Monte Carlo Wang-Landau_antiferromagnetic perovskite
  • Context: Graduate
  • Thread starter Thread starter UFSJ
The discussion revolves around the application of the Wang-Landau algorithm to simulate the magnetic behavior of a bulk perovskite using the Monte Carlo method. Participants explore the Hamiltonian model describing the system and share code snippets for obtaining the density of states, while seeking assistance with an unexpected phase transition temperature result.
  • One participant describes their use of the Wang-Landau algorithm to simulate the magnetic behavior of a perovskite, detailing the Hamiltonian parameters including exchange constants and anisotropic constants.
  • The participant reports obtaining a phase transition temperature of 75 K, which is significantly lower than the expected experimental value of 139.5 K, and seeks input on potential errors in their Fortran code.
  • Some participants suggest reviewing the Hamiltonian parameters and the implementation of the Monte Carlo method to identify possible sources of error.
  • Others propose examining the boundary conditions set in the simulation, as they may influence the results.
  • A later reply questions whether the initial spin configurations might be affecting the phase transition temperature observed in the simulations.
  • There is discussion about the significance of the flatness parameter in the Wang-Landau algorithm and its potential impact on the results.
Participants do not reach a consensus on the cause of the discrepancy in the phase transition temperature, with multiple competing views on potential sources of error and the influence of various parameters in the simulation.
Limitations include the dependence on specific Hamiltonian parameters and the initial conditions set for the spins, which may not be fully explored or validated in the current discussion.
UFSJ
Hi guys.
Using the Wang-Landau algorithm, I have tried to simulate the magnetic behavior of a bulk perovskite by the Monte Carlo method. I have used the JDoS description to build the Energy x magnetization phase space. By a referencing article, this magnetic system can be described by the Hamiltonian:
H = - 2J1 ∑ Si Sj - 2J2 ∑ Si
Sk - D ∑ Si 2, where J1 is the exchange constant between two spins of the same basal plane (0.83 meV), J2 is the exchange constant between two different basal planes (- 0.58 meV), D is the anisotropic constant (0.165 meV) and the experimental TN = 139.5 K. This compound is an A-type Néel antiferromagnetic. Below, I share my Wang-Landau program to obtain the density of states (actually to obtain the ln[g(E,m)]) written in Fortran 90. Can anyone point out where my error is? I am obtaining a phase transition temperature at 75 K.
Thanks![CODE lang="fortran" title="Wang-Landau JDoS"]
PROGRAM Perov_4est_JDoS
IMPLICIT NONE
INTEGER, PARAMETER :: lz = 20 ! lattice length
INTEGER, PARAMETER :: ly = 20
INTEGER, PARAMETER :: lx = 20
INTEGER, PARAMETER :: n = lx*ly*lz ! number of spins
INTEGER, PARAMETER :: ff = 25 ! number of loops applying the modification factor e^0.5
