Moment of Inertia in slender rod - density varies
The discussion focuses on calculating the moment of inertia for a slender rod with a mass per unit length that varies according to the equation dm/dx = (gamma)x, where (gamma) is in kg/m². The total mass of the rod is determined to be M = 0.5(gamma)L². The moment of inertia is calculated for two different axes of rotation: one at x=0 and the other at the opposite end of the rod. The final moment of inertia for the axis at the opposite end is derived to be (1/6)ML² after integrating the appropriate expressions.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concept of moment of inertia in physics.
  • Knowledge of mass distribution and variable density in rigid bodies.
  • Basic principles of rotational dynamics.
  • Study the derivation of moment of inertia for various shapes and mass distributions.
  • Learn about the parallel axis theorem and its applications in rotational dynamics.
  • Explore advanced integration techniques for variable density problems in physics.
  • Investigate the implications of mass distribution on the stability of rotating bodies.
Students and professionals in physics, mechanical engineering, and applied mathematics, particularly those interested in dynamics and the analysis of rigid body motion.
ph123
A slender rod with length L has a mass per unit length that varies with distance from the left-hand end, where x=0, according to dm/dx = (gamma)x, where (gamma) has units of kg/m^2.
I calculated the total mass of the rod by integrating. I got
M = 0.5(gamma)L^2
In the second part I found the moment of inertia with the axis of rotation to be at x=0, perpendicular to the rod. I don't know how to represent the integration symbol, so I'll use "|." I am integrating from 0 to L
I = |r^2dm
I = |L^2(gamma)L = (gamma)|L^3 = [(gamma)L^4]/4
= [2M/L^2][0.25L^4] = 0.5ML^2
The third part asks me to do the same thing for the rod, this time with the axis of rotation at the opposite end of the rod. I know I have to integrate from L to 0, but shouldn't this just give me the negative of my previous expression? I know it's wrong, but I don't know how the mass expression changes at the other end. Can someone help?
Those first two seem to be fine. For calculating the moment of inertia, you want a little bit of mass multiplied by its distance from the axis, and then you sum this over the length of the rod. For the third part, because the mass is decreasing as you move along the rod, a little piece of mass is
\frac{dm}{dx} dx = \gamma (L-x) dx
So if you integrate this mass times the distance from the axis squared (x^2) between 0 and L, you should get the moment of inertia.
\int_{0}^{L} \gamma (L-x) x^2 dx
Hope that helps
Ed
Ok, this makes sense. But they want the answer in terms of M and L. When I substitute my expression for gamma after integration, I get
[(4LMX^3)-(6MX^4)]/(6L^2)
There's no way I can see to get rid of X, so now I'm stuck...again.
X is your variable of integration; you need to evaluate that definite integral over the range X = 0 to X = L.
ahhh. thanks a lot. got (1/6)ML^2
Need Help
i don't know how to set up this question...
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 21 ·
