Modern Cosmology by Dodelson: Problem 6.12 a
The problem involves deriving identities related to the slow-roll parameters during inflation, specifically focusing on a relationship involving the derivative with respect to conformal time and the Hubble parameter.
  • Mixed
  • Participants explore the relationship between derivatives with respect to time and conformal time, questioning the implications of using different notations for differentiation. There are attempts to manipulate equations involving the scale factor and Hubble parameter to derive the desired identity.
Some participants have offered guidance on using the relationship between time derivatives and conformal time derivatives. There is ongoing exploration of the definitions and relationships between the variables involved, with some participants expressing confusion over the notation used in the text.
There is mention of potential inconsistencies in interpreting the notation used by the author, particularly regarding the differentiation symbols. Participants are also grappling with the implications of the definitions of the slow-roll parameters and their relationships to the scale factor.
travelingscienceman
The general goal of the problem is to derive some useful identities involving the slow-roll parameters during inflation.
For part a show that:
$$\frac {d} {d\eta} (\frac {1} {aH})= \epsilon - 1$$
$$\epsilon \equiv \frac {d} {dt} (\frac {1} {H})= \frac {-\dot H} {aH^2}$$
$$H=\frac {\dot a}{a}$$
$$\eta\approx\frac{-1}{aH}$$
First I put everything into the scale factor a and its derivatives:
$$-\dot H = \frac{\dot a^2 - \ddot a a}{a^2}$$
$$\frac{1}{a H^2}=\frac{a}{\dot a^2}$$
$$\frac {-\dot H} {aH^2} = \frac{\dot a^2 - \ddot a a}{a\dot a^2}=\frac{1}{a}-\frac{\ddot a}{\dot a^2}=\epsilon$$
Now this is where I am struggling.
He uses a derivative with respect to time and one with respect to conformal time (##\eta##). Coupled with the fact that
$$\frac {d} {d\eta} (\frac {1} {aH})=\frac {d} {d\eta} (-\eta) =-1=\epsilon - 1$$
Which means that ##\epsilon=0## which is not correct. Instead of substituting I could do the following:
$$\frac {d} {d\eta} (\frac {1} {aH})=\frac {d} {d\eta} (\frac {1} {\dot a})=\frac {-1} {\ddot a}=\epsilon - 1$$
Rearranging we get
$$\epsilon=1-\frac {1} {\ddot a}$$
And I am not sure this is correct either. I cannot see any way to make the RHS equal to epsilon.
Any help showing where I might have gone wrong would be appreciated and thanks in advance for taking a look at this!
Try using that ##\frac {d} {d\eta} = a \frac{d}{dt}##. So you've got ##a \frac{d}{dt} (\frac{1}{a} \frac{1}{H})##. It's pretty straightforward from there.
That helps but I am still having trouble. With ##\epsilon=\frac{-\dot H}{a H^2}## I just end up going in circles. But if I work with ##\epsilon=\frac{d}{dt}\frac{1}{H}## I get the following:
$$\epsilon=\frac{d}{dt}\frac{1}{H}=\frac{\dot a^2 - \ddot a a}{\dot a^2}$$
$$\frac{d}{d\eta}\frac{1}{\dot a}=a\frac{d}{dt}\frac{1}{\dot a}=\frac{-a}{\ddot a}=\epsilon-1$$
$$1+\frac{a}{\ddot a}=\epsilon=\frac{\dot a^2 - \ddot a a}{\dot a^2}$$
$$\dot a^2 \ddot a -a \dot a^2=\ddot a \dot a^2 - \ddot a^2 a$$
$$\dot a =\ddot a$$
Which is better but not right.
From looking inside Dodelson's text at Amazon, it appears that the author uses a dot to denote differentiation with respect to ##\eta##. But, it looks like you are sometimes interpreting the dot as differentiation with respect to ##t## (for example, when you write ##H =\large \frac{\dot a}{a}##).
Ah, that explains some inconsistencies. I assumed dot was differentiation by ##t## from that definition of ##H##.
Thank you both. Today with a clear head I figured it out.
$$H=\frac{\dot a}{a^2}$$
And so
$$\epsilon=\frac{2\dot a^2 -\ddot a a}{\dot a^2}$$
Which made things much easier.
