What is the best way to incorporate accelerometers into a 3D positioning system?
  • Thread starter Thread starter nclay
    3d Need advice
The discussion centers on developing a rudimentary 3D positioning system, with a focus on the use of accelerometers for position data acquisition. The initial suggestion was to place an accelerometer at the tip of the actuator arm; however, participants recommended using rotary or linear encoders for more accurate movement tracking. Additionally, the use of limit switches for zeroing counts and stepper motors for motion control was highlighted as effective alternatives. The conversation emphasizes the limitations of accelerometers, particularly their effectiveness in tilt measurement rather than precise positioning.
  • Understanding of 3D positioning systems
  • Familiarity with rotary and linear encoders
  • Knowledge of stepper motor operation
  • Experience with limit switches for motion control
  • Research the implementation of rotary encoders in motion systems
  • Explore linear encoder technologies and their applications
  • Learn about the integration of limit switches in automated systems
  • Investigate the use of stepper motors for precise movement control
This discussion is beneficial for engineers, hobbyists, and students involved in robotics, automation projects, or anyone interested in developing 3D positioning systems using various sensors and motors.
nclay
I am trying to create a kind of rudimentary 3d positioning system, sort of like a CNC minus the machining aspect. I am just trying to get my very basic design down and I am stuck at how i should get the position data, my first thought was to use an accelerometer placed at the tip of the actuator arm but I am wondering if there is a better way to go... I've been doing lots of research on accelerometers and they seem to only work well with tilt. Any suggestions?
Welcome to the PF.
You can use rotary or linear encoders, depending on what you are using to create the movements. Limit switches can be used to zero out the counts, when you return the motion assembly to its home position.
Thanks berkeman! That was exactly what i was looking for... these things arent cheap! Gonna blow my budget.
Thanks again!
-Nick
Thanks again!
-Nick
How are you creating the motion? If you're using stepper motors, you can generally just count the steps...
My original idea was to use a servo control arm and use an accelerometer to track the movement. I would really like to use the accelerometers i have so I'm thinking about going a different direction with the project... maybe a arm that you can control by attaching accelerometers to your shoulder and elbow. The steppers are a good idea though. I'm just trying to come up with a good project that would satisfy the requirements of my senior project, unfortunately I am really not an idea man.
  • · Replies 20 ·
  • · Replies 16 ·
