More projectile motion difficulties
4 replies · 3K views
billieluv
A soccer ball is kicked with a speed of 7.50 m/s at an angle of 30.0° above the horizontal. If the ball lands at the same level from which it was kicked, how long was it in the air? (Neglect air resistance.)
I really don't know where to start, all of the equations are confusing me.
This question is quadratic. What you need to find is how long the ball was in the air from when Vy=initial to Vy = 0. Your acceleration should be -9.80 m/s/. Finding the time, or the y-max (maximum height) will give you more insight as to how to solve the problem.
Vf = Vt + a(dt)? try it!
Sorry, how do I get y-max. I can't even begin to fill in this equation because I have only the acceleration
Okay. Vf = 0 (since it only goes so high if it's kicked), and Vi = 7.50 m/s. You can use deltaY= Vi(t)+1/2at^2, where your a = -9.80 m/s. Solve using the quadratic formula for t. Once you get t, you can multiply t by 2 since it takes the same amount of time for the ball to fall downward as it does going upward.
oh, wait. no. Get your Dy, by drawing a straight line through the middle of the pathway of the ball. use trigonometry to calculate the y part of the right triangle to get your Vi. then use the Vf=0, and then sub it into the equation to get t.
