Moment of intertia of thin disc
The discussion revolves around understanding the moment of inertia of a thin disc about its axis of rotation, specifically why it is expressed as 1/2 MR². Participants explore the relationship between the moment of inertia of a disc and that of a ring, questioning the assumptions and methods used in deriving these formulas.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the integration approach to derive the moment of inertia, questioning how the mass distribution affects the outcome. Some participants illustrate their reasoning by comparing the moment of inertia of a disc to that of a ring, raising questions about the validity of their methods.
The discussion is active, with participants providing insights into the integration process and the significance of mass distribution. There is recognition of differing interpretations of the problem, particularly regarding the treatment of mass elements and their distances from the center.
Some participants express confusion over the derivation processes and the implications of treating mass elements at equal distances versus varying distances in the context of a disc versus a ring. There is acknowledgment of the need for clarity in the definitions and assumptions being used in the calculations.
BradP
This is not a homework question but it could be. I am trying to understand why the moment of inertia of a thin disc about its axis of rotation is 1/2 MR2.
The rotational moment of inertia of a system of points is [tex]^{}\sum[/tex]mr2.
However, if you just took one point at radius r and divided its mass into as many points as it took to make a virtual ring with radius r, the result of [tex]^{}\sum[/tex]mr2 is mr2, right? So how is this the equation for a solid disc and not a thin ring?
Consider a mass at a distance 'r' on the disc.
The total moment of intertia of the disc is ∫r2 dm = ∫ r2 σ dA where σ is the mass per unit area.
Now dA is just the circumference of that ring * width of the ring (dr)
So if the radius of the ring is 'r' what is the circumference?
So the integral becomes [tex]\sigma[/tex]∫r2(2*pi*r)*dr.
(I cannot type any more. Whenever I enter a latex symbol it shows up as some random unrelated symbol.)
Yes and the 'r' varies from 0 to R.
Okay, I see how that works. The sigma*pi*r^2 turns into M. But I still do not see why the concept that I illustrated does not also create 1/2*M*R^2. Suppose you start with a mass M at a distance R from the center. Then you divide that mass into 100 pieces and you equally distribute the pieces around a point in a ring, all at a distance R. The moment of inertia of each piece would be 1/100*1/2*M*R^2. Applying [tex]^{}\sum[/tex]mr2 yields 100*1/100*1/2*M*R^2, which equals 1/2*M*R^2. Isn't that right? How could it be the same?
Because you are dividing up the mass into equal pieces at the the same radius. So when you sum them up you would get that.
Usually to get the moment of inertia you would start with a small delta element and then form an expression for the inertia of that and then integrate over the entire mass.
Yeah, that is what I did. My point is that it created a ring with mass M. So why doesn't the formula work?
I used a delta element of 1/100th of the total mass, and I found the expression of the inertia of that as 1/100*M*R^2. I then integrated over the entire ring, from 0 to 2*pi.
It is best that you use a delta element of mass 'dm' but, with your way, if you take an element of mass 0.01M at a distance of R; then you've divided the mass into 100 pieces and you placed them all at a distance 'R'. Which is not the case in a disc. All pieces are not equidistant from the center.
I know. This is the formula I derived for a ring, not a disc. My question is why I ended up with the same formula as that of a disc. The derivation seems sound to me.
you have Idisc = 0.5mr2 and Iring =mr2.
the only time you ended up with mr2 is initially when you took individual elements at equal distances of 'r' and summed them up. That forms a ring and not a disc.
You should not end up with the inertia of the ring when you do it for a disc.
But in your OP, you took one point and subdivided that, which would give you mr2 being the inertia of a point mass.
Oh wow, I thought I was getting the same thing. I don't know how I overlooked the (1/2), sorry.
Well, the point was that I formed a ring by subdividing the point mass, but that doesn't matter anymore.
15K
  • · Replies 27 ·
