Solving Momentum Questions: Two Rolling Golf Balls Collision
  • Thread starter Thread starter hulkster
    Momentum
The discussion focuses on solving a momentum problem involving two rolling golf balls of equal mass colliding at different angles. The initial velocity of one ball is 2.70 m/s towards the east, while after the collision, the velocities of the balls are 2.49 m/s at 62.8 degrees north of west and 2.37 m/s at 69.2 degrees south of east. The unknown initial velocity of the second ball is determined to be 3 m/s towards the west. The conservation of momentum is applied using vector components to solve the problem.
  • Understanding of momentum conservation principles
  • Knowledge of vector components and trigonometric functions
  • Familiarity with coordinate systems in physics
  • Ability to solve simultaneous equations
  • Study vector decomposition in physics problems
  • Learn about momentum conservation in two-dimensional collisions
  • Practice solving problems involving angles and trigonometric functions
  • Explore graphical methods for visualizing momentum vectors
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators looking for practical examples of collision problems.
hulkster
Ok. So I have spent about 40 mins on this question, and can't seem to get it. I know how to conserve momentum when an object hits another at rest, using the cosine and sine laws. but this question involves two objects both moving at different angles. We'll, here it is, if anyone can help:
Two rolling golf balls of the same mass collide. The velocity of one ball is initially 2.70m/s[E] . After the collision, the velocities of the balls are 2.49m/s [62.8 degrees N of W] and 2.37m/s[69.2 degrees S of E]. What is the magnitude and direction of the unkown initial velocity?
The answer is 3m/s[W}...Any help would be greatly appreciated...Thanks.
Have you drawn a diagram, show all the velocities?
Since momentum is a vector, if it is conserved, then it is conserved in all directions. So set up a coordinate system (E is +x and N is +y is fairly standard) and break everything up into components. So you have an initial momentum component for each golf ball in the x direction and the same for the y direction.
p_{01x}+p{02x}=p_{1x}+p_{2x}
and a similar equation in the y direction. Plugging in your known values (and taking vector components) leaves you two equations in two unknowns.
-Dan
  • · Replies 19 ·
