Need Help Solving nth Derivative of e^ax*Sin(ax+b)
  • Context: Graduate
  • Thread starter Thread starter Tanny Nusrat
    Derivative
The discussion revolves around finding the nth derivative of the function e^(ax) * Sin(ax + b). Participants are seeking confirmation of their solutions and exploring the differentiation process, including the application of the product rule and the identification of patterns in derivatives.
  • Homework-related, Mathematical reasoning, Technical explanation
  • One participant expresses uncertainty about their solution for the nth derivative and requests confirmation.
  • Another participant advises showing the working steps and mentions the use of the product rule, suggesting that a cyclic pattern may emerge after several differentiations.
  • A proposed solution for the nth derivative is presented, involving terms with b, a, and sine functions, but lacks clarity on its derivation.
  • A suggestion is made to substitute n=1 into the proposed formula and compare it with the result of a single differentiation to check for consistency.
  • A participant points out a potential inconsistency in the notation between the original function and the proposed derivative formula, questioning if there was a misreading.
The discussion remains unresolved, with participants expressing differing views on the correctness of the proposed solution and the need for clarification on the differentiation process.
There are limitations regarding the clarity of the proposed formula and the assumptions made in the differentiation process. The discussion also highlights the importance of accurate notation in mathematical expressions.
Tanny Nusrat
i have solved the following one but not sure...anyone give me the solve..i want to be sure..
nth derivative of {e^ax * Sin(ax+b)}
Show your solution and your working, as requested in the sub-forum guidelines, and I'm sure somebody will confirm it, or correct it if wrong.
You need to use the product rule. Once you've differentiated several times you'll see a cyclic pattern that can be written down as a set of four cases.
ok..here is my solution...somebody please confirm me..
b^n * e^ax * Sin {(n*pi/2)+(bx+c)} + n*a*b* e^ax * Sin {pi/2+(bx+c)} + a^n * e^ax * Sin (b+c)
Substitute n=1 into your formula and then compare to what you get when you differentiate once, ie ##\frac{d}{dx}\big(e^{ax}\sin(ax+b)\big)##.
Do they look the same?
Post the working by which you arrived at your conclusion and somebody can show where you went wrong. Did you try what I suggested in post 2?
If you use latex to properly display your formulas you will also improve your chances of getting help. The latex tutorial is here.
Your original function has "ax+ b" while your formula for the nth derivative has "bx+ c". Was one of those a misreading?
