Motion Homework -- A particle moving along the x-axis....
The position function of a particle moving along the x-axis is defined as x(t) = 6.00 - 7.00t². To determine when the particle momentarily stops, the velocity function v(t) must be calculated and set to zero. The equation for the position at the origin is solved as 0 = 6 - 7t², yielding two time values: one positive and one negative. The correct interpretation of the variables and clear delineation of problem parts are essential for accurate solutions.
  • Understanding of quadratic equations
  • Knowledge of calculus concepts, specifically derivatives
  • Familiarity with motion equations in physics
  • Ability to solve for variables in algebraic equations
  • Calculate the velocity function v(t) from the position function x(t)
  • Learn how to apply the quadratic formula to solve for time in motion problems
  • Explore the concept of instantaneous velocity and its significance in particle motion
  • Study the implications of negative time in physical scenarios
Students studying physics, particularly those focusing on kinematics, as well as educators seeking to clarify motion equations and their applications.
fahadff
The position function x(t) of a particle moving along an x axis is x = 6.00 - 7.00t2, with x in meters and t in seconds.
(a)[/B] At what time and
(b) where does the particle (momentarily) stop? At what
(c) negative time and
(d) positive time does the particle pass through the origin?
0= 6.00-7.00x^2
x=0.925
0= 6.00-7.00x^2
x=0.925
You have mixed up your variables. The equation is ##x = 6 - 7t^2##, so when the position x is 0, the equation becomes ##0 = 6 - 7t^2##. When you solve this equation, you get two values of t. One of them is positive and one is negative. These will be the answers to parts c and d.
For parts a and b, you need to calculate the velocity, v(t), and determine at what time(s) it is zero.
You should also state clearly, which part of the problem you are trying to solve with each set of equations you present in your work.
  • · Replies 20 ·
  • · Replies 16 ·
