What Causes an Object to Stop after a Collision?
  • Thread starter Thread starter mike_302
    Momentum Zero
The discussion centers on the collision of two balls, specifically a 0.25 kg ball moving at 1.7 m/s and a 0.18 kg ball moving at 2.5 m/s. After the collision, the 0.25 kg ball reverses direction with a speed of 0.10 m/s, leading to the conclusion that the 0.18 kg ball comes to a complete stop at 0 m/s. The key takeaway is that the conservation of momentum is the primary factor determining the outcome of the collision, with no additional indicators present to suggest that one object will stop.
  • Understanding of momentum conservation principles
  • Basic knowledge of physics equations related to collisions
  • Familiarity with mass and velocity calculations
  • Ability to analyze one-dimensional motion
  • Study the principles of momentum conservation in elastic and inelastic collisions
  • Learn how to apply the conservation of momentum equation in various collision scenarios
  • Explore the effects of mass and velocity on collision outcomes
  • Investigate real-world applications of collision physics in sports and vehicle dynamics
Students studying physics, educators teaching collision dynamics, and anyone interested in understanding the principles of momentum in collisions.
mike_302
Two balls roll directly towards each other. The 0.25kg ball has a speed of 1.7m/s. The 0.18kg ball has speed of 2.5m/s. After the collision, the 0.25kg ball has reversed its direction and has a speed of 0.10m/s . What is the magnitude and direction of the 0.18 kg ball after hte collision?
P(total)=P'(total)
I know the answer... IT's 0 m/s . Further question though:
On a test, I'd be questioning that result. As I did when I first obtained it in the homework... So I thought to myself: Zero tends not to just come out of nowhere... There's usuall an indicator that it's coming. What is the indicator that one of the objects in a collision will stop? Is there any sort of indicator in this case?
Thanks!
Mike
There's no special indicator in this case other than the momentum conservation calculation.
  • · Replies 32 ·
  • · Replies 19 ·
