My internal combustion engine is more efficent than 30%
78 replies · 20K views · last reply
smokingwheels
I have an spark ignited 4 cylinder 2000 cc engine in a wagon and I think its 50% thermally efficient at idle due to the mods I have done on the intake manifold.
My engine uses (mesured on video) roughly 9.807 cc/min at approx 750 rpm and the only reference I have come across is a similar engine uses 5kw of fuel just to idle which works out at 29.55 cc/min of fuel.
Is 5kw for idle a good guess?
I have the video of the idle test on youtube, if anybody is interested I will post the links.
so I did the percentage 29.55 - 9.807= 19.743 then (19.743/29.55)*100= 66.8% then assuming an engine is 30% efficent 30*.668= 20.04 then 20.04% +30% = 50.04% is it ok to add the thermal efficency on to the original number?
If not how would I work it out the thermal efficiency at idle?
Another thing my city consumption is 58% better about 7l/100km and my hwy consumption is approx 34% better at approx 7l/100km my engine seems to work better under light loads.
Its very strange to have hwy and city nearly the same that is pushing a law of physics.
Another thing my engines idle increases by 9.33% when the temp goes from 160 deg f to about 200 deg f the above tests where done with a 160 deg thermostat, I now have a 195 deg F thermostat and I will fit it soon and retest my engine to see if I get a 9.33% increase.
My first real test of my engine in 2005 was 340km to approx 14 L of fuel at 80km/h with a 190 or 195 deg F thermostat this is nearly 100% more efficent but it was running very close to knocking most of the way, since then some one has sliped silicon in my engine and damaged it so its not as good as it used to be.
<< link to commercial whereis website removed by berkeman >>
An idling engine is 0% efficient. With no load there is no conversion of heat to mechanical energy.
If you wish to measure efficiency accurately you'll need to hook the engine up to a controlled load so you can measure the work done per fuel energy used.
At idle all the mechanical work is lost to engine friction. You can't extrapolate from similar engines because the friction could vary significantly. Little things like oil type, temperature, rings, whether you broke in the engine properly or not, and simple variations in manufacturing tolerances may dramatically change the engine friction.
I suggest you link your engine to a generator and use that to power something like a heating element or bank of lights to produce a controlled load. You can then either measure the electrical power output or measure the torque and rotation speed to calculate power (work per unit time). Then work out(load)/energy in (fuel) is the efficiency.
The stock 3.4 litre engine in my minivan uses 16.7 cc per minute. That works out to 4.9 cc per litre of engine displacement, which is exactly the same as yours. Sorry.
Ok so how did you measure it I am interested?
Is it an EFI or carby?
My city cycle is approx 58% better and I have a tacho graph see below.
Spreadsheet-style line graph of engine tachometer readings: rpm on the vertical axis from 0 to 4000 against sample number on the horizontal axis from 1 to about 5400, with a single Series1 trace fluctuating mostly between 1500 and 2500 with frequent spikes.
EFI with a fuel consumption readout. It takes six minutes of idling to use .1 litre (100 ml).
The reason that city fuel economy is usually worse than highway is that it involves traffic. Most cars will get very good fuel economy at a steady 60 kph, often better than at 100 kph.
What mods did you make? And 58% better than what?
I can gaurantee you that you've not increased your thermal efficiency to over 50% purely by arsing around with the inlet geometry.
The fact is you've openly guessed at the vast majority of your numbers. The sheer amount of error involved with 'guesstimating' everything can lead to so very funny results/conclusions.
You'll need to accurately measure a heck of a lot more to get a better idea as to what you are using, and therefore the real efficiency.Even using your numbers you get a very odd answer, shoing that they are most likely wrong.
Thermal efficiency = total energy available from fuel / total energy output.
Output: 5kW for 1 minute = 300kJ energy.
Input: Assuming standard petrol contains 34.8 MJ/l
You used about 10cc of fuel in a minute. 0.01 * 34.8 = .348 MJ energy = 348 kJ.
So your indicated thermal efficiency is 300/348 = 86%. Which is clearly wrong.
Metrology is the science of measurement
Measurement is the language of Science
learn how to measure
xxChrisxx said:
... by arsing around with the inlet geometry.
I suspect the mod has more to do with inlet temperature.
ok so the .1 L is what the computer is saying. What is the resolution on the computer?
The mods I made are like a golf ball surface that simple.
