Motion equations of a disc rotating freely around its center (3d)
The discussion focuses on the motion equations of a disc rotating freely around its center, constrained at the origin with weights that can be added to induce tilt. The primary equations of interest are dω⃗/dt = f(t,ω,θ) and dθ⃗/dt = ω⃗, with initial conditions ω⃗(t0) = ω⃗0 and θ⃗(t0) = θ⃗0. The user seeks to separate the vectorial equations into linear equations to facilitate simulation using the Runge-Kutta integration method. The z-component of momentum is established as zero due to the nature of the forces involved.
  • Understanding of rotational dynamics and angular momentum
  • Familiarity with vector calculus and differential equations
  • Knowledge of the Runge-Kutta integration method
  • Basic principles of Lagrangian mechanics
  • Research the separation of vectorial equations in rotational dynamics
  • Study the application of the Runge-Kutta method for simulating dynamic systems
  • Explore Lagrangian mechanics and the Euler-Lagrange equation in detail
  • Investigate coordinate systems for analyzing motion in rotating frames
Students and professionals in physics, particularly those studying dynamics and rotational motion, as well as engineers working on simulation models involving rotating systems.
bluekuma
The system is made of a disc the center of which is pinned to the origin (so the disc cannot translate), and some weights that can be stuck on the disc to make it tilt (weights do not translate on the disc) (see images attached).
There is no friction whatsoever. The only force is gravitational force, with direction opposite to the z-axis'.
Let's start with the disc at rest with its axis parallel to axis z. Now, if you put a weight on it, the disc starts oscillating just as if it was a pendulum. Then, at time t=t0, you put another weight on it.
If ω⃗ is the rotational speed vector and θ⃗ is the rotation vector of the disc (meaning the direction of the disc's axis is always the z-versor rotated by θ radians around θ⃗ ) what's the expression of f⃗ (t,ω,θ) in:
dω⃗ /dt = f(t,ω,θ),
dθ⃗ /dt = ω⃗
Given the initial values ω⃗ (t0) =ω⃗0≠0 and θ⃗ (t0=θ⃗0≠0, dω⃗ (t0)/dt≠0,
that would give me a way to simulate the system's motion through a standard Runge-Kutta integration method.
MIGHT HELP TO KNOW:
- I'm pretty sure there is a way to divide the two vectorial equations in six (three systems of two) linear equations
- z-component of momentum M⃗ (where dω⃗ /dt = M⃗ /I ) is always 0 (zero) as M is the result of a cross product between a vector r (x, y, x) and the gravitational force (0, 0, -mg), therefore z-component of ω⃗ and θ⃗ are also 0.
d\vec{ω}/dt = \vec{M}/I
where \vec{M} is the momentum and I the moment of inertia.
ehr...i'm actively looking for a system of coordinates in which the vectorial equations can be separated in three linear equations, that would solve my problem. Obviously I had no success so far.
I tried with Lagrangian and Euler-Lagrange equation but I really don't know where to start writing kinetic and potential energies in cartesian or spherical coordinates.
I tried with a coordinate system that moves together with the disc (longitudinal and vertical axis, as it is usually done when studying motion of airplanes). There I'd have that the weights are still but force of gravity keeps changing its direction, that only adds to the confusion.
Any idea?
