Momentum/Impusle problem [revised]
  • Thread starter Thread starter harelo
12 replies · 2K views
harelo
So my problem says: "Car A (in a frictionless surface) travels at a velocity and weighs 1100 kg, Car B is parked and weighs 2200 KG, they collide in an inelastic collision (meaning they stick together) and they move a distance of 2.8 M together. The road has a coefficient of friction of 0.4"
Find the velocity of the Car A before impact
Last time I posted this question, our professor did not give us a coefficient of friction, which deemed the problem impossible to solve with mathematical values, but now that he realized his mistake, he gave us the problem again (an a re-test) so I just wanted to know if I'm along the right lines.
Since
[tex]F_{f}[/tex] = [tex]U_{k}[/tex]mg,
and
F = [tex]F_{f}[/tex],
we can asume that
ma = [tex]U_{k}[/tex]mg
and the masses would divide out, so
a = [tex]U_{k}[/tex]g
a = (0.4)(-9.82 [tex]m/s^{2}[/tex])
a = -3.982 [tex]m/s^{2}[/tex]
so then we can use the kinematic equation of
[tex]V_{f}[/tex]^2 = [tex]V_{o}[/tex]^2 + 2ad
where [tex]V_{f}[/tex] = 0 (this is the only part I'm iffy about), so
[tex]V_{o}[/tex] = [tex]\sqrt{-2ad}[/tex]
[tex]V_{o}[/tex] = 4.7 m/s
Is this correct? thank for the help :)
There will be a vf that is nonzero, unless car A accelerates to 0m/s before it collides with car B
Feldoh said:
Unless car a accelerates to 0m/s then vf will not equal 0
Wouldn't the fact that they crashed and there is a force of friction mean they'll eventually come to a rest?
EDIT: but not over that distance, now I see what I did.
So should I approach it some other way? maybe through work?
Yes eventually but momentum has to be conserved and right after they collide they will still be moving because if the collided them car A had a momentum that was not 0 so then the momentum right after the crash will have to get a nonzero number as well.
Edit: Work backwards, you can use the fact that the two cars went 2.8m after the collision to your advantage.
Well since I have a distance, and an acceleration and a mass, I can get work.
W = F[tex]\Delta[/tex]d
W = (m1 + m2)ad
W = (3300)(-3.982)(2.8)
W = -36793.68 J
and since W = KE
W = 1/2mv^2
v = [tex]\sqrt{2W/m}[/tex]
v = 4.72 m/s
what? ok now I'm lost.
Am I missing something in my interpretation of work?
The acceleration was the value before they collided, that won't be the acceleration after they collide.
Hmmmm alright, so I'm guessing kinematic equations won't work... I'm lost, can I get a clue please?
View the problem as having two parts:
(1) The collision. Hint: What's conserved?
(2) The coming to a stop due to friction (after the collision). What's the acceleration?
Begin by looking at part two and figure out the initial speed of the stuck-together cars immediately after the collision.
well I know that Momentum is conserved, however kinetic energy isn't (inelastic collisions, do'h)
and the acceleration would be the the coefficient of friction times acceleration due to gravity (like shown above).
So,
[tex]m_{1}[/tex][tex]v_{1}[/tex] = ([tex]m_{1}[/tex]+[tex]m_{2}[/tex])[tex]V^{'}[/tex]
hmmmm... Where can this get me?
Good. (I see you've already calculated the initial speed of the stuck-together cars immediately after the collision.)
So,
Good. Use conservation of momentum to figure out the initial speed of car A.
OHHHHHH how can I be so dumb! that speed I Calculated is V'! wow I'm dumb!
So now it should be:
[tex]v_{1}[/tex] = (([tex]m_{1}[/tex]+[tex]m_{2}[/tex])[tex]V^{'}[/tex]) / [tex]m_{1}[/tex]
[tex]v_{1}[/tex] = ((3300)(4.72))/1100
[tex]v_{1}[/tex] = 14.16 m/s
I think this should be right, is it?
