Mount Rack & Pinion Interference in PTC Creo | Avoidance & Solutions
Mounting a rack and pinion in PTC Creo is causing interference issues, particularly when the pinion is positioned at the calculated pitch diameter. The pinion's pitch diameter is 24 mm with a modulus of 2, but placing it directly above the rack leads to misalignment and timing problems. Increasing the mount height slightly alleviates interference but worsens timing discrepancies. The discussion raises concerns about the implications of mounting the pinion slightly off from the gear, especially for a feeding mechanism involving disposable components. Overall, precise alignment is crucial for proper functionality in CAD modeling.
Chevreuil
Hello,
I have downloaded CAD models of a rack and pinion, and I don't seem to be able to mount them up in PTC Creo without quite obvious interference.
The pinion has a pitch diameter of 24 mm, and a modulus 2. The "pitch diameter" of the rack is exactly one modulus lower than the tip of the cogs on the rack. The modulus is, of course, 2 mm. Measurements on the CAD-models suggest that I haven't had a mixup of some kind.
In Creo, if I mount the pinion exactly 12 mm above the "pitch diameter" of the rack, it's quickly obvious that something is wrong. If I put a cog from the pinion facing straight down between two cogs of the rack, I get interference on both sides. If I rotate the pinion, after a few turns, the timing between the rack and the pinion is off. Why is this? Creo says that it is moving the rack pi*24mm per turn of the pinion, and I can't believe that Creo could mess that up. Have I done something wrong?
Increasing the mount height if the pinion to 12.5 mm, everything looks a lot better. The timing problem is still weird, though.
A) Why is this such a mystery?
B) Is it horrible to mount a pinion slightly off from a gear? This is for a feeding mechanism of a disposable item. The pinion stays in the machine, but the rack is supposed to be soft plastic, and it is discarded after it has passed the pinion.
Oh, sorry, nomenclature error, I meant the distance from the tip of the cog to the pitch line, which according to the roymech document is 1*module.
Pinion
20012-N20 from this site
http://www.mekanex.se/produkter/komponenter/kugghjul/cylindriska-kugghjul/
If you have trouble navigating and you are brave enough, use this direct link to zipped proE file.
http://old.solidcomponents.com/company/out/4103919/20012-N20_Mekanex.zip
Rack
K200500 from this site
http://www.mekanex.se/produkter/komponenter/kuggstanger/
zipped .prt
http://old.solidcomponents.com/company/out/4103932/K200500P_Mekanex.zip
I'm having problems downloading those files . If you still want some help send me your drawings directly . Any common CAD file format is ok .
See conversation for my Email address .
Thank you!
I have sent the original .prt files from the Mekanex source. Mounting them so that the pitch diameter of the pinion is in contact with the "pitch diameter" of the rack (which is exactly 1 module from the tip of the cogs of the rack) give me serious interference issues. I also have trouble getting the translation of the rack right in Creo.
If I increase the mounting distance by half a module I get rid of the interference, but this sloppy solution messes up the timing even more.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
