Momentum and movement basic GCSE Quest
The discussion revolves around a momentum problem involving Mr. Green, who steps off a boat, and the resulting motion of the boat. The participants explore the principles of momentum conservation in a system where two objects are initially at rest.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the initial conditions of the problem, questioning how to apply momentum conservation. There are attempts to clarify the definitions of momentum and the implications of directionality in the calculations. Some participants express confusion about the formulas needed to solve the problem.
The discussion is ongoing, with participants providing hints and guidance regarding the momentum calculations. There is an exploration of different interpretations of the problem, particularly concerning the signs of momentum and the relationship between the velocities of Mr. Green and the boat.
Some participants note the lack of information regarding time or distance, which complicates the calculation of velocity. The discussion also highlights the importance of correctly applying vector principles in momentum calculations.
nonthesecond
Mr Green, mass 80 kg, stepped off a boat of mass 35 kg at a speed of 3m/s. how fast did the boat move in the opposite direction?
i have no idea how to work it out?
I think you will find that Mr Green and the boat are assumed to be at rest initially, so the total momentum was - and will remain - zero.
ok thanks but how do i answer the question?
i still don't understand i don't understand what formula to use as well.
If you define the direction Mr Green goes as positive, he will have some positive momentum after he leaves the boat.
To maintain a total of zero, the boat must have an equal sized, but negative momentum - so it will be traveling at an appropriate speed in the negative direction (ie the other way)
i think i remeber my teacher saying that it's: 80 + 35= 115
115 x 3 = 375
375/35 = 1.3...m/s
is that correct?
115 x 3 = 375
375/35 = 1.3...m/s
is that correct?
Sadly, no.
When you added the masses and multiplied by 3 (presumably the speed of Mr Green), you calculate the momentum if both he and the boat were traveling at that veocity; only he is.
115 x 3 = 375
375/35 = 1.3...m/s
is that correct?
answer these in order:
What is Mr Green's mass?
What is Mr Green's velocity?
What is Mr Green's momentum?
What is the boat's momentum?
What is the boat's mass?
What is the boat's velocity?
you are very kind for helping me.
80kg
240 kg m/s
105 kg m/s
35kg
no idea for velocity i know formula is f=d/t but you aren't given time or distance.
80kg correct
(+3) - but you didn't answer that question
+240 kg m/s almost correct
105 kg m/s incorrect
35kg correct
For that final velocity - think about how you calculated the momentum of Mr Green - and don't forget to use + and - signs correctly.
Velocity is a vector; so can be positive or negative.
EDIT: Hint - answers 3 and 4 add up to zero
is the answer 240/35?
did i get the question right?
Certainly is.
  • · Replies 29 ·
