Multivariable Calculus: Conceptual Question on Total Change in a Function
  • Context: Graduate
  • Thread starter Thread starter cepheid
    Conceptual
The discussion centers on the misconceptions surrounding the total change in a multivariable function, specifically for the function z = f(x, y). The user initially attempts to extend single-variable calculus principles to multivariable calculus using tangent plane approximations, leading to incorrect conclusions about integrating partial derivatives independently. Key insights reveal that the total change in z cannot be computed by simply summing integrals of partial derivatives due to path dependency and the interrelation of variables. The correct approach involves recognizing that the differential dz must be integrated along a specific path in the plane, considering the relationship between x and y.
  • Understanding of single-variable calculus, including derivatives and integrals.
  • Familiarity with multivariable calculus concepts, particularly partial derivatives.
  • Knowledge of differential forms and their applications in calculus.
  • Basic comprehension of path integrals in multivariable functions.
  • Study the concept of total differential in multivariable calculus.
  • Learn about path integrals and their significance in evaluating multivariable functions.
  • Explore the relationship between partial derivatives and total derivatives in multivariable contexts.
  • Investigate conservative vector fields and their properties related to path independence.
Students and educators in mathematics, particularly those studying multivariable calculus, as well as researchers interested in advanced calculus concepts and applications.
cepheid
Staff Emeritus
Please don't laugh at the following: I am new to multivariable calculus, and just thought of this on the fly:
In single variable calculus, for a function y = f(x) we have the tangent line approximation:
\Delta y \approx \frac{df}{dx} \Delta x
The relation becomes exact in the limit:
dy = \frac{df}{dx} dx
So to find the total change in y over an interval [a,b] we just have:
\int dy = \int_{a}^{b} \frac{df}{dx} dx = \int_{a}^{b} f^{\prime} (x)dx
I hope that this reasoning is correct. Having assumed that it was, and being very naive, I tried to extend this result to the multivariable case using the tangent plane approximation. For a function z = f(x, y)[/tex]<br /> <br /> \Delta z \approx \frac{\partial f}{\partial x} \Delta x + \frac{\partial f}{\partial y} \Delta y<br /> <br /> In the limit:<br /> <br /> dz = \frac{\partial f}{\partial x} dx + \frac{\partial f}{\partial y} dy<br /> <br /> So I just assumed that for a change in x from a to b, and a change in y from c to d, the total change in z was given by:<br /> <br /> \int_{a}^{b} \frac{\partial f}{\partial x} dx + \int_{c}^{d} \frac{\partial f}{\partial y} dy<br /> <br /> = \int_{a}^{b} f_{x} (x,y) dx + \int_{c}^{d} f_{y} (x,y) dy<br /> <br /> Now, I know that this is <b>dead wrong</b>. I can think of a couple of reasons. For one thing, the curly d’s set off alarm bells: if f_{x} has y in it, then the first integral cannot be evaluated, and if f_{y} has x in it, then the second integral cannot be evaluated. Also, the region over which z is changing is limited to a rectangle. My question is: where did I go wrong in this line of reasoning? I have a vague inkling that the problem is that you cannot do it in two parts using the partials…you need something else to be the “whole” derivative of the multivariable function. My textbook says that the net change in a function z = f(x, y)[/tex] can be evaluated using a double integral, but I’m not sure how they factor in. To me, \iint seems to be something else entirely. I cannot relate it intuitively in my mind to the concept that I’m working with (which is: to get the net change in the function…multiply the infinitesimal change in the independent variable(s) by the infinitesimal rate of change of the function with respect to that variable, and integrate). I would appreciate any help with this.
The difficulty with what you are doing is that you are applying and integration with respect to x to one term and an integration with respect to y to the other. In other words, you are not "doing the same thing to both sides of the equation".
If, on the other hand, you intgrat dz = \frac{\partial f}{\partial x} dx + \frac{\partial f}{\partial y} dy along a given curve in the plane, then you do get a valid answer.
"along a given curve in the plane"? An example would be very helpful.
halls of ivys point is that in the plane you cannot integrate only in the x or y directions but must integrate in a slanted direction to get from one point to another.
your integrand df/dx may depend on both y and x, and the integral may depend on the path so you cannot just integrate only over the x values, for example.
by the way your question shows great imagination, and wonderful intuition for how to pursue analogies, and how to pose questions! I predict you will be a research mathematician someday soon, if that interests you.
Actually, what you are not taking into account is that z(x,y) is a function of both x and y, while you wrote the differential form of z in terms of the partial derivatives of it. The partial derivatives do not come naturally as an straight forward extension of one variable case, since in multivariables ( 2 variable, in this case), there are many directions one can move (in a plane, in this case).
So suppose I start with the point (a,c) and go to (b,d), there is not a unique path to follow and the function z(x,y) may depend upon which path you follow, except in a special case, where z(x,y) is a conservative function ( curl of it is zero), one can give an absolute meaning to the function z(x,y), in all other cases z(x,y) is path dependent.
In the above calculations, you have done, it is okay till the last step, where if some particular path is chosen, y is related to x and hence dy and dx are not independent.
  • · Replies 16 ·
