Multi-Stage Pump: Understanding Flow Rate & Head
  • Thread starter Thread starter ron_adigross
    Pump
The discussion focuses on the mechanics of multi-stage centrifugal pumps, specifically how multiple impellers affect flow rate and head. It is established that while the flow rate remains consistent from impeller to impeller, the head increases with each additional impeller. Minor increases in flow capacity may occur at each stage to compensate for losses due to backward leakage across the hub and eye rings of the previous impeller, but these are negligible.
  • Understanding of multi-stage centrifugal pump design
  • Knowledge of fluid dynamics principles
  • Familiarity with pump performance metrics such as flow rate and head
  • Basic concepts of hydraulic losses in pumping systems
  • Research the design and operation of multi-stage centrifugal pumps
  • Learn about hydraulic losses and their impact on pump efficiency
  • Explore performance curves for multi-stage pumps
  • Investigate comparison between multi-stage pumps and multi-stage turbines
Engineers, pump system designers, and anyone involved in fluid mechanics or pump performance optimization will benefit from this discussion.
ron_adigross
Hello.
I try to understand how multi stage pump (few impellers in a row) influence on
flow rate and head.
Thanks
There's often something in between, Compare with multi stage turbine
Complex question. In general multi stage centrifugal pumps have the same flow rate impeller to impeller, but head increases impeller to impeller. Some increase in flow capacity is sometimes included at each stage to account for losses (like backwards leakage across the hub ring and the eye ring of the previous impeller), but those are very minor.
  • · Replies 38 ·
