Multi-Phase Circuit Modification Help Needed
  • Thread starter Thread starter Bowl
    Circuit
The discussion focuses on modifying a circuit to operate three parallel wires in sequence using MOSFETs triggered by a feedback coil. The goal is to create a synchronized pathway where each coil turns off and repels the next coil in line, ultimately closing the circuit with a battery. Participants compare this setup to a three-phase inverter and discuss the challenges of sequencing MOSFETs with a flyback transformer. Suggestions include using a current sense transformer to signal when the magnetic field collapses, which could help control the next MOSFET in the sequence. The conversation emphasizes the complexity of the task while exploring potential solutions.
Bowl
Hi People!
I need some help to modify the following circuit to run current trougth three parallel wires in sequence, using three mosfets triggered by one feedback coil.My goal is to obtain a syncronized patway in a manner that when the first coil is shut OFF,the reversing field of the coil have to repel aganist the field of the next coil that is still in the ON phase.Then the second coil is shut off and will repel with the third coil.The last coil (third) will repel aganist a fourth coil that is connected to the ends of all the previous coils to close the circuit with the battery. All these steps have to be done ciclically.It can be done in a simple way?Thank you!
Kind of like a three phase inverter? I am not quite clear on what your trying to do, what is this for?
Yeah,its like a three phase inverter. I want to run a self resonant flyback transformer and with the output turn off the gate of other two mosfet,in sequence. Some one has said to me that running in sequence three mosfet with a fwith flybeack is non easy,but I don't believe in...
Hmm, my first instinct would tell me to use a current sense transformer on the gnd. side of the flyback to signal when the field has collapsed, perhaps use this signal to control a mosfet driver for the next transformer in line. Am I on the right track here?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
