Motorboat Ques: Gelfand Algebra 131 | Hints to Help
  • Thread starter Thread starter user10921
    Algebra
The discussion revolves around a problem from Gelfand's Algebra concerning the motion of a motorboat in a river, focusing on the relationship between the speeds of the boat and the river current, as well as the distances and times involved in traveling between two points.
  • Participants discuss defining variables for the speeds of the boat and river, and setting up equations to describe the motion. There is an exploration of manipulating these equations to isolate variables and clarify relationships. Some participants express confusion regarding the notation used for distance.
Participants are actively engaging with the problem, attempting to derive equations and clarify definitions. There is recognition of potential confusion regarding the notation for distance, suggesting a need for clearer variable definitions. No consensus has been reached on the best approach yet.
There is a mention of the original poster seeking hints rather than complete solutions, indicating a focus on guidance through the problem-solving process. The discussion also highlights a potential misunderstanding of the distance variable used in the equations.
user10921
A motorboat needs a hours to go from A to B down the river and needs b hours to go from B to A(up the river). How many hours would it need to go from A to B if there were no current in the river?
$$vb_r question mark?$$
I am struggling on how to approach this problem. Hints would help greatly. This is also from Gelfand's Algebra problem 131
The motorboat has an intrinsic speed with respect to the water. The water has a speed downstream. Those speeds add in the downstream direction and subtract in the upstream direction.
Define variables for those two speeds and write some equations describing what is going on. Please show that work. Thank you.
let $$v_r$$ be the river water speed and $$v_b$$ the boat speed and
let's let AB be the distance between A and B
when going down the river, the speed is $$v_b+v_r$$ and the duration is a, so the equation is
$$a=\dfrac{AB}{v_b+v_r}$$
similarly:
$$b=\dfrac{AB}{v_b-v_r}$$
What we're looking for is
$$x=\dfrac{AB}{v_b}$$
So we have to manipulate the equation to get rid of the $$v_r$$ out of the expression
So once you manipulate the equation, you get $$v_b+v_r=\dfrac{AB}{a}$$ and $$v_b-v_r=\dfrac{AB}{b}$$
Using system of equations you add the two and you get
$$2v_b=AB\left(\dfrac{1}{a}+\dfrac{1}{b}\right)$$
and divide by two on each side and you're left with that. Thank you for helping
user10921 said:
so the equation is $$a=\dfrac{AB}{v_b+v_r}$$
user10921 said:
...and you get $$2v_b=AB\left(\dfrac{1}{a}+\dfrac{1}{b}\right)$$
These equations are a little confusing, as I originally thought that ##AB## was the product of A and B, the labels for the two points on the river. Instead, I think your intent is that ##AB## represents the distance from point A to point B. It would be clearer to define a new variable, say d, that represents the distance from A to B.
That doesn't tell you how long it takes.
  • · Replies 17 ·
  • · Replies 20 ·
10K
  • · Replies 38 ·
13K
