Momentum operator and comutators
In summary, the momentum in x direction is represented by an operator, p=-ih\frac{d}{dx}. The comutator is used to calculate [x,p^2]: [x,p^2]=xp^2-p^2x=x*(-h^2\frac{d^2}{dx^2})+h^2\frac{d^2}{dx^2}(x)=0+0=0.
Ene Dene
48
I'm having trouble understanding the folowing:
(I'll write h for h/(2Pi))
Momentum in x direction is represented by operator
[tex]p=-ih\frac{d}{dx}[/tex].
So comutator
[tex][x,p]=xp-px=x(-ih)\frac{d}{dx}-(-ih)\frac{dx}{dx}=0+ih*1=ih.[/tex]
Now here comes the part that I don't understand. I'll calculate [x,p^2]:
[tex][x,p^2]=xp^2-p^2x=xpp-ppx[/tex],
but from:
[tex][x,p]=xp-px=ih[/tex]
I have:
[tex][x,p^2]=xpp-ppx=(ih+px)p-p(-ih+xp)=2ih+pxp-pxp=2ih[/tex]
As it should be. But why can't I say:
[tex]p^2=pp[/tex],
[tex](-ih)\frac{d}{dx}*(-ih)\frac{d}{dx}=-h^2\frac{d^2}{dx^2}[/tex]
And write:
[tex][x,p^2]=xp^2-p^2x=x*(-h^2\frac{d^2}{dx^2})+h^2\frac{d^2}{dx^2}(x)=0+0=0[/tex]
I don't know how you are reducing the last line to zero. [x,p^2] in this representation is an operator. It needs to operate on something. Work out [x,p^2](f(x)) for an arbitrary function f(x).
try to apply the comutator on a arbitrary wavefunction[tex]\psi [/tex]. Remember that [itex]p^2[/itex] is not the p-operator squared, it is performed twice on a wavefunction:
[tex]p^2 \psi=-ih\frac{d}{dx} \left(-ih\frac{d}{dx} \psi \right) [/tex]
Edit: Dick was 5 seconds before me =)
Yes, of course, I understand now! Thank you!
So comutator
but from:
I have:
the third equal sign is the above equation is incorrect (you didn't distribute the p correctly). The equation should read:
[tex]
[x,p^2]=xpp-ppx=(ih+px)p-p(-ih+xp)=2ihp+pxp-pxp=2ihp
[/tex]
In general
[tex]
[x,f(p)]=i\hbar f'(p)
[/tex]
and the above is a special case with f(p)=p^2.:wink:
You better also had done the first one that way, as not to get confused by what the differential operator acts on.
Let f denote a function of x, then
[tex][x,p]f = xpf-pxf=x(-ih)\frac{df}{dx}-(-ih)\frac{dxf}{dx}= -i h x f' + i h (f + x f') = i h f[/tex]
so dropping the function we see [tex][x, p] = i h[/tex].
And this method will give you the correct result for any commutator (just remember, the differentiation operator works as far as possible to the right, so [itex]\frac{d}{dx} x f [/itex] really is [itex]\frac{d (x f)}{dx}[/itex] and not [itex]\left( \frac{dx}{dx} \right) \cdot f[/itex]).
How come there is no h^2 term after we do it this way? Using the definition, I don't see why I only get an h and not h^2.
1. What is a momentum operator?
A momentum operator is a mathematical operator that represents the momentum of a particle in quantum mechanics. It is typically denoted as p and is defined as the product of the particle's mass and velocity.
2. How is the momentum operator defined mathematically?
The momentum operator is defined as p = -iħ∇, where ħ is the reduced Planck's constant and is the gradient operator.
3. What is the commutator of two momentum operators?
The commutator of two momentum operators is given by [px, py] = pxpy - pypx = 0. This means that the operators commute, or that the order in which they are applied does not matter.
4. What is the significance of the commutator of momentum operators?
The commutator of momentum operators is significant because it is related to the uncertainty principle in quantum mechanics. It implies that the momentum and position of a particle cannot be known simultaneously with absolute certainty.
5. How is the momentum operator used in quantum mechanics?
The momentum operator is used in quantum mechanics to describe and calculate the behavior of particles in terms of their momentum. It is a fundamental operator that is used in many equations and principles, such as the Schrödinger equation and the Heisenberg uncertainty principle.
