Which Iceboat Finishes with Greater Momentum?
In the iceboat race problem, two iceboats with masses m and 2m experience the same force F and cross the finish line with equal kinetic energy. However, the iceboat with mass 2m has greater momentum due to its longer acceleration time. The momentum of the heavier boat is shown to be √2 times greater than that of the lighter boat, confirming that p = mv and the relationship between kinetic energy and velocity was correctly applied, leading to the conclusion that the heavier boat's momentum is indeed 2√2.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of momentum and kinetic energy
  • Knowledge of impulse and its relation to force and time
  • Basic algebra for manipulating equations
  • Study the relationship between momentum and kinetic energy in different mass systems
  • Explore the concept of impulse and its applications in physics
  • Learn about the conservation of momentum in collision scenarios
  • Investigate the effects of varying forces on acceleration and momentum
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of momentum and kinetic energy principles.
learnitall
Two iceboats hold a race on a frictionless horizontal lake. The two iceboats have masses m and 2m. Each iceboats has an identical sail, so the wind exerts the same constant force F on each boat. The two ice boats start from rest and cross the finish line a distance s away. The total work done to accelerate each of the boats from rest are the same (because the net force and displacement were the same for both). Hence both iceboats cross the finish line with the same kinetic energy.
a)Which iceboat crosses the finish line with greater momentum?
b)Can you show that the iceboat with mass 2m has √2 times as much momentum at the finish line as the iceboat of mass m?
J = p2-p1=ƩFΔt
p=mv
K=(1/2)mv2
W=Fds
I know that the boat with mass 2m will have greater momentum crossing the finish line by realizing the boat with the larger mass will take a longer amount of time for it to travel from rest to a distance s. Thus the impulse from the larger boat will be bigger. Since the iceboat starts
from rest, this equals the iceboat's momentum p at the finish line:
P=FΔt.
Im having trouble with part b of the problem. This is my thought process:
Both boats will cross the finish line with the same kinetic energy
∴ (1/2)mv2=(1/2)(2m)[(1\2)v2
Half, of the heavier boat's, square speed must be equal to the square of the lighter one for the kinetic relation to be true. If this is the case then,
can't I make new relation of speeds? what I mean is:
(1/2)vheavier2=vlighter2
after some algebra → (vheavier)/√2 = vlighter
so
pheavier=2mvheavier
plighter=mvlighter
so to find how much larger the momentum of the heavier boat is to divide the two using the substitution of the lighter velocity:
(2m)(vheavier)/[(mvheavier)/√2] = 2√2
why is my quantity two times larger than it should be?
Equating the kinetic energies was a right choice... But the simplification was a bit confusing...
This is where it went wrong. It has to be √2vheavier=vlighter...
Other than that everything is fine, check your calculations and you will be on your way...
Regards
I think it went wrong a little earlier.
To clarify
(1/2)mvlight2=(1/2)(2m)vheavy2
Take it forwards from there.
Ah, i see now. I didnt need that extra (1/2) factor. I also understand why I didnt need it. Thanks guys
  • · Replies 21 ·
  • · Replies 22 ·