58% better than some one who has owned one from yahoo answers see http://answers.yahoo.com/question/index?qid=20100220205012AAUkG6f"
The city test was done driving arround the block 12 times and at speeds of 50 60 70 km/h see post with graph.
Some rough stats from the data based on engine rpm, crusing 82.61%, idle 7.41% rpm above 2440 rpm 9.94%.
I also calculated when the acceleration rate exceeded a threshold eg when in lower gears accelerating the figure is 19.49% of the time the engine was running during the test.
Yes for guessing I am using what wally said on a forum that a 30% efficient engine similar to mine uses 5kw of fuel just to idle he calulated it he wrote
http://www.carforums.com/forums/index.php?showtopic=23881&hl=smokingwheels"
fuel = 34.656 Mj/litre
specific weight majority of cases = 0.72 (can go as high as 0.79 and as low as 0.71)
engine efficiency 30% = 69mg/kW (0.09858cc/kw) = 5.91cc/kw/min
0.868 l/s air /kW at stoich 14.7
Thus 5kw=29.55 cc/min at idle.
I do not know how accurate the 5 kw is I have no idear.
Increased thermal efficency, then why is my city and hwy consumptions very similar?
see tacho graph on other post.
I know I need to accurately measure all sorts of things but I am on a pension and do not have any money left to spent on it.
Another thing is my idle speed increases by 9.33% when going from 160 deg f to above 200 deg f, How normal is that?
Another thing I could do is hire a video camera and record my city test curcuit then host on youtube.
And I could just add that this is my second prototype my first one used to knock when the timing was fired 4-5 deg before top dead center above 3000 rpm with no load, I ended up destroying it before I could fix the timing problem later on I threw it out.
Fuel economy isn't easy to measure consistently due to the amount of driving you have to do to get accurate measurements. In any case, 7l/100km is good but not terribly exciting. I drive a 2.4L Mazda 6i and get about that under good conditions.
That doesn't sound much like city driving to me - how often did you come to a complete stop?
But you have to compair eggs with eggs.
I have a 1984 nissan bluebird wagon with a carby with a 2 point vacumme advance. I can only speculate that if I had an modern EFI engine I might me another 20% to 30% better off if the load map was correct and having fuel injectors.
For the city test that I did, I drove arround the block 12 times, 6 laps turning right and 6 laps turning left so I would cop the stop signs on 1/2 the journey and doing 67 km in one go.
Acording to my tacho graph my engine was idleing for 7.41% of the time I think this is a bit low but I can not find a standard anywhere to test my car against eg the amount of idle time I think it should be neer 15%, that's easy to derate my figures
the test ran for 91 min and I am short 7.59% so say 7 min at 10 cc/min I used 4.76 L in 91min +70cc any way about 7.184 l/100km
There is no way it should have been knocking with that little timing at 3000 rpm and no load.
It was knocking and the spark plugs would only last 3-4 days
see http://www.youtube.com/watch?v=XnwJuNbvULY" for a look at my plugs back in 2002.
This is the timing of my first engine http://ampair.tripod.com/Graph/My_first_engine.html"
The 1st and 2nd graphs would stop my engine knocking but the power level was low.
The 3rd and 4th are when I lowered the compression ratio to 8:1.My second engine timing plots at http://ampair.tripod.com/Graph/My_second_engine.html"
note notice how there is no bend at 3000 rpm.
Over time my timing base line seems to go lower.
I think its due to carbon build up.
Just for the record my current timing base line is as follows
750 rpm 1.18 deg BTDC
2000 5.74
4000 13.03
6000 30.32
10000 35
Also I have a normal laptop computer running Microsoft's Quick Basic v4.5 controling my spark timing eg running in realtime.
Dear me, this is pretty shocking. What is engine speed supposed to show you anyway?
To compare fuel consumption with different engine setups, you really have to do tests on a dynamometer to hold all possible test conditions constant. I really don't believe that meaningful conclusions can be drawn with the test methodology currently in use.
The big problem is I do not have any money to spend on testing it, so I can only do what I can and report my results.
When my engine was undamaged in 2005 we did a trip of 340 km on a flat road in the country crusing very carefully at 80 km/h in overdrive with the engine slightly knocking under acceleration and used approx 14 L of fuel that's 4.11 L/100km, but since then I have had silicon put in my engine and damaged the cam and crank also I have a very low temp thermostat as well and I do not push my engine into the knocking zone anymore.
