Moment of inertia of an isosceles triangle
The discussion revolves around calculating the moment of inertia of an isosceles triangle, specifically focusing on the setup of integrals for this calculation. The original poster presents an approach involving integration over the triangle's area, but expresses uncertainty about handling double integrals.
  • Participants discuss various methods for setting up the integral, including suggestions to use Cartesian coordinates and considerations of different orientations for integration. Some express difficulty with double integrals, while others provide insights into the structure of the problem.
There is an ongoing exploration of different integration techniques and the implications of the axis of rotation. Some participants have provided guidance on how to approach the double integral, while others are questioning the assumptions about the axis of rotation and its orientation.
Participants note the constraints of the problem, including the specific parameters of the triangle and the requirement to find the moment of inertia with respect to a particular axis. There is also mention of the potential complexity involved in evaluating multivariable integrals.
Nexus99
Find the moment of inertia of an isosceles triangle of mass M = 1.0 kg, height h = 0.4 m and base angles equal to ## \alpha = \frac{ \pi}{6} ##, with respect to an axis passing through its vertex
moment of inertia
I did in this way:
## I = \int dm \rho^2 ##
Dividing the triangle in small rectangles with ##dA = dy x(y) ## where ##x(y) = 2 ctg( \alpha ) (h - y) ##
we have : ## dm = \sigma 2 ctg( \alpha ) (h - y) ##
Now i have ## \rho^2 = x^2 + (h-y)^2 ##
Now I don't know what I can do because it would be an integral in 2 variables that I don't know how to do
Why not just set up an integral in ##dxdy##?
I can't do for the moment integrals with two variables
That might be a problem. I'm not sure how you could avoid a double integral.
As has been mentioned, it's easier to impose a Cartesian frame (e.g. origin at top of triangle, ##x## axis running along the height), then the region of integration is specified by ##-\frac{x}{\tan{\alpha}} \leq y \leq \frac{x}{\tan{\alpha}}## and ##0 \leq x \leq h##, so you can write down the integral$$I_z = \int_S \rho r^2 dx dy = \int_0^h \int_{-\frac{x}{\tan{\alpha}}}^{\frac{x}{\tan{\alpha}}} \rho (x^2 + y^2) dy dx$$where ##\rho## is the area density. To evaluate this you can do the inner integral first, holding ##x## constant, and then feed the result into the outer integral.
I am sure that is easier, but i have never done a multivariable integral.
Is it possible tu use the fact that:
## I_z = I_x + I_y ##?
That is indeed true for a lamina, it follows because of the linearity of the integral$$I_z = \int_S \rho r^2 dS = \int_S \rho (x^2 + y^2) dS = \int_S \rho x^2 dS + \int_S \rho y^2 dS = I_x + I_y$$but I don't think it will help you here, since the computations will be exactly the same, just in two parts (so in fact it is more long-winded).
The double integral is not too bad... I promise! For starters, can you evaluate$$\int_{-\frac{x}{\tan{\alpha}}}^{\frac{x}{\tan{\alpha}}} \rho (x^2 + y^2) dy$$whilst treating ##x## as a constant?
Nexus99 said:
Homework Statement:: Find the moment of inertia of an isosceles triangle of mass M = 1.0 kg, height h = 0.4 m and base angles equal to ## \alpha = \frac{ \pi}{6} ##, with respect to an axis passing through its vertex
Relevant Equations:: moment of inertia
I did in this way:
I like to think of this sort of thing visually before starting down the road with formulas.
When you do a double integral, you are usually laying things out in rows and columns. You integrate down a row to get the moment of inertia of a single row. Then you add those moments up -- integrating up in the column direction.
The first challenge you always face is trying to figure out an orientation for your rows and columns. There are many possibilities here:
1. You could consider a bunch of parallel strips running perpendicular to the base, up in the general direction of the apex, find the moments of inertia of each of those and then integrate them up.
2. You could consider a bunch of narrow triangles running from apex down toward the base, find the moments of inertia of each of those and then integrate those up.
3. You could consider a bunch of strips parallel to the base, short rows near the apex and long rows near the base. This is where @etotheipi has taken you.
The moment of inertia of a thin strip about its midpoint is a well known formula. That plus the parallel axis theorem gets you to the moment of inertia of a thin strip about the apex here.
@jbriggs444 @etotheipi
thanks for explanation.
I watched some videos on youtube about double integrals and i got these results
## I_z = \frac{5 \rho h^4}{12 tan( \alpha) } = \frac{5 M h^2}{12} ##
Hope it's correct
I noticed in this moment that is present the solution of this problem:
"For the calculation of the moment of inertia, can be considered the moment of inertia of the elementary rod with mass dm, thickness dy and length l = l (y) indicated in the figure, where y is the distance from the apex of the triangle . In this case, for Steiner's theorem the moment of inertia can be written as:"
Sorry if the solution is not written in english, but there was written nothing important, so I simply tried to explain what was written with arrows
Nexus99 said:
... with respect to an axis passing through its vertex
It seems that the axis of rotation is parallel to the plane of the triangle, according to angle θ shown in the schematic; could it be perpendicular instead?
https://en.m.wikipedia.org/wiki/Centroid#Of_a_triangle
"The centroid is also the physical center of mass if the triangle is made from a uniform sheet of material; or if all the mass is concentrated at the three vertices, and evenly divided among them."
http://hyperphysics.phy-astr.gsu.edu/hbase/parax.html#pax
"The moment of inertia about a parallel axis is the center of mass moment plus the moment of inertia of the entire object treated as a point mass at the center of mass."
Lnewqban said:
Could it be perpendicular instead?
It isAnyway i don't understand what do you want to say with your previous message
Nexus99 said:
It isAnyway i didn't understand what do you want to say with your previous message
If I understand correctly, the axis of rotation is perpendicular to the plane of the triangle.
In other words, the triangle rotates about the dot, clockwise or counterclockwise on the plane over which it is represented.
Sorry about my previous post and links, perhaps I am over-simplifying the problem when I see it as estimating the moment of inertia (I) of a center of mass (m) located at the centroid of the triangle and rotating perpendicularly at a fixed distance (r) from an axis.
Yes, it's a physical pendulum.
Sorry if it was not so clear but i had to summarise the problem
