Calculating Minimum Angle in Multiple-Slit Interference
  • Thread starter Thread starter robera1
    Interference
To determine the minimum angle in a five-slit interference pattern, the formula dsin(θ) = mλ is used, where d is the distance between slits, λ is the wavelength, and m is the order of the minimum. In this case, the distance between adjacent slits is given as 125λ. For the first minimum, m is set to 1/2, leading to the equation 125λsin(θ) = (1/2)λ. After simplifying, the angle θ is calculated to be approximately 0.23 degrees. This approach effectively solves the problem using the correct formula and parameters.
robera1
"If the distance between the centers of adjacent slits in the five-slit mask is 125[lambda], determine the angle (measured relative to the normal to the screen) to the minimum closest to the center of the screen."
So, I have a question about the homework due tomorrow.
Here is the question:
So, do I use dsin[theta] = m[lambda]?
Where d would be, well, I am not sure,
Theta is what I'd be solving for,
m would be 0.5 (I think, but not sure since there are 5 slits)
and lambda would be 125
Is this right, or totally wrong?
Correct formula. "d" is the distance between slits, so replace it with 125*L
(I'm writing L instead of lambda). That gives you
125*L*sin(A) = m*L
For the first minimum, m = 1/2.
The L cancels, so you can find A.
Okay, so theta = 0.23 degrees?
Yes, that's it.
Awesome! Thanks :D
9K
