Moment of Inertia of Small Blocks on Rod: 3/4mL^2
The moment of inertia for a system of small blocks with mass m clamped at the ends and center of a massless rod of length L is calculated about an axis perpendicular to the rod, located one-fourth of the length from one end. The correct approach involves using the fundamental formula I = mr² for point masses, rather than the moment of inertia for a uniform rod, which is I = 1/2mL² or I = m(L²)/12. The total moment of inertia for the two point masses located at L/4 and 3L/4 is determined to be 11/16mL².
  • Understanding of moment of inertia concepts
  • Familiarity with the fundamental formula I = mr²
  • Knowledge of mass distribution in rigid bodies
  • Basic principles of rotational dynamics
  • Study the derivation of the moment of inertia for various shapes, including rods and point masses
  • Learn about the parallel axis theorem and its applications
  • Explore the implications of massless rods in rotational dynamics
  • Investigate the effects of mass distribution on the moment of inertia in complex systems
Physics students, mechanical engineers, and anyone involved in the study of rotational dynamics and moment of inertia calculations.
princessfrost
Small blocks, each with mass m, are clamped at the ends and at the center of a rod of length L and negligible mass
Compute the moment of inertia of the system about an axis perpendicular to the rod and passing through a point one-fourth of the length from one end.
Express your answer in terms of the given quantities.
Since I=1/2mL^2 for a system about an axis perpendicular to the rod and passing through the center of the rod, can't I just add 1/4mL^2 + 1/2mL^2 and get 3/4mL^2=I for the equation?
Read the question carefully.
Mass moment of Inertia of a rigid uniform rod of length L and mass m about an axis passing through its centre of mass and perpendicular to the length of the rod is given by I = m(L^2)/12. (and not, I=1/2mL^2, as u have quoted.)
Plz note, in the given problem, rod is of negligible mass.. so u can't apply the above formula. Instead, since point masses are involved, you should use the fundamental formula for mass moment of inertia.
is it 11/16mL^2 then?
Think of it this way, if you look at the link Astronuc provided, you see that we can use I = mR^2 if we have a massless rod, and a mass at the end of the rod. What you essentially have is two massless rods put into one. The first massless rod will have the length L/4, and the second rod will have the length 3L/4. These are also where the two masses are located relative to the axis of rotation. If you find the moment of inertia for each rod, again, using the equation Astronuc provided, you can add the rotational inertias together to get the total inertia you're looking for.
please show ur steps involved.
The rod is massless.Hence you just have to use the fundamental equation
I = mr^2
  • · Replies 21 ·