REAL, PARAMETER :: flat = 0.95 ! the flatness parameter
INTEGER, PARAMETER :: cond = 1 ! if cond =1 the boundary conditions is ON, if cond = 0 is OFF
REAL, PARAMETER :: J1 = 2*0.83 ! exchange constant in the same basal plane in units of de meV
REAL, PARAMETER :: J2 = 2*(-0.58) ! exchange constant between basal planes in units of de meV
REAL, PARAMETER :: D = 0.1*J1 ! anisotropic constant in units of meV
REAL, PARAMETER :: E_max = n*((J1*16 - J2*8)/2 - D*4) ! maximum energy value
INTEGER, PARAMETER :: bin_E = 10**4 ! maximum number of different energy values to be get
INTEGER, PARAMETER :: bin_m = 10**4 ! maximum number of different magnetization values to be get
INTEGER :: r, k, q, r1, r2, k1, k2, px, py, pz, pV, pG, pr, pf, ping, pong, idum, sf
REAL :: Ei, Ef, mi, mf, E_latt, M_latt, E, m
DOUBLE PRECISION :: test, E_fund, h_sum, f, ln_Ohm_fund
INTEGER, DIMENSION (bin_E,bin_m) :: h, h_acum ! matrix Histograma and accumulated Histograma
DOUBLE PRECISION, DIMENSION (bin_E,bin_m) :: g ! matrix of the log of density of states
REAL, DIMENSION (bin_E) :: E_val ! array of energy values
REAL, DIMENSION (bin_m) :: m_val ! array of magnetization values
INTEGER, DIMENSION (n+1) :: s ! spin ! array os the values of the spin
INTEGER, DIMENSION (n) :: sv1 ! at right ! arrays of the neighbor's position along the spin chain
INTEGER, DIMENSION (n) :: sv2 ! at left
INTEGER, DIMENSION (n) :: sv3 ! in the next line
INTEGER, DIMENSION (n) :: sv4 ! in the bottom line
INTEGER, DIMENSION (n) :: sv5 ! in the up basal plane
INTEGER, DIMENSION (n) :: sv6 ! in the down basal plane
CHARACTER(LEN = 70) :: txt
REAL :: rd, xrand
idum = 123456789
s(n+1) = 0
! Array of first neighbors
DO pz=1,lz
DO py=1,ly
DO px=1,lx
r = px + lx*(py - 1) + lx*ly*(pz - 1)
sv1(r) = r + 1 ! at right
sv2(r) = r - 1 ! at left
sv3(r) = r + lx ! in the next line
sv4(r) = r - lx ! in the bottom line
sv5(r) = r + lx*ly ! up
sv6(r) = r - lx*ly ! down
END DO
END DO
END DO! Boundary condition
IF (cond==1) THEN ! boundary condition ON
DO pz=1,lz
DO py=1,ly
DO px=1,lx
IF(px==lx) THEN
sv1(r) = r - lx + 1 ! at right
END IF
IF(px==1) THEN
sv2(r) = r + lx - 1 ! at left
END IF
IF(py==ly) THEN
sv3(r) = r - lx*(ly - 1) ! in the next line
END IF
IF(py==1) THEN
sv4(r) = r + lx*(ly - 1) ! in the line before
END IFIF(pz==lz) THEN
sv5(r) = r - lx*ly*(lz - 1) ! up
END IF
IF(pz==1) THEN
sv6(r) = r + lx*ly*(lz - 1) ! down
END IF
END DO
END DO
END DOELSE IF (cond==0) THEN ! boundary condition OFF
DO pz=1,lz
DO py=1,ly
DO px=1,lx
IF(px==1) THEN
sv2(r) = n + 1 ! at left
END IF
IF(px==lx) THEN
sv1(r) = n + 1 ! at right
END IF
IF(py==1) THEN
sv4(r) = n + 1 ! in the line before
END IF
IF(py==ly) THEN
sv3(r) = n + 1 ! in the next line
END IF
IF(pz==1) THEN
sv5(r) = n + 1 ! up
END IF
IF(pz==lz) THEN
sv6(r) = n + 1 ! down
END IF
END DO
END DO
END DO
END IF
!!!!! Building the phase space E x m and updating the ln[g(E,m)] and histogram
DO r=1,bin_E
DO k=1,bin_m
g(r,k)= 1
h_acum(r,k) = 0
E_val(r) = 123456789 ! filling the energy and magnetization arrays with any wrong values. As a new state is observed, these values will be updating
