Need help for my question regarding circuit
  • Thread starter Thread starter mremadahmed
    Circuit
The discussion revolves around a circuit design involving LEDs, resistors, and voltage sources. The original poster seeks assistance in determining the appropriate resistor and voltage values for the circuit to function correctly, as well as clarification on specific circuit behavior and terminology.
  • Participants inquire about the implications of closing a switch in the circuit, the intended function of the circuit, and the expected behavior of the LEDs. Questions about the meaning of specific voltage and current ratings for the LED are also raised.
The conversation is ongoing, with participants seeking clarification on the circuit's design goals and functionality. Some guidance has been provided regarding the interpretation of LED specifications, but there is no consensus on the circuit's correctness or necessary modifications.
Participants note potential issues with the circuit design, including the use of two voltage sources and the need for clearer definitions of terms used by the original poster. The assignment constraints and requirements for monitoring LED behavior are also mentioned, but details are still unclear.
mremadahmed
Hello ,
I am having problem with one question.
In the figure below which resistors values and voltage source values are sufficient so that LED can work properly.
Is the circuit correct,do i need some modifications on that.
If it is correct what will be the equivalent voltage.
what does "@20 mA" means in this LED.
Before going any further, what happens when you close S3?
I don't know nothing at all ... please guide me which you know of ... if i am wrong in this circuit please guide me
mremadahmed said:
Hello ,
There may be problems with the circuit, but in order to help you find them we will need to know what the circuit should be doing. Is this your own design? If so, what are the design goals?
The "1.83 V @20 mA" type labels indicate the expected voltage drop across the LED when the specified current of 20 milliamps is flowing through it. Note that 20 mA is a typical operating current for many LEDs.
S3 connects the positive of V2 to the negative of V2. What happens if you short out a voltage source like that?
Ohms law... V=IR so I = V/R but R=0
Besides being shorted out when S3 is closed, what purpose is V2 supposed to accomplish?
As gneill says, we need to know what the circuit is supposed to do before we can help you. When will the switches be activated? Will they never be closed together or can it happen that all of them are closed at the same time? Are they supposed to light up together or one at a time? Why is there 2 voltages supplies?
I was told in assignment to make a circuit and monitor each light blinking ... this is why i made this circuit and want to monitor it with switches open and closed... The major thing which i need to know is that
1)With switch/switches closed which led/leds is going to blink
2)The direction of current will go from where to where
3)What should be the value of resistors,current in the circuit
4)Which voltage source will dominate and what will be the total voltage of the circuit
5)If there is any flaw in the circuit please let me know.I will change it.
Hi mremadahmed. I'm afraid that your explanation is still not clear. I think you are wrongly using the words "monitor" and "blink". Can you write your explanation again, but this time avoid those two words and choose other equivalent words that mean the same to you.
Were you told that you must use two voltage sources? If not, why have you chosen two?
Can you include a .jpg of the assignment question and its accompanying diagram? Post it even if it is not in English.
  • · Replies 21 ·
