Monomorphism cancellation property
  • Context: Graduate
  • Thread starter Thread starter tom.coyne
    Property
The discussion centers on the monomorphism cancellation property in topology, specifically regarding the implications of homotopy and injective maps. It is established that if a continuous map \( f: X \rightarrow Y \) is a split monomorphism, then \( f \circ g \simeq f \circ h \) implies \( g \simeq h \). However, when \( f \) is merely an injection into a contractible space, the implication does not hold, as counterexamples exist. The conversation also touches on the conditions under which a map can be considered a "homotopy monomorphism," particularly focusing on the injectivity of induced maps on homotopy groups.
  • Understanding of monomorphisms in category theory
  • Familiarity with homotopy theory and homotopy groups
  • Knowledge of continuous maps and their properties in topology
  • Awareness of Whitehead's and Hurewicz's theorems
  • Study the properties of split monomorphisms in topological spaces
  • Explore the implications of Whitehead's theorem on homotopy equivalence
  • Investigate examples of maps into contractible spaces and their homotopy properties
  • Learn about the injectivity of induced maps on homotopy groups and its significance
Mathematicians, topologists, and students of algebraic topology seeking to deepen their understanding of monomorphism properties and homotopy theory.
tom.coyne
Hi, I know that if I have a monomorphism f:X\rightarrow Y then for any arrows g,h:A \rightarrow X we have f \circ g = f \circ h \; \Rightarrow \; g=h
However in a topological space, if I have f to be an injection but now have f \circ g \simeq f \circ h (where \simeq denotes homotopic) then does this imply that g \simeq h?
So my question is, is this true? If not what conditions would I require to make it true?
Thanks,
Tom
Thanks,
Tom
if f is continuous with a continuous inverse, then you will have that g and h are homotopic to each other. ( apply f^-1 to the homotopy family )
So if f is a split monomorphism then this works. What about when its not a split monomorphism? Can you think of any counter examples?
aren't any two maps to a contractible space homotopic? does that suggest a counterexample?
Ok, so if f is an injection into a contractible space Y then if g \not\simeq h then we would still have f \circ g \simeq f \circ h.
Thanks!
so what kind of map would be a "homotopy monomorphism"? what if it were injective on homotopy groups? (and you were working with nice spaces, like simplicial complexes.)
start by proving this is necessary.
If f\circ g \simeq f \circ h \; \Rightarrow \; g \simeq h then f_*\circ g_* = f_* \circ h_* \; \Rightarrow \; g_* = h_* hence f_* is injective.
If f is a map such that f_* is monic for all homotopy groups, then if we have f \circ g \simeq f \circ h then this implies that f_* \circ g_* = f_* \circ h_* hence g_*=h_* for all homotopy groups. Now I am getting a bit stuck... I know that g_*=h_* does not imply that g \simeq h. But I can't think of an example where g \not\simeq h and f \circ g \simeq f \circ h. Am I going down the right lines here?
I don't follow your argument. homotopy group elements are represented by maps g,h, so injectivity seems to say that fg ≈ fh implies g ≈ h, which is the hypothesis restricted to maps g,h, of spheres.
as to the other direction, have you heard of whitehead's theorem? or is it Hurewicz' theorem? that two maps are homotopic on CW complexes iff they induce the same maps on homotopy groups. better check that, it has been over 40 years since i took homotopy theory.
...well i seem to be overstating whitehead's theorem, but maybe it can be strengthened.
I thought about trying to use Whitehead's Theorem. But it states that if a map between CW complexes induces isomorphism on all homotopy groups then it is a homotopy equivalence. I wasn't sure how to use this though.
Also, I am not sure I totally understood your previous answer. Were you suggesting that a way to get a cancellation property might be to try:
if f:X \rightarrow Y is a map such that f_*:\pi_k(X) \rightarrow \pi_k(Y) is injective for all k then f\circ g \simeq f \circ h \; \Rightarrow \; g \simeq h??
Or did I misunderstand your response?
Thanks for your continued help!
no, the converse.
  • · Replies 0 ·
  • · Replies 26 ·
