Multiplication=addition 2*2=2+2=4
  • Context: Undergrad
  • Thread starter Thread starter MathematicalPhysicist
The discussion centers on the equation xy = x + y, exploring the conditions under which multiplication yields the same result as addition. Participants established that for real numbers, there are infinite pairs (x, y) satisfying this equation, specifically y = x / (x - 1) for x ≠ 1. However, when restricted to integers, the only solutions are (0, 0) and (2, 2). The conversation highlights the importance of distinguishing between real numbers and integers in number theory.
  • Understanding of basic algebraic equations
  • Familiarity with number theory concepts
  • Knowledge of Diophantine equations
  • Ability to manipulate and rearrange equations
  • Research Diophantine equations and their solutions
  • Study the properties of integer solutions in number theory
  • Explore the implications of the equation xy = x + y in different number sets
  • Learn about the significance of unique factorization in integers
Mathematicians, students of number theory, and anyone interested in the relationships between multiplication and addition in various number systems.
i think everyone is familiar to this but i wonder if someone has made his research to study it.
what i mean is the namubers that when the result of multiplying them together is the same as adding them:
for example:
2*2=2+2=4 (trivial, i know (-: ).
3*1.5=3+1.5=4.5
my question has someone prooved that the number of these pairs are finite or infinite in the real numbers?
xy=x+y
rearrange and solve for R.
for N (well, this is the number theory thread)
xy-x-y+1=1
(x-1)(y-1)=1
in N x=y=2
Perhaps I'm misunderstanding something... You want real solutions to this equation:
x + y = xy
y = x / (x - 1)
I.e, for any x != 1 we can chose a y so that x + y = xy, namely y = x / (x - 1). Any real x (except for x = 1) will give a real y, so there are an infinite number of such pairs...
A more interesting question would be to consider only integers...
x + y = xy
y = x / (x - 1)
i didnt think about it very much so perhaps from this had risen the misunderstanding.
i guess in the real numbers is really trivial.
so let's say just prooving for integers how do you go around prooving this?
[x,y]=[Z] or [x,x/(x-1)]=[Z]
I have no idea what this means. matt grime provided an answer for what happens if you only consider the natural numbers (i.e, x = y = 2 is the only solution).
z doesn't represent the integers?
Aha, yes it does, but you used the equals sign (and non-curly braces), and I've never seen = used to specify membership in a set (
seems to be more commonly used).
For \frac{x}{x-1} to be an integer, x-1 must dividex. Since the difference between the two is 1, their greatest common factor is 1, so the only solutions are x-1=1 and x-1=-1 (2+2=2*2 and 0+0=0*0).
NateG, you should state you are only working in N there, by saying integer you implying Z. In Z, there are other answers. All we know is that here (x-1) is a unit, hence x-1=-1 or 1, yielding the other integer answer of x=y=0 as well as x=y=2
For \frac{x}{x-1} to be an integer |x-1| must divide |x|. The GCF of the two absolute values is 1 (by Euclid's algorithm). Therefore |x-1| \leq 1 since it divides |x| and obviously divides itself. For x \in \mathbb{Z} that leaves three solutions: 0,1, and 2, but 1 leads to division by zero, so the only solutions are x=0 and x=2.
P.S. My apologies for the mixed formatting
forget that last post if you saw it, i absolutely apoligize, i misread your post.
Don't sweat it, I've posted some beauties myself. I should be less adverserial in my response though. ;)
Integer solutions of xy = x + y where x,y \epsilon Z
xy - x - y = 0
(x-1)(y-1) = 1
let x' = x -1 and y' = y - 1 so x',y' \epsilon Z
So x' = 1 / y'
The only integers whose reciprocals are also integers are 1 and -1
So y' = 1 and x' = 1
So y = 2 and x = 2
AND
So y' = -1 and x' = -1
So y = 0 and x = 0
Therefore there are only two solutions to this diophantine equation x = y = 2 and x = y = 0
  • · Replies 0 ·
  • · Replies 17 ·
9K
  • · Replies 26 ·
