How Do You Calculate Time Ratios in Motion with Drag Force?
The discussion focuses on calculating time ratios in motion under the influence of drag force, specifically using the equation F = -k(dx/dt). The derived equations include mx'' = -kx' and the position function x(t) = A + B exp(-kt/m), leading to the velocity function v(t) = u exp(-kt/m). The user successfully integrates to find the distance L in terms of time t, expressed as L = mu/k (1 - exp(-kt/m)), but encounters difficulty in determining the ratio t2/t4 from the distances L/2 and L/4.
  • Understanding of differential equations and their applications in physics
  • Familiarity with concepts of drag force and motion
  • Knowledge of integration techniques in calculus
  • Proficiency in interpreting exponential decay functions
  • Study the derivation of time ratios in motion with drag force
  • Explore advanced integration techniques for solving motion equations
  • Learn about the implications of exponential decay in physical systems
  • Investigate the relationship between distance and time in non-linear motion
Physics students, engineers, and anyone interested in the dynamics of motion with drag force, particularly those working on problems involving differential equations and integration in motion analysis.
tanaygupta2000
At t=0, a particle of mass m having velocity u starts moving through a liquid kept in a horizontal tube and experiences a drag force F = -kdx/dt. It covers a distance L before coming to rest. If the times taken to cover the distances L/2 and L/4 are t2 and t4 respectively, then the ratio t2/t4 (ignoring gravity) is ?
F = -kdx/dt
Since given F = -kdx/dt
so I equated mx'' = -kx'
which gave x(t) = A + B exp(-kt/m)
hence v(t) = (-kB/m) exp(-kt/m)
and using v(0) = u, v(t) = u exp(-kt/m)
then I integrated dx = v(t)dt, dx from 0 to L and v(t)dt from 0 to t to find the distance covered L in terms of time taken t.
From this I got L = mu/k (1 - exp(-kt/m) )
Then I substituted L/2 = mu/k (1 - exp(-kt2/m) )
and L/4 = mu/k (1 - exp(-kt4/m) )
Now after this, I'm not getting how to find the ratio t2/t4 from the last two expressions of L/2 and L/4.
If it ultimately travels a distance L, then at infinite time, x = L
You are in danger of confusing yourself by using the same symbol, L, for both the given distance covered at t=∞ and the distance covered at some arbitrary time t.
  • · Replies 27 ·
  • · Replies 36 ·
