Need help developing probability calculator for a game
This discussion focuses on developing a probability calculator for a turn-based game where players aim to reduce their opponent's life points to zero. The key variables include Attack (hit accuracy), Strength (maximum hit), Defense (opponent's hit/miss ratio), and Life Points (health). The participants suggest using computer simulations to estimate the probability of winning, particularly through a two-dimensional random walk model with orthogonal absorbing boundaries. The consensus is that simulating multiple battles will provide a practical solution for determining winning probabilities.
  • Understanding of probability distributions and random walks
  • Familiarity with computer simulations and statistical analysis
  • Basic knowledge of game mechanics and turn-based strategies
  • Experience with software tools for data generation, such as spreadsheets
  • Implement a computer simulation to model player battles and calculate winning probabilities
  • Research two-dimensional random walk models and their applications in game theory
  • Explore statistical methods for estimating probabilities using generating functions
  • Learn about linear interpolation techniques for refining simulation results
Game developers, data analysts, and anyone interested in probability theory and simulation modeling for competitive gaming scenarios.
Firefight
The goal of this game is to get your opponents life points down to 0 before he gets yours down to 0. You take turns hitting each other until one persons health is at 0.
The variables are:
Attack (accuracy of hitting instead of missing)
Strength (how high you can hit)
Defense (determines opponents hit / miss ratio)
Life points (How much health of yours is to take away.
Now, I'm going to leave the formulas of the game out. But usually, you miss around 30% of the time.
Out of the times you do hit, a random number is generated between 1 and your max hit determinant on your strength. A common max hit is 8, so the hitting range would be 1-8.
Now, let's assume that we have already calculated both opponents hit/miss ratio and max hit and that we know their life points.
The average number of hits the match will last is easy to calculate. However, my goal is to determine the probability of each player winning.
Assume P1:
Misses 35% of the time
Has a hitting range of 1-8
Life points are 60
and P2:
Misses 30% of the time
Has a hitting range of 1-10
Life points are 55
So, P1 has to hit a total of 55 or more damage against P2 before P2 hits a total of 60 damage against P1 for P1 to win. What is the probability of P1 winning?
I've thought about ways to do this, and I imagined that we had two overlapping probability distributions of the number of turns it would take P1 to hit 55, and P2 to hit 60.
If we knew these distributions, we could calculate the % chance of either one of them winning with relative ease. The hard part for me is getting the probability distributions.
Any insights on how to do this?
The model for this is a two-dimensional random walk with orthogonal absorbing boundaries. If the life points of the two players are represented as (x, y) then there is a probability distribution of how this vector changes each move. A normal analytic approach is to set up some recurrence relations to represent these transition probabilities and try to solve them using generating functions.
In practice this can get quite messy; a more practical approach may be just to generate the numbers in software, maybe with a spreadsheet. Generate the numbers starting at (x, 0) and (0, y), working up.
haruspex is correct.
His suggestion is most definitely your best bet, and if you're having to ask for help with this (I mean no disrespect) your only bet.
Please read more here.
Use a computer simulation
I once had a very complex three dimensional problem, where I needed to estimate the error distribution, which depended on the number of samples and geometrical factors. So I made an linear approximation of the geometrical factors, and scaled the distribution by k(n)/sqrt(n).
I then applied a rather massive computer simulation, and simply calculated the average factor k(n) for n=(3,4,5,6,7,8,9). In the setup the distribution is non-linear, so I have no clue if it is even possible to calculate the k(n) analytically.
In any case your problem should be easy to solve by a computer simulation, where you may extend simulation results by an interpolation of results as a function of an interesting parameter.
Bo at TRNG98.se
If all 6 parameters (max hit, hit probability, life for both players) are variable and you are interested in a rough approximation ("is it a good idea to fight this player?"), I would just simulate 100 or 1000 battles and check how often P1 wins.
This is not too time-consuming if your values are typical and if you don't have to do this for thousands of battles at once.
There is a good chance that your input parameters has some distribution, so they are not all (all combinations of) equally probable. You can focus your computer run on frequent alternatives. I would then consider a direct search for most close simulations, compared to the actual case. Try a linear (multi-dimensional) interpolation between closest computer runs and the actual case.
Bo at TRNG98.se
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
  • · Replies 41 ·
