilities. The recommended approach is to utilize Ordinary Least Squares regression, incorporating all relevant variables to maximize overall significance. This analysis aims to enhance aircraft fuel management by moving beyond simple average calculations.
  • Understanding of Ordinary Least Squares (OLS) regression
  • Familiarity with statistical significance and R-squared metrics
  • Knowledge of variable coding techniques for regression analysis
  • Experience with data analysis in a statistical software environment
  • Research "Ordinary Least Squares regression techniques" for practical applications
  • Explore "statistical significance in regression analysis" to understand variable impact
  • Learn about "data preprocessing for regression" including variable coding methods
  • Investigate "advanced regression techniques" for potential model refinement
Data analysts, statisticians, and airline operations managers seeking to optimize taxi duration predictions and improve fuel management strategies.
iambasil
Hiya,
I have been looking at a problem, and just can’t get my head round the right way to tackle it.
I have a whole heap of data for an airline showing the taxy duration of each of their flights (this is the time taken to go from the gate to actual lift off). As I see it, there are 3 variables that can affect this time:
1. Flight number (this takes account of both departure station and time of day)
2. Aircraft type
3. Month of year
Now, having had a look at the data, it does not follow a simple normal or chi-squared distribution – it actually varies. Some airports have two runways – one miles from the terminal and the other right next it – hence you get two clusters.
What I need to have as an output (monthly) is:
Flight number: (set by user)
Significance: (set by user) – probability that a taxi duration will fall within the output taxy time duration (below)
Taxy duration: (derived)
What I have is years worth of data. The data obviously changes year to year, so whilst I want the month of year variable considered, it must also be in relation to how the previous month compared to the previous month a year ago (or some other way eg deviation of month from annual mean?).
From a statistical perspective, how would I assess what type of distribution the data falls into, and how would I handle the sample to be used (sample size/the different variables)?
Would really appreciate your help.
The purpose of analysis is for improved aircraft fuel management – currently a simple average taxy time of the previous month (by flight number) is used.
Thanks,
Basil
What you want to do is to run a regression with taxiing duration on the left hand side and all other variables that may affect that duration on the right hand side. Since you don't really care about a "theory" that explains that relationship (am I correct that what you are really looking for is an empirical relationship?) I would start with "the kitchen sink" on the right hand side. That is, put in every conceivable variable on the right hand side and maximize the R-squared, and/or the total F statistic for overall significance; i.e., maximize "equation significance" as opposed to "individual variable significance" (measured by individual t-statistic values). And, you want to start with the Ordinary Least Squares regression technique -- you can always refine it (graduate to more complex techniques if needed) further down the road.
Thank you so much for the response.
Sorry for being naive on this, but I don't quite understand what you mean by 'on the right' - are there any examples on the web of something similar being done?
Basil
Check this out. In a simple (single x) regression equation y = a + b x + u, y is the dependent or explained variable "on the left," and x is the independent or explanatory variable "on the right."
"a" and "b" are model coefficients (parameters) to be estimated; "u" is the error term.
A multiple regression equation has multiple variables on the right: y = a + b1x1 + ... + bkxk + u.
For example, x1 may be departure station, x2 may be time of day, x3 may be type of equipment (somehow numericized, e.g. large = 1, small = 0 and then x4 might be coded jet = 1, prop = 0, etc.), x5 may be month of the year, and x6 might be "the number of pizza slices served in the airport pizzeria during the flight day." :smile:
  • · Replies 30 ·
