Solve Motional EMF Problem: Total Resistance, V(ind), I(ind), and Fnet Explained
  • Thread starter Thread starter SpectraPhy09
    Emf Motional emf
The discussion focuses on solving the motional electromotive force (EMF) problem involving total resistance, induced voltage (V(ind)), induced current (I(ind)), and net force (Fnet). The equations presented include total resistance as R + 2λx, V(ind) as vBd, and I(ind) as vBd/(R + 2λx). The participants clarify the correct formulation of the net force, concluding that the applied force F is represented as F = iBd + 2λi²m(R+2λx)/B²d², correcting earlier misconceptions about the signs in the equations.
  • Understanding of electromotive force (EMF) principles
  • Familiarity with Lenz's law and its implications on force direction
  • Knowledge of basic mechanics, particularly Newton's laws
  • Ability to manipulate algebraic equations involving forces and currents
  • Study the principles of Lenz's law in depth
  • Learn about the relationship between current, magnetic fields, and forces in electromagnetic systems
  • Explore advanced topics in electromagnetism, such as Faraday's law of induction
  • Investigate the applications of motional EMF in real-world scenarios, such as electric generators
Physics students, electrical engineers, and anyone interested in understanding the dynamics of motional EMF and its applications in electromagnetic systems.
SpectraPhy09
Two long Horizontal rails, a distance d apart and each having a resistanc λ per unit length are joined one end by a resistance R. A perfectly conducting rod MN of mass m is free to slide along the rails without friction v(I have attached the file for the diagram plz check) . There is a uniform magnetic field of induction B Normal to the plane of the paper and directed into the paper. Variable Force F is applied to the rod MN such that, as the rod moves, a constant current i and flows through R.
(i) Find the applied force F as function of distance x of the rod from R.
Force due to a current carrying wire = iBl
Where i = current
B = Magnetic field
L = length of the wire
E.M.F induced due to a rod of length l moving with Velocity V in Magnetic field B = VBl
Its applicable only when V, B and I are mutually perpendicular to each other
I request please go through my solution
Total Resistance = R + 2λx
V(ind) = vBd
I(ind)= vBd/(R + 2λx )
v = i(R + 2λx )/Bd
If force on the wire due to induced current is iBl then
Fnet = iBd - F ...(i)
or Fnet = F - iBd ...(ii)
Fnet = v(dv/dx)
v(dv/dx) = iBd - F
By solving we get
Fnet by (i) is iBd - 2λi²m(R+2λx)/B²d²
(ii)is 2λi²m(R+2λx)/B²d² - iBd
Which one of this is correct ? Or both are correct ? Did I made any mistake in the solution
Hello @SpectraPhy09,
:welcome: ##\qquad## !​
I have attached the file for the diagram please check
I checked -- didn't see a thing !
What I see is two answers, one the opposite of the other ?
I don't see the file for the diagram that you said you attached. It's not clear in which direction the rod is being pushed.
SpectraPhy09 said:
Fnet = v(dv/dx)
v(dv/dx) = iBd - F
Should the mass of the rod appear somewhere in the equations above?
SpectraPhy09 said:
By solving we get
Do these expressions represent Fnet or the applied force F?
I'm really sorry there's a mistake in my soln
Ya m should appear, i.e Fnet = mv(dv/dx)
mv(dv/dx) = iBd - F
The force Is not Fnet it is the applied Varying force F
i.e. F = iBd - 2λi²m(R+2λx)/B²d². ...(i)
Or. F = 2λi²m(R+2λx)/B²d² - iBd ...(ii)
My doubt was which of the equation among (i) or (ii) is correct ?
Or both are correct ? I have attached the figure please check
SpectraPhy09 said:
mv(dv/dx) = iBd - F
Hi @SpectraPhy09. Both equations can't be correct. For example -5 is not equal to +5. In fact neither equation is correct! See if this helps.
We are taking +x as being ’to the right’. And from the question we deduce the rod moves to the right.
In 1-dimension, vectors in the positive direction are represented positive values and vectors in the negative direction by negative values
The applied force, F, acts to the right (given in diagram) so it is represented by a positive value.
As the rod moves right, its (positive) velocity must increase to keep the current constant. (Why?) So the direction of acceleration is to the right. Therefore the direction of the net force is to the right. So the net force is represented by a positive value.
The ‘back-force’ has magnitude = iBd and acts to the left (from Lenz’s law). So we assign it the value -iBd.
We are adding two forces by vector addition:
##\overrightarrow {net force} = \overrightarrow {applied force} + \overrightarrow {back force}##
which in 1-dimension gives
##F_{net} = F + (-iBd)##
Does that make sense?
Neither of your answers:
are correct. But you are very close!
@Steve4Physics
Oh is there a +ve instead of -ve ..?
SpectraPhy09 said:
@Steve4Physics
Yes, that's what I get too. Well done!
  • · Replies 22 ·
  • · Replies 17 ·
20K
