Nabla operator and working with it
  • Thread starter Thread starter jink
    Nabla Operator
The discussion focuses on the use of the Nabla operator (∇) and its treatment as a vector in mathematical derivations. A specific product rule involving the cross product of vectors A and B is presented, prompting inquiries about direct derivation methods. The use of summation convention is suggested as an effective approach for deriving results, highlighting the complexities involved when treating ∇ as an operator rather than a true vector. Participants note that the identity ∇·A = A·∇ does not hold, emphasizing the unique nature of the Nabla operator. Overall, the conversation underscores the importance of understanding the distinctions between vector operations and operator behavior in mathematical contexts.
jink
While using the ∇ operator, most of the times we can treat it as a vector. I came across a few formulae(basically product rules)..
Code:
∇×([B]A[/B]×[B]B[/B])=([B]B[/B].∇)[B]A[/B]-([B]A[/B].∇)[B]B[/B]+[B]A[/B](∇.[B]B[/B])-[B]B[/B](∇.[B]A[/B])
where A and B are vectors
I wanted to know if there is any direct way of deriving it. By direct I mean assuming the basic vector identity
Code:
[B]C[/B]×([B]B[/B]×[B]A[/B])=[B]B[/B]([B]C[/B].[B]A[/B])-[B]A[/B]([B]C[/B].[B]B[/B])
. Any other better way is also fine. I derived it by splitting each of the vectors A, B, and ∇(although this is not truly a vector) in their orthogonal components and then doing the appropriate cross products.
The best way to derive these results is to use summation convention. Everything drops out quite nicely.
The vector identity you've stated is also derived in the same way but you'll notice the subtleties of the fact that you're dealing with an operator when doing the derivation.
Likes 1 person
Thanks for the idea. I have never really used summation notation, always expanded terms and got my way through. Will try summation from now on.
I realized one thing that ∇.A=A.∇ doesn't hold in this case while it holds with vectors.
yeah that's fine, I just wanted to think if there is any result which we can exploit using the fact that ∇ behaves as a vector(well, almost). I was just worried that incase I forget the long identity, and I want to use it, I won't be able to derive it quickly.
I realized one thing that ∇.A=A.∇ doesn't hold in this case while it holds with vectors.That's because Del isn't really a vector; it's a set of operators which work on vectors.
http://en.wikipedia.org/wiki/Del
Yeah right.
22K
