Necessity of the field viewpoint
  • Context: Undergrad
  • Thread starter Thread starter simonjech
    Field
The discussion centers around the necessity of using field operators in relativistic quantum theory as opposed to operators with a finite number of degrees of freedom, which are common in non-relativistic quantum mechanics. Participants explore theoretical justifications, implications for causality, and the nature of quantum fields in the context of quantum field theory (QFT).
  • Some participants note that there are no finite-dimensional unitary representations of the Poincaré group, which is a reason for the necessity of fields in relativistic quantum mechanics.
  • Others argue that the causality structure in relativity is more complex and is best described using local field theories, as first-quantization fails to maintain locality and causality.
  • A participant highlights that at relativistic energies, particles can be created and destroyed during collisions, which is more naturally described by QFT.
  • One participant requests clarification on why causality cannot be fulfilled without using fields.
  • Another participant explains that using the first-quantization formalism leads to violations of causality, as demonstrated with the Klein-Gordon field, where faster-than-light signal propagation occurs.
  • It is mentioned that QFT allows for both positive and negative frequency modes without leading to an unbounded Hamiltonian, thus preserving causality through the use of creation and annihilation operators.
  • A participant reflects on the relationship between quantum mechanics and quantum field theory, noting that QM can often be viewed as a QFT in lower dimensions.
Participants express various viewpoints regarding the necessity of fields in relativistic quantum mechanics, with some agreeing on the importance of causality and locality, while others present differing interpretations and implications of these concepts. The discussion remains unresolved with multiple competing views.
Limitations include the dependence on specific definitions of locality and causality, as well as unresolved mathematical steps in the transition from first-quantization to QFT.
simonjech
I am learning QFT rn, so the question that I naturaly ask myself often is why do we have to use field operators in relativistic quantumn theory instead of operators with finite number of degrees of freedom which are used in non-relativistic quantumn mechanics?
One of the reasons that I came across is that there are no finite-dimensional unitary representations of the Poincaré group (Wigners theorem).
But I would like to now some other reasons why fields are necessary in relativistic quantumn mechanics. So could you please write me some arguments that you know?
There are also no finite-dimensional unitary representations of the Galilei group.
The reason is that in relativity you have a more subtle "causality structure", which is most easily fulfilled by descriptions of the dynamics of physical entities in terms of local field theories. There's no way to fulfill locality and causality in the first-quantization formalism, while it's easy to establish using the microcausality constraint on local operators that represent local observables.
From an empirical point of view it's, because when particles collide at relativistic energies (i.e., when the energy exchange between the interacting particles gets in the order of magnitude of the masses of particles that are interacting with the colliding particles) there can always particles be destroyed and new ones created, and this is most naturally described with a quantum-field theoretical description.
Thank you for your respond. Can you also please explain why it is impossible to fulfill causality without using fields?
You can try the first-quantization formalism for, e.g., the Klein-Gordon field. Then you'll see that the time-evolution operator must be
$$\hat{U}(t)=\exp(-\mathrm{i} \sqrt{m^2 + \hat{\vec{p}}^2} t),$$
because energy should be positive definite, i.e., the negative-energy solutions must be abandoned, and the corresponding time evolution of the wave function with this ##\hat{U}(t)## does not fulfill the causality constraint, i.e., if you solve the KG equation with this time-evolution operator for the initial condition ##\Phi(t=0,\vec{x})=\delta^{(3)}(\vec{x})## you get for any ##t>0## a wave function ##\Phi(t,\vec{x})## which is non-zero at any ##\vec{x}##, i.e., you have faster-than-light signal-propagation through ##\Phi##, and this clearly violates relativistic causality.
The solution through QFT is that here you can write the free-field operator with both positive and negative frequency-modes without making the Hamiltonian unbound from below. That's achieved by using the Feynman-Stückelberg trick, i.e., writing an creation instead of an annihilation operator in front of the negative-frequency modes. For the Klein-Gordon field you must quantize everything as bosons to achieve all the good properties of the QFT, i.e., microcausality, ##[\hat{\Phi}(x),\hat{\Phi}(y)]=0## for ##(x-y)## spacelike and positive definiteness of the Hamiltonian:
$$\Phi(x)=\int_{\mathbb{R}^3} \frac{\mathrm{d}^3 p}{(2 \pi)^3 \sqrt{2 E_p}} [\hat{a}(\vec{p}) \exp(-\mathrm{i} x \cdot p) + \hat{b}^{\dagger}(\vec{p}) \exp(+\mathrm{i} x \cdot p]_{p^0=E_p}$$
with ##E_p=\sqrt{m^2+\vec{p}^2}##. The creation and annihilation operators have to fulfill the commutator relations
$$[hat{a}(\vec{p}),\hat{a}^{\dagger}(\vec{q})]=[\hat{b}(\vec{p}),\hat{b}^{\dagger}(\vec{q})]=(2 \pi)^3 \delta^{(3)}(\vec{p}-\vec{q})$$
with all other combinations of operator pairs in the commutator giving 0.
This construction of the microcausal field operators shows that there are necessarily anti particles (annihilated by the ##\hat{b}## operators) with the same mass as the particles (annihilated by the ##\hat{a}## operators). At the same time, thanks to the use of bosonic commutation relations for the field and thsu the annihilation-creation operators, you find a positive semidefinite Hamiltonian,
$$\hat{H}=\int_{\mathbb{R}^3} \frac{\mathrm{d}^3 p}{(2 \pi)^3} E_p [\hat{a}^{\dagger}(\vec{p}) \hat{a}(\vec{p}) +\hat{b}^{\dagger}(\vec{p}) \hat{b}(\vec{p})].$$
For a very clear discussion on an introductory level, see
https://arxiv.org/abs/1110.5013
  • Love
What is tangentially related and really impressed me when I realized it is that QM IS often a QFT, except in 0 spatial and 1 temporal dimensions, except the fields are, for example, the position and momentum operators.
Thank you very much for the clarification.
  • · Replies 87 ·
9K
  • · Replies 22 ·
  • · Replies 113 ·
11K
10K
  • · Replies 134 ·
13K