m_val(k) = 123456789
END DO
END DO
DO k=1,n ! defining values for the spin-lattice
rd = xrand(idum)
IF (rd<=0.2) THEN
s(k) = - 2
ELSE IF ((0.2<rd).AND.(rd<=0.4)) THEN
s(k) = - 1
ELSE IF ((0.4<rd).AND.(rd<=0.6)) THEN
s(k) = 0
ELSE IF ((0.6<rd).AND.(rd<=0.8)) THEN
s(k) = 1
ELSE IF (0.8<rd) THEN
s(k) = 2
END IF
END DO
E_latt = 0
M_latt = 0
DO k=1,n ! obtaining the initial values of energy and magnetization of the chain
E_latt = E_latt - s(k)*( J1*( s(sv1(k)) + s(sv2(k)) + s(sv3(k)) + s(sv4(k)) )/2 + J2*( s(sv5(k)) + s(sv6(k)) )/2 + D*s(k) )
M_latt = M_latt + s(k)
END DO
Ei = E_latt
mi= M_latt
E_val(1) = Ei
m_val(1) = mi
DO pf=1,ff ! defining the value of the modification factor
f = exp(1.0)**( 1/(2**(pf - 1.0) ) )
DO r=1,bin_E
DO k=1,bin_m
h(r,k)= 0 ! histogram
END DO
END DO
print*, 'pf-', pf
ping = 0
DO WHILE (ping==0) ! the beginning of the loop responsible for the flatness test
DO pV=1,n*10**6 ! Monte Carlo loops testing new configuration of the chain
rd = xrand(idum) ! random choice of a spin "q" to be flipped
q = NINT(n*rd)
IF(q==0) THEN
q = n
END IF
rd = xrand(idum) ! Analyzing the flip of the spin "q"
IF (s(q)==-2) THEN
IF (rd<=0.25) THEN
sf = - 1
ELSE IF ((0.25<rd).AND.(rd<=0.5)) THEN
sf = 0
ELSE IF ((0.5<rd).AND.(rd<=0.75)) THEN
sf = 1
ELSE IF (0.75<rd) THEN
sf = 2
END IF
ELSE IF (s(q)==-1) THEN
IF (rd<=0.25) THEN
sf = - 2
sf = 0
sf = 1
sf = 2
END IF
ELSE IF (s(q)==0) THEN
IF (rd<=0.25) THEN
sf = - 2
sf = - 1
sf = 1
sf = 2
END IF
ELSE IF (s(q)==1) THEN
IF (rd<=0.25) THEN
sf = - 2
sf = - 1
sf = 0
sf = 2
END IF
ELSE IF (s(q)==2) THEN
IF (rd<=0.25) THEN
sf = - 2
sf = - 1
sf = 0
sf = 1
END IF
END IF
! Calculating the value of energy and magnetization of the possible final state with the flip of the spin "q"
Ef = Ei - (sf - s(q))*( J1*( s(sv1(q)) + s(sv2(q)) + s(sv3(q)) + s(sv4(q)) ) + J2*( s(sv5(q)) + s(sv6(q)) ) ) &
- D*(sf**2 - s(q)**2)
mf = mi + (sf - s(q))
DO r=1,bin_E ! identifying the position of the final energy along the Energy values array
IF (abs(E_val(r) - Ef) <= 0.001 ) THEN
r2 = r
GO TO 100
END IF
END DO
DO r=1,bin_E ! defining a position for the final energy along the Energy array, if it already not have been made
IF (abs(E_val(r) - 123456789) <= 0.001) THEN
E_val(r) = Ef
r2 = r
GO TO 100
END IF
END DO
100 CONTINUE
DO k=1,bin_m ! identifying the position of the final magnetization along the magnetization values array
IF (abs(m_val(k) - mf) <= 0.001 ) THEN
k2 = k
GO TO 200
END IF
END DO
DO k=1,bin_m ! defining a position for the final magnetization along the magnetization array, if it already not have been made
IF (abs(m_val(k) - 123456789) <= 0.001) THEN
m_val(k) = mf
k2 = k
GO TO 200
END IF
END DO
200 CONTINUE rd = xrand(idum) ! analyzing the possibility of changing from initial state to the final state and updating the histogram and density of states
IF (exp(g(r1,k1) - g(r2,k2)) >= 1) THEN
g(r2,k2) = g(r2,k2) + log(f)
h(r2,k2) = h(r2,k2) + 1
h_acum(r2,k2) = h_acum(r2,k2) + 1
s(q) = sf
r1 = r2
k1 = k2