I used the low temp thermostat because the timing drifts greatly with temp, soon I will be fitting a high temp thermostat again and run some more tests.
I fully understand why you're not doing controlled condition tests, but let me put it like this:
My job is all about developing engines, and fuel consumption is an increasingly important parameter. I'd never even dream of wasting money trying to do this in a vehicle, because the variability in SFC which can be attributed to uncontrollable factors (humidity, operator mood, wear, traffic, ambient temperature to name a few) far outweighs any change in fuel consumption that I would reasonably foresee in making the kinds of modifications I would make. That's all assuming the engine is a constant; you're talking about knock, damage, and several years between tests. Your methodology simply cannot yield valid results, I'm sorry.
So, I understand (ish!) what you're trying to do and why you're trying to do it, but I hold no faith in your test methodology. You said it yourself - you have to compare apples with apples and it's impossible to do this by road testing.
More crucially, I'm not sure what your 'idle' experiments are trying to show; the fuel used at idle balances the FMEP and pumping losses. Volumetric efficiency (which is presumably what you're trying to improve) makes bugger all difference at idle, because the air flow is so low; and even less in a spark ignition engine because your flow is intentionally throttled anyway!
We're not here to piss on your chips, we're here to help, but what you're doing is flawed and we'd rather see you learn a bit about conducting a proper experiment than waste time and fuel on your current methodology.
xxChrisxx said:
I can guarantee you that you've not increased your thermal efficiency to over 50% purely by arsing around with the inlet geometry.
Even using your numbers you get a very odd answer, showing that they are most likely wrong.
Ok 1 problem its 5 HP not kw so I redid the numbers, If you want the links to my evidence please let me know and I will post them.
Output: 5 HP = 3.7284kw for 1 min = 223 kj energy
Input: My best is 10cc of fuel/min 0.01 * 34.8 =.348 MJ = 348 kj
So my indicated thermal efficiency is 223 / 348 = 64%
I have it on video on youtube
I did a 40 min test and measure in 2008 and the average was 13.66 cc/min
Input: my average 13.66 cc of fuel/min 0.01366 * 34.8 =.475 MJ = 475 kj
So my indicated thermal efficiency is 223 / 475 = 49%
I did a more recent test and used approx 15 cc/min
Input: my best is 15 cc of fuel/min 0.015 * 34.8 =.522 MJ = 522 kj
So my indicated thermal efficiency is 223 / 522 = 42%
so its dropped off a bit when I have some money to spare I will rip it apart and look at what's gone on
Note: I used 5 HP not 5kw because that's what is quoted around the traps for a 2L 4 cylinder engine.
I have even been quoted 30cc/min just to idle as well for a normal 4 cylinder but my program puts that down to 20 cc/min for 5 HP.
Thanks for your time Chriss
russ_watters said:
Fuel economy isn't easy to measure consistently due to the amount of driving you have to do to get accurate measurements. In any case, 7l/100km is good but not terribly exciting. I drive a 2.4L Mazda 6i and get about that under good conditions. That doesn't sound much like city driving to me - how often did you come to a complete stop?
I came to a complete stop roughly 28 times the data log is a bit coarse
Well the spark plugs would last 3-4 days before shorting out and my compression ratio was approx 12.5:1 see http://www.youtube.com/watch?v=XnwJuNbvULY"
I have approx timing graphs plotted back in 2002 and I still have the programs I wrote to control the timing.
1. This is the result of my first program a 4 ms delay there was no power from my engine.
2. After a few nights work lowering the delay no knocking sound from engine.
3. This is a later program after I lowered the compression to 8:1 Look at where the advance peaks its about 1500 rpm then it goes negative this is not normal unless you have a large super charger feeding the engine.
4. After a while I got the feel for the timing the blue line is a guess below 3000 RPM because the mechanical advance was fine until 3000 rpm under load I have no idea what the timing should be of my first engine well if its anything like my second engine its about 20 degrees retard with full load but it was knocking at no load so I would have to find than figure out one day when I want to end the life of my engine to get some idea of what it should of been. I do agree it would be very different to find the timing because the piston is moving away eg the space is getting bigger instead of surviving getting smaller.
brewnog said:
I fully understand why you're not doing controlled condition tests.
Ok, how much would you pay me to build another engine the knocks above 3000 rpm with 3-4 deg of advance?
