Multiplication of infinity and zero
The discussion centers on the mathematical concept of multiplying infinity by zero, which is classified as an indeterminate form. Participants emphasize that infinity is not a number but a concept, making the multiplication of infinity and zero nonsensical in standard arithmetic. They highlight that while limits involving these terms can yield finite results, the product itself does not have a defined value. The conversation also touches on different number systems, such as cardinal numbers, where the rules for multiplication differ.
  • Understanding of mathematical concepts such as limits and indeterminate forms.
  • Familiarity with number systems, including real numbers and cardinal numbers.
  • Basic knowledge of calculus and its applications.
  • Awareness of the properties of infinity in mathematical contexts.
  • Study the concept of indeterminate forms in calculus.
  • Learn about the properties of extended real numbers and their arithmetic.
  • Explore cardinal numbers and their applications in set theory.
  • Research the implications of limits involving infinity in mathematical analysis.
This discussion is beneficial for mathematicians, students of calculus, and anyone interested in advanced mathematical concepts, particularly those dealing with limits and the nature of infinity.
samieee
What will happen if we multiply infinity with zero? how to describe this situation?
Mathematics news on Phys.org
Nothing happens, because we don't do that.
In fact, you can't multiply "infinity" with anything at all, because it's not a number. It's just a mathematical concept that we "invented" because it is convenient.
Just in case you made that question because you were evaluating some function, you might want to remember that \infty\cdot 0 is an http://en.wikipedia.org/wiki/Indeterminate_form" .
The limit of the function to that point might still exist and be finite.
It depends on the number system, of course.
However, in all commonly used number systems that have a number called "infinity" and a number called "zero" and a product, one is not allowed to multiply infinity by zero -- so talking about the result of that product is in the same class of nonsense as other English questions like "How much does blue weigh?"
[offtopic]
About 4.5 x 10-36 kg (taking 475 nm for the wavelength).[/size]
[/offtopic]
[offtopic]
Right on!
However, that is only the effective relativistic mass (E/c^2) of one blue photon. The concept "blue" doesn't depend on the number of blue photons, so Hurkyl was right that it doesn't make sense :smile:
[/offtopic]
when you say zero it means nothing (does not exist). if you multiply how many ever times of some thing which is not existing, it will be still nothing (zero).
That is true (and intuitive) only if you multiply a finite number with zero.
You are not necessarily allowed to treat \infty as a simple finite number, otherwise you are basically suggesting that \infty \cdot 0 = 0 is always valid, which is not true.
Mmm..nope.
Consider the following example:
x*(1/x)=1, irrespective of the (non-zero) value of x.
As you let "x" go to infinity, the first factor goes to infinity, whereas the second to 0.
Yet the product equals 1, nonetheless..:smile:
but still (1/x) is not zero. regardless of x value. it could be negligible but it is not zero.
arildno said:
Mmm..nope.
And if you do that, you can also consider
x*(2/x) = 2
x*((-1/12)/x) = -1/12
x*(a/x) = a for all numbers a
and thus "show" that 0 \cdot \infty is equal to any number you please. Which leads to a contradiction (of course, we want a multiplication between two numbers to always give the same result).
Huh? What does this have to do with anything? :confused:
You might have made sense if you were talking about cardinal numbers*... but there is no cardinal number called "infinity". However, each infinite cardinal \alpha does indeed have the property that \alpha 0 = 0.
But this is only for the cardinal number system, and has no bearing on what may be true, false, or nonsense in other number systems.
*: I find it unlikely this is what you were getting at, though -- I expect you didn't have any number system in mind, but instead a particular physical interpretation, and you were trying to apply that interpretation in a domain where it doesn't even apply. (i.e. it doesn't even make enough sense to ask if the interpretation is valid or invalid)
yes, Math is not my Domain. so you are saying zero is not a null value. please can you clarify why only with infinity we should not consider zero as a finite (Null) value. please if you can refer any book or link which can explain this it will be great because my mind is disturbing me.
Infinity is a red herring. It is a fact that zero is a null value for the operation of multiplication of real numbers. If you are interested in a different multiplication operation -- e.g. the multiplication of extended real numbers -- then anything could happen.
Most number systems have various motivations: the motivation of the arithmetic of extended real numbers is to be a continuous extension of arithmetic of real numbers. Multiplication cannot be continuously extended to 0 * +infinity or 0 * -infinity. Therefore, the arithmetic of extended real numbers is defined so that 0 * +infinity is nonsense.
Still i am not clear why they use infinite if it doesn't make sense. like if you divide still it is infinite. if you subtract still it is infinite. Any way Thank you for explaining. i will also study little bit on this for my curiosity to understand it.
Because it's useful.
The fact 0 * +infinity is nonsense does not diminish the utility of the extended real numbers for many tasks -- such as simplifying calculus. In fact, that 0 * +infinity is nonsense is actually a feature -- things would be very awkward if things were defined differently so that that product has a value.
And, just to reiterate the other point I've been trying to make, other number systems have their own considerations. For example, the cardinal numbers have to do with "counting" -- or more precisely of bijections between sets. The product of cardinal numbers relates directly to the Cartesian product of sets. 0x=0 is an identity of cardinal numbers, because \emptyset \times S = \emptyset is an identity of sets.
Not necessarily, at least in the context of indeterminate forms, which were mentioned elsewhere in this thread.
Several indeterminate forms involve infinity.
\left[\frac{\infty}{\infty}\right]
\left[\infty - \infty\right]
\left[1^{\infty}\right]
Keep in mind that these are only forms that are used to represent different limit types. They usually appear in brackets to emphasize the fact that they don't represent actual arithmetic problems. We're not actually going to try to carry out the division, subtraction, and so on.
For each one of these forms or categories, as many limit problems as you like can be found, each with a different limit that can be any arbitrary real number, as well as positive or negative infinity.
  • · Replies 40 ·
  • · Replies 19 ·
  • · Replies 30 ·
