Multiplication of infinity and zero
The discussion revolves around the implications of multiplying infinity by zero, exploring the mathematical and conceptual challenges associated with this operation. Participants address various contexts, including theoretical mathematics, limits, and the nature of infinity and zero in different number systems.
  • Some participants assert that multiplying infinity by zero is nonsensical, as infinity is not a number but a mathematical concept.
  • Others mention that \(\infty \cdot 0\) is classified as an indeterminate form, suggesting that limits approaching this product may yield finite results.
  • There are claims that the validity of multiplying infinity by zero depends on the number system in use, with some systems not allowing such multiplication.
  • One participant argues that treating infinity as a finite number leads to contradictions, as demonstrated through examples involving limits.
  • Another participant introduces the concept of cardinal numbers, noting that in that context, multiplying a cardinal number by zero yields zero.
  • Several participants express confusion about the utility of infinity in mathematics, questioning why it is used if it leads to nonsensical results in certain operations.
  • Some participants clarify that while zero is a null value in multiplication, the context of infinity complicates its interpretation.
  • Indeterminate forms are discussed, with examples provided to illustrate how they can lead to various limits, emphasizing that they do not represent actual arithmetic operations.
Participants do not reach a consensus on the implications of multiplying infinity by zero. Multiple competing views remain regarding the nature of infinity, the validity of the operation, and the contexts in which it may or may not make sense.
Limitations include the dependence on specific number systems and the unresolved nature of mathematical definitions related to infinity and zero. The discussion highlights the complexity of indeterminate forms and their implications in calculus.
samieee
What will happen if we multiply infinity with zero? how to describe this situation?
Mathematics news on Phys.org
Nothing happens, because we don't do that.
In fact, you can't multiply "infinity" with anything at all, because it's not a number. It's just a mathematical concept that we "invented" because it is convenient.
Just in case you made that question because you were evaluating some function, you might want to remember that [tex]\infty\cdot 0[/tex] is an http://en.wikipedia.org/wiki/Indeterminate_form" .
The limit of the function to that point might still exist and be finite.
It depends on the number system, of course.
However, in all commonly used number systems that have a number called "infinity" and a number called "zero" and a product, one is not allowed to multiply infinity by zero -- so talking about the result of that product is in the same class of nonsense as other English questions like "How much does blue weigh?"
[offtopic]
About 4.5 x 10-36 kg (taking 475 nm for the wavelength).[/size]
[/offtopic]
[offtopic]
Right on!
However, that is only the effective relativistic mass (E/c^2) of one blue photon. The concept "blue" doesn't depend on the number of blue photons, so Hurkyl was right that it doesn't make sense :smile:
[/offtopic]
when you say zero it means nothing (does not exist). if you multiply how many ever times of some thing which is not existing, it will be still nothing (zero).
That is true (and intuitive) only if you multiply a finite number with zero.
You are not necessarily allowed to treat [tex]\infty[/tex] as a simple finite number, otherwise you are basically suggesting that [tex]\infty \cdot 0 = 0[/tex] is always valid, which is not true.
Mmm..nope.
Consider the following example:
x*(1/x)=1, irrespective of the (non-zero) value of x.
As you let "x" go to infinity, the first factor goes to infinity, whereas the second to 0.
Yet the product equals 1, nonetheless..:smile:
but still (1/x) is not zero. regardless of x value. it could be negligible but it is not zero.
arildno said:
Mmm..nope.
And if you do that, you can also consider
x*(2/x) = 2
x*((-1/12)/x) = -1/12
x*(a/x) = a for all numbers a
and thus "show" that [itex]0 \cdot \infty[/itex] is equal to any number you please. Which leads to a contradiction (of course, we want a multiplication between two numbers to always give the same result).
Huh? What does this have to do with anything? :confused:
You might have made sense if you were talking about cardinal numbers*... but there is no cardinal number called "infinity". However, each infinite cardinal [itex]\alpha[/itex] does indeed have the property that [itex]\alpha 0 = 0[/itex].
But this is only for the cardinal number system, and has no bearing on what may be true, false, or nonsense in other number systems.
*: I find it unlikely this is what you were getting at, though -- I expect you didn't have any number system in mind, but instead a particular physical interpretation, and you were trying to apply that interpretation in a domain where it doesn't even apply. (i.e. it doesn't even make enough sense to ask if the interpretation is valid or invalid)
yes, Math is not my Domain. so you are saying zero is not a null value. please can you clarify why only with infinity we should not consider zero as a finite (Null) value. please if you can refer any book or link which can explain this it will be great because my mind is disturbing me.
Infinity is a red herring. It is a fact that zero is a null value for the operation of multiplication of real numbers. If you are interested in a different multiplication operation -- e.g. the multiplication of extended real numbers -- then anything could happen.
Most number systems have various motivations: the motivation of the arithmetic of extended real numbers is to be a continuous extension of arithmetic of real numbers. Multiplication cannot be continuously extended to 0 * +infinity or 0 * -infinity. Therefore, the arithmetic of extended real numbers is defined so that 0 * +infinity is nonsense.
Still i am not clear why they use infinite if it doesn't make sense. like if you divide still it is infinite. if you subtract still it is infinite. Any way Thank you for explaining. i will also study little bit on this for my curiosity to understand it.
Because it's useful.
The fact 0 * +infinity is nonsense does not diminish the utility of the extended real numbers for many tasks -- such as simplifying calculus. In fact, that 0 * +infinity is nonsense is actually a feature -- things would be very awkward if things were defined differently so that that product has a value.
And, just to reiterate the other point I've been trying to make, other number systems have their own considerations. For example, the cardinal numbers have to do with "counting" -- or more precisely of bijections between sets. The product of cardinal numbers relates directly to the Cartesian product of sets. 0x=0 is an identity of cardinal numbers, because [itex]\emptyset \times S = \emptyset[/itex] is an identity of sets.
Not necessarily, at least in the context of indeterminate forms, which were mentioned elsewhere in this thread.
Several indeterminate forms involve infinity.
[tex]\left[\frac{\infty}{\infty}\right][/tex]
[tex]\left[\infty - \infty\right][/tex]
[tex]\left[1^{\infty}\right][/tex]
Keep in mind that these are only forms that are used to represent different limit types. They usually appear in brackets to emphasize the fact that they don't represent actual arithmetic problems. We're not actually going to try to carry out the division, subtraction, and so on.
For each one of these forms or categories, as many limit problems as you like can be found, each with a different limit that can be any arbitrary real number, as well as positive or negative infinity.
  • · Replies 40 ·
  • · Replies 18 ·
  • · Replies 19 ·
