How High Should the Cable Be Anchored for Equilibrium?
The discussion centers on calculating the minimum height for anchoring a cable to ensure equilibrium for a sign and rod system. The system consists of a 65 kg sign and a 9.8 kg rod, with a maximum cable tension of 760 N. The key equation derived involves balancing the torques around the pivot point, leading to the formula: (Force of sign)(Radius of sign) + (Force of rod)(Radius of rod) - (vertical component of Tension) * distance = 0. Participants emphasize the importance of considering only the vertical component of tension for torque calculations.
  • Understanding of torque and equilibrium principles in physics
  • Knowledge of forces and their components, specifically vertical and horizontal
  • Familiarity with basic mechanics equations, including tension and weight calculations
  • Ability to set up and solve equations involving multiple forces and distances
  • Study the concept of torque and its application in static equilibrium problems
  • Learn how to resolve forces into their vertical and horizontal components
  • Explore the principles of tension in cables and their limits in structural applications
  • Practice solving similar problems involving multiple forces and pivot points
Students and professionals in physics, engineering, or architecture who are involved in structural analysis and equilibrium calculations will benefit from this discussion.
jtulibarri
a 65 kg sign hung centered from a uniform rod of mass 9.8 kg and length 2.3 m. At one end(left) the rod is attached to the wall by a pivot; at the other end(right) it's supported by a cable that can withstand a maximum tension of 760 N. What is the minimum height h above the pivot for anchoring the cable to the wall?
i need help on setting up an equation to solve...
what i have so far i don't know how wrong or right it is.
(Force of sign)(Radius of sign)+(Force of rod)(Radius of rod)-(Tension)=0
(637N)(1.15m)+(96.04N)(1.15m)-m*g*sin(angle away from wall)=0
? i don't really know exactly where I am going with this
you need the torque about that point to be zero... so you need:
(Force of sign)(Radius of sign)+(Force of rod)(Radius of rod)-(vertical component of Tension)*distance=0
(since horizontal component of tension exerts 0 torque about the pivot)
what is the vertical component of Tension in terms of the total tension T... what is the distance here?
  • · Replies 18 ·