If you check my timing line in my second engine on my forum http://203.161.71.130/forum/topic.asp?TOPIC_ID=23" you will notice is a 1 dementioned
line unlike a modern engine which is 2 and if I heat my engine up a little it needs to be 4 deg lower at low rpm.
What money I do have usually goes on food and bills so its hard for me to do anything the proper way.
I really can't remember this thread, at work so can't really spend time reading through it.
Why are you testing something at idle anyway? Seems like a useless test to me, it's not indicitave of the engine running with an open throttle or at above idle. If you that worried about fuel use at idle (which let's face it is a tiny amount of time as a percentage of engine usage) turn the key. Then you use no fuel.
There also appears to be no aim or logical progression to the testing. What are you trying to do excatly?
I'm not going to pay you to do anything.
People pay ME to develop engines for them, not the other way round.
smokingwheels said:
If you check my timing line in my second engine on my forum http://203.161.71.130/forum/topic.asp?TOPIC_ID=23" you will notice is a 1 dementioned line unlike a modern engine which is 2 and if I heat my engine up a little it needs to be 4 deg lower at low rpm.
Your forum looks to be your own personal computer? You might want to be careful dishing that out.
I note you're also the only contributor. So it's not so much a forum, more a place for you to jot down your thoughts.
Shifting focus there from here does nothing to back up your solution. You've been given answers in this thread and guidance as to what you should do next. There's really no more anyone can do for you.
Why are you testing something at idle anyway? Seems like a useless test to me, it's not indicative of the engine running with an open throttle or at above idle. If you that worried about fuel use at idle (which let's face it is a tiny amount of time as a percentage of engine usage) turn the key. Then you use no fuel.
There also appears to be no aim or logical progression to the testing. What are you trying to do exactly?
I can only video my fuel consumption test at idle and maybe higher rpms, I have done road tests also with greatly improved results but I do not have a comparison engine, that was left behind at my last girlfriends place because the police insisted on a court order for me to get my stuff from her place.
I have worked out something from a drive around the block.
I used an average of 42 cc/min of fuel and my average rpm was 1719.
From that data my engine and a normal engine software I worked out this.
My engine uses 7.8 kw of fuel 42 cc/min to run at 1719 rpm eg normal city loads for 99.5 min
Thus VE% of my engine is 25% How does that compare?
Yes I am not very logical its been said I have the splatter gun approach but I'm learning.
What are you using to read fuel use? I hope it's not the cars fuel gauge.
My pc is ok thanks. Yes I am the only one with such an engine so that kinda makes me authoritative on the subject, My first engine really messed my life around I destroyed it before I could fix it.
I have 2 questions.
Forget about current design
1. How would you calculate the maximum compression ratio for an engine if the combustion process was 88% efficient eg reduced leftover heat from the previous cycle and firing At Top Dead center or below?
Variables, known things
Self ignition temperature of fuel
Temperature rise to to compression of gas
Temperature of chamber that compresses gas
Temperature of inlet charge
Temperature of coolant 88 deg C
space fuel takes up in compressed gas
compression ratio 12.5:1 shorts out plugs with carbon in 3-4 days with heavy knocking(well it killed good crankshaft in 3 weeks)
normal cyclic pumping losses reduced by 50%
answer: Compression ratio 12.5:1 not high enough
2. How to calculate the engine efficiency if you could fire the spark 0 deg 5 deg 10 deg After Top Dead Center and still make peak combustion pressure by 18-19 deg in power stroke?
You would start to reduce and return lost energy from the crankshaft like a spring
Efficiency decreases with advance timing, data from my current engine
answer: would have to build such a beast again
Just note that "authoritative" does not mean "right".
In this particular case it simply means you're the only person with a knowledge of it, right or wrong.
I have 2 questions.
compression ratio 12.5:1 shorts out plugs with carbon in 3-4 days with heavy knocking(well it killed good crankshaft in 3 weeks) Of course it does; stop doing this and your engine will thank you!
answer: Compression ratio 12.5:1 is too high
The ideal is about 11 degrees after TDC. The spark has to occur before TDC to accomplish that. The small amount of negative work from the advanced timing is more than made up for by the increase in net cylinder pressure. That means that the engine efficiency will increase.
(if true this tells you that you're doing things wrong!)
Better answer: stop expecting that engine to survive. It won't.
Let me save you a lot of time and money: your concept is not going to succeed. You're chasing a dead end, and your methodology won't allow you to see that.
