Motion (Newton's 2nd law + weight question)
In summary, a waterskier of mass 70 kg is being towed by a speedboat with a mass of 350 kg. The tension in the rope towing the waterskier is 380N north and the thrust force applied to the boat due to the action of the motor is 600N. When analyzing the problem, the mass of the boat and skier are treated as separate objects, but when considering the system as a whole, their combined mass is 420kg. A free body diagram is a helpful tool for visualizing the forces acting on a system.
rudders93
46
[SOLVED] Motion (Newton's 2nd law + weight question)
A waterskier of mass 70 kg is towed in a northerly direction by a speedboat with a mass of 350 kg. The frictional forces opposing the forward motion of the waterskier total 240 N.
(a) If the waterskier has an acceleration of 2.0 m due north, what is the tension in the rope towing the waterskier?
(b) If the frictional forces opposing the forward motion of the speedboat total 600 N, what is the thrust force applied to the boat due to the action of the motor?
2. The attempt at a solution
I answered a) correctly getting the tension as 380N north. For part b) though I got the answer wrong. According to the solutions it says that the mass used in for Fnet = ma is 350kg. Why? Doesn't the boat also pull the skier? So the net weight it 420kg? I'm confused as to why they used 350kg rather than 420kg. Same with part a), although I got it correct, looking back I'm not sure why 70kg is used rather than the combined mass of 420kg.
So, in problems with two objects connected by a string, why is the mass of an object ONLY it's mass rather than the added mass of both, because isn't the mass pulled by the object the overall mass of the pair?
Sorry if I'm not clear :(
Thanks!
Have you drawn out your FBDs? For a) you should only have 1 FBD, and for b) you should again only have 1 FBD.
If you haven't, that should answer your question concerning which mass to choose and why its not both.
EDIT: It depends on how you analyze the problem, and to find the tension in the rope, you need to separate it into two systems and analyze it from one.
Sorry, but what's an FBD?
free body diagram.
If you are unsure of what that is, it is a diagram that shows the system you are analyzing as a point particle (a dot or circle or what not on your paper) and you draw in the forces.
So for a, you could draw a small circle labeled Ws for waterskier and draw a vector upwards labeled T for tension and a vector downwards labeled f for friction as those are the only two forces acting on the skier. Sum of F=ma. Since your only mass in your system is the skier, it is only 70kg. The tension accounts for the mass/forces on the boat.
Ah yes. Solved my problem. So they are essentially separate objects (in terms of mass), except for the tension between them?
I think it all has to do with how you analyed it. Say the motorboat dies. And a tug boat comes by and offers to tow the motorboat and the skier too, just how they were.
And you wanted to find the Tension in THAT rope (between the motorboat and the tug, so you still have the skier being towed by the motorboat).. Well you could analyze it as the tug boat of mass 1000kg and motorboat/waterskier 420kg with tension T between them..
So it just depends on how you look at it and need to analyze it. The motor boat is definately pulling the weight of the boat and skier, against frictional forces on the boat and the skier, but to analyze it, we split them up, but as a whole system, the mass is 420kg.
1. What is Newton's 2nd law of motion?
Newton's 2nd law of motion states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. In simpler terms, the greater the force applied to an object, the greater its acceleration will be, and the more massive an object is, the less it will accelerate for a given force.
2. How is Newton's 2nd law related to weight?
Newtons's 2nd law is related to weight because weight is a force that is exerted on an object due to the Earth's gravitational pull. According to the law, the greater the weight of an object, the greater the force it exerts on the ground or surface it is resting on.
3. How do you calculate force using Newton's 2nd law?
According to Newton's 2nd law, force (F) is equal to mass (m) multiplied by acceleration (a). This can be represented by the formula F=ma, where F is in Newtons (N), m is in kilograms (kg), and a is in meters per second squared (m/s²).
4. How does Newton's 2nd law apply to real-life situations?
Newton's 2nd law can be seen in many real-life situations, such as when a car accelerates or stops, when a ball is thrown or kicked, or when a person jumps. In all of these situations, the force applied determines the acceleration of the object.
5. How does Newton's 2nd law affect the motion of objects in different environments?
Newton's 2nd law applies to the motion of objects in all environments, as long as there is a net force acting on the object. However, factors such as air resistance, friction, and buoyancy may affect the acceleration of the object and must be taken into consideration when calculating the force.