ELSE IF (exp(g(r1,k1) - g(r2,k2)) >= rd) THEN
s(q) = sf
r1 = r2
k1 = k2
ELSE ! Keeping in the initial state and updating the histogram and density of states
g(r1,k1) = g(r1,k1) + log(f)
h(r1,k1) = h(r1,k1) + 1
h_acum(r1,k1) = h_acum(r1,k1) + 1
END IFEND DO ! end of pV loop
!!!!!!!!!!!!!!! flatness test
h_sum = 0
pr = 0
DO r=1,bin_E
DO k=1,bin_m
IF (h_acum(r,k)>0) THEN ! considering just visited states, that is, the states with accumulated histogram not zero
pr = pr + 1
h_sum = h_sum + h(r,k)
END IF
END DO
END DO
pong = 0
DO r=1,bin_E
DO k=1,bin_m
test = h(r,k)/(h_sum/pr)
IF (test < flat) THEN
pong = pong + 1
END IF
END IF
END DO
END DO
! if all considered states pass the flatness test, then "ping" changes to 1 and we go out of the flatness test, update the modification faction and repeat the process
IF (pong == 0) THEN
ping = 1
END IFEND DO ! final of the flatness loop
END DO ! final of the modification factor loop
!!!!!! Normalization of the density of states
ln_Ohm_fund = 0
E_fund = E_max ! starting considering the smallest value of energy as the maximum possible value
DO r=1,bin_E
DO k=1,bin_m
IF ((h_acum(r,k)>0).AND.(E_val(r) < E_fund)) THEN ! updating the smallest value of energy among the values computed
E_fund = E_val(r)
ln_Ohm_fund = g(r,k)
END IF
END DO
END DO
DO r=1,bin_E
DO k=1,bin_m
g(r,k) = g(r,k) - ln_Ohm_fund + log(1.0) ! Updating the value of the density of states
END IF
END DO
END DO
! creating the output file with the energy and magnetization values and the respective ln[ g(E,m) ]
WRITE(txt,"(f4.2,f5.2,f4.2,I3,I3,I3,I0)") J1, J2, flat, ly, lx, lz, cond
WRITE(txt, "(A,f4.2,A,f5.2,A,f4.2,A,I3,A,I3,AI3,A,I0,A)") 'J1=',J1,'J2=',J2,'_ &
<h>=',flat,'lx=',lx,'ly=',ly,'lz=',lz,'cond=',cond,'.dat'
OPEN(2, FILE = trim(txt), STATUS = 'unknown')
DO r=1,bin_E
DO k=1,bin_m
WRITE(2, *) E_val(r),';',m_val(k),';',g(r,k)
END IF
END DO
END DOEND PROGRAM
!cccccccccc Random function generator
FUNCTION XRAND(IDUM)
INTEGER IDUM
REAL XRAND
INTEGER, PARAMETER :: IM1=2147413563, IM2=2147413399, IMM1=IM1-1
INTEGER, PARAMETER :: IA1=40014,IA2=40692,IQ1=53661,IQ2=52774,IR1=12211,IR2=3791,NTAB=32,NDIV=1+IMM1/NTAB
REAL, PARAMETER :: AM=1./IM1,EPS=1.2E-7,RNMX=1.-EPS
INTEGER IDUM2,J,K,IV(NTAB),IY
SAVE IV,IY,IDUM2
DATA IDUM2/123456719/,IV/NTAB*0/,IY/0/
IF (IDUM .LE. 0)THEN
IDUM=MAX(-IDUM,1)
IDUM2=IDUM
DO J=NTAB+1,1,-1
K=IDUM/IQ1
IDUM=IA1*(IDUM-K*IQ1)-K*IR1
IF(IDUM .LT. 0)IDUM=IDUM+IM1
IF(J .LE. NTAB)IV(J)=IDUM
END DO
IY=IV(1)
END IF
K=IDUM/IQ1
K=IDUM2/IQ2
IDUM2=IA2*(IDUM2-K*IQ2)-K*IR2
IF(IDUM2 .LT. 0)IDUM2=IDUM2+IM2
J= 1 + IY/NDIV
IY=IV(J)-IDUM2
IV(J)=IDUM
IF(IY .LT. 1)IY=IY+IMM1 XRAND=MIN(AM*IY,RNMX)
RETURN
END
[/CODE]
UFSJ said:
Hi guys.
I have tried to simulate the magnetic behavior of a bulk perovskite by Monte Carlo method through the Wang-Landau algorithm. I have used the JDoS description of the phase space. By a reference article the magnetic system can be described by the hamiltonian:
Hi Professor, it looks like your post got cut off. Can you try again?
Thank by the alert. And now, still cut off?
Nope, looks fine now. :smile:
