Need help understanding the twins
  • Context: Undergrad
  • Thread starter Thread starter Malorie
The discussion revolves around the Twin Paradox, a thought experiment in relativity that explores the effects of time dilation due to relative motion and acceleration. Participants examine the implications of speed and changes in velocity on aging, as well as the role of gravitational effects in time dilation.
  • One participant questions why speed causes time dilation, suggesting that it may be the changes in velocity rather than speed itself that lead to different aging outcomes for the twins.
  • Another participant introduces three factors relevant to the Twin Paradox: time dilation, length contraction, and the relativity of simultaneity, explaining how these concepts interact from different frames of reference.
  • A participant emphasizes that the asymmetry in the situation arises from one twin experiencing acceleration when turning around, while the other does not, which they argue is a key factor in determining aging differences.
  • Some participants express confusion over terminology, particularly the use of "inertia" versus "acceleration," and clarify that acceleration is what leads to changes in velocity.
  • One participant proposes an analogy involving a triangle to illustrate the difference in paths taken by the twins, suggesting that the non-linear path contributes to the aging difference.
Participants generally express disagreement regarding the primary cause of time dilation, with some attributing it to speed and others to changes in velocity or acceleration. The discussion remains unresolved, with multiple competing views presented.
Participants note that gravitational time dilation is related to gravitational potential rather than gravitational force, and some express uncertainty about the implications of this in the context of the Twin Paradox.
  • #181
JesseM said:
You're using an incorrect equation for v, the correct equation given on the http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html ), which makes sense since you can have an arbitrarily high proper acceleration for arbitrarily long periods of proper time without ever exceeding c.
OK, after the burn of twin1 do you agree
d = (c2/a) [ch(aT/c) - 1]
Or, am I going to have to fight with you over this?
  • #182
In the launch frame where twin1 was at rest before accelerating (and twin2 remains at rest for time t after twin1 finishes accelerating), yes I agree this is the distance at the moment twin1 finishes his burn.
  • #183
So, do you agree from the accelerated frame
d = 1/a * ( cosh(a BT) - 1 )
is the distance between the ships?
  • #184
The relativistic rocket equations only work in inertial frames...by "accelerated frame" do you just mean the inertial frame where twin1 is at rest after he finishes his burn? If so, then no, this is incorrect. (1/a)*(cosh(a*BT) - 1) would be the distance in this frame between the position where twin1 started his burn and the position where he stopped his burn, but in this frame twin2 is continuing to move at v=tanh(a*BT) throughout the time twin1 is accelerating, and in this frame twin1's acceleration lasts for a time of t=(1/a)*sinh(a*BT). So by the time twin1 finishes his acceleration, twin2 will have moved a distance of vt = (1/a)*sinh(a*BT)*tanh(a*BT) from the position where twin1 started his acceleration, and twin1 will have moved a distance of (1/a)*(cosh(a*BT) - 1) in the opposite direction, so their distance at the time twin1 stops accelerating will be (1/a)*(sinh(a*BT)*tanh(a*BT) + cosh(a*BT) - 1).
  • #185
show me a mainstream paper.
  • #186
I don't know of any mainstream paper that specifically considers the problem of how the distance between twins changes when one moves inertially while the other accelerates away at constant proper acceleration, and looks at this from the perspective of a frame where the inertial twin is not at rest. However, most of the reasoning here is a pretty basic application of SR principles:
1. Do you disagree that if twin1 has velocity v=tanh(a*BT) after he finishes accelerating in the launch frame, while twin2 is at rest in this frame, then if we transform into a new inertial frame where twin1 is at rest after he finishes accelerating, then twin2 must have a constant velocity v=tanh(a*BT) in this frame?
2. Do you disagree that if it takes time t1 = (1/a)*sinh(a*BT) in this frame from the beginning to the end of twin1 accelerating, then if twin2 has velocity v=tanh(a*BT) in this frame, he will have moved a distance of v*t1 = (1/a)*sinh(a*BT)*tanh(a*BT) between the time twin1 starts accelerating and the time he stops accelerating?
3. Do you disagree that in this frame twin1 moves a distance of (1/a)*(cosh(a*BT) - 1) in this frame between the time he starts accelerating and the time he stops?
4. If you don't disagree with any of the above, then the only remaining question should be whether twin1 and twin2 moved in the same direction from the point where twin1 started accelerating, or in opposite directions. I admit I didn't think this part through very carefully, after further consideration I think the answer should be that they both moved in the same direction (since twin1's initial speed and direction was the same as twin2's, but twin2 continued to move at the same speed and direction while twin1's speed dropped to zero) and that therefore twin1's distance covered should be subtracted from twin2's distance covered rather than added, in which case the distance would be (1/a)*(sinh(a*BT)*tanh(a*BT) - cosh(a*BT) + 1).
  • #187
What was wrong with my original method of the D/c business?
  • #188
The fact that it doesn't actually give you a way to calculate twin1's final age when twin2 stops accelerating (i.e. the age he is when he receives the light signal, minus D/c) given known values for the variables BT, a, and t that determine twin2's final age. If you think it does, then please show me how you'd calculate a numerical value for twin1's final age given the example values I gave, namely BT=0.5 years, a=2 light years/year^2, and t=5 years.
Again, my method does allow you to calculate twin1's final age given a set of values like this. I can show you the details of the calculation if you're interested.
  • #189
At Johns Hopkins as a Jr. Instructor the "twins" paradox was never aproached. Likely there has been two generations of teachers who think there is an "answer" to the paradox.
Einstein gave it in 1915; GR. He termed the paradox as "a failure of epistemology." Western 'Greek think" begins with postulates land thru a system of logic arrives at solutions. An unspoken postulate in the twins thing is that the mass environment of neither twin is necessary for fiddling with the SR transformation formulas. Wrong so he thought up GR. If one wants to map wrinkles onto faces of the "twins" one must use the GR equations to the travels of both.
Einstein was largely ignored by the media after he kept repeating that immigrants to palestine must get along with Palestinians and that an international police force must have the power to insure the planet that no nuclear weapons existed anywhere. He also insisted that infinities in formulas weren't physical simply imperfect postulates producing math artifacts. He died before the media was allowed to accept infinite densities here and there.
I expect to be told I am wrong. Could someone carry this century old "twin" thought to a physicist with whom I can discuss this. Thanks
  • #190
Good, this is not the normal twins paradox.
  • #191
Yes, I am interested.
No, I cannot give a specific example and you know this.
I would need to actually know the distance between the two when twin2 entered the frame.
For me this does not matter. But for some it does.
So, I am interested how you decide t'.
  • #192
OK, I'll get to this soon, but first I want to ask a few more questions about how your own approach is supposed to work:
You can calculate the distance between the two in the final rest frame when twin2 finishes his acceleration given BT, a, and t, but it seems to me that even with this information your approach does not tell us who is older. As I said in post #186, if we are analyzing things from the perspective of the inertial frame where they are at rest after acceleration, then in this frame twin1 moves a distance of (c/a)*(cosh(a*BT/c) - 1) during his acceleration phase, after which he is at rest in this frame. Meanwhile we know that twin2 moves inertially for a proper time of (c/a)*sinh(a*BT/c) + t before beginning to accelerate, and in this frame twin2 is moving at constant velocity v=c*tanh(a*BT/c) before beginning to accelerate, so according to the time dilation equation the coordinate time in this frame before twin2 begins to accelerate must be gamma times the proper time, i.e. gamma*[(c/a)*sinh(a*BT/c) + t], and the coordinate distance twin2 covers in this time is just given by velocity*coordinate time, or gamma*c*tanh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t]. Then during twin2's acceleration phase, twin2 will cover an additional distance of (c/a)*(cosh(a*BT/c) - 1). So, the total distance twin2 travels from the origin (the point where the two twins first separated) in this frame is:
gamma*c*tanh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t] + (c/a)*(cosh(a*BT/c) - 1)
Whereas the total distance twin1 travels from the origin in this frame is:
So, subtracting the second from the first shows that the final distance between them will be:
Since gamma is 1/sqrt(1 - v^2/c^2), we can plug in v=c*tanh(a*BT/c), showing that gamma = 1/sqrt(1 - tanh^2(a*BT/c)). And making use of the hyperbolic trig identities here, we known tanh(x) = sinh(x)/cosh(x), so gamma = 1/sqrt(1 - sinh^2/cosh^2) = 1/[sqrt(1/cosh^2)*sqrt(cosh^2 - sinh^2)], and since another identity says that cosh^2 - sinh^2 = 1, this reduces to 1/sqrt(1/cosh^2) = cosh(a*BT/c). So with gamma = cosh(a*BT/c), the final distance between them can be rewritten as:
c*cosh(a*BT/c)*tanh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t]
And again making use of the fact that tanh(x) = sinh(x)/cosh(x), this reduces to:
c*sinh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t]
So if you plug in BT=0.5 years, a=2 light years/year^2, and t=5 years, this becomes:
sinh(1)*[sinh(1) + 5] = 1.1752011936438014*[1.1752011936438014 + 5] = 7.25710381376082 light years.
But even with the final distance known, can you calculate a numerical value for the final age of twin1?
  • #193
You can calculate the distance between the two in the final rest frame when twin2 finishes his acceleration given BT, a, and t, but it seems to me that even with this information your approach does not tell us who is older. As I said in post #186, if we are analyzing things from the perspective of the inertial frame where they are at rest after acceleration, then in this frame twin1 moves a distance of (c/a)*(cosh(a*BT/c) - 1) during his acceleration phase, after which he is at rest in this frame. Meanwhile we know that twin2 moves inertially for a proper time of (c/a)*sinh(a*BT/c) + t before beginning to accelerate, and in this frame twin2 is moving at constant velocity v=c*tanh(a*BT/c) before beginning to accelerate, so the time in this frame before twin2 begins to accelerate must be gamma times the proper time, i.e. gamma*[(c/a)*sinh(a*BT/c) + t], and the distance twin2 covers in this time is just given by velocity*time, or gamma*c*tanh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t]. Then during twin2's acceleration phase, twin2 will cover an additional distance of (c/a)*(cosh(a*BT/c) - 1). So, the total distance twin2 travels from the origin (the point where the two twins first separated) in this frame is:
I am going to need some time to follow your argument.
Yes, why not?
It is the same type of problem.
I sub off the distance of the twin1 accel phase and then I sub the distance of the twin2 accel phase.
I am left with the distance of the relative motion phase and thus, d/v = t'.
No?
  • #194
cfrogue said:
I am going to need some time to follow your argument.But even with the final distance known, can you calculate a numerical value for the final age of twin1?
Yes, why not?
No?
Sure, that works. But I thought your calculation method was supposed to involve subtracting D/c from the time twin1 receives the signal--that doesn't appear to happen anywhere in the method above.
My method for calculating twin1's time from the perspective of the final rest frame was basically similar but without the need to consider distances. I would just say that since we know twin2 moved inertially at v=c*tanh(a*BT/c) before beginning to accelerate, and we know twin2 experienced a proper time of [(c/a)*sinh(a*BT/c) + t] before beginning to accelerate, the according to the time dilation equation the coordinate time in this frame before twin2 accelerates would just be gamma times the proper time, i.e. gamma*[(c/a)*sinh(a*BT/c) + t]. As I showed in my previous post, if v=c*tanh(a*BT/c) then gamma=cosh(a*BT/c), so the coordinate time before twin2 accelerates can also be written as cosh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t]. Then the coordinate time for twin2 to accelerate in this frame is (c/a)*sinh(a*BT/c), so the total coordinate time from start to finish is cosh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t] + (c/a)*sinh(a*BT/c).
Now, we know that in this frame it took twin1 a coordinate time of (c/a)*sinh(a*BT/c) to do his own acceleration, so the coordinate time from the end of twin1's acceleration to the end of twin2's acceleration must be:
[cosh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t] + (c/a)*sinh(a*BT/c)] - (c/a)*sinh(a*BT/c)
Which just reduces to cosh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t]...since twin1 was at rest throughout this period, this would also be the proper time for twin1 from the end of his acceleration to the moment when twin2 stopped his own acceleration. And we know the proper time for twin1 during his acceleration was BT, so add them together and we have twin1's total proper time from start to finish:
BT + cosh(a*BT/c)*[(c/a)*sinh(a*BT/c) + t]
Since gamma = cosh(a*BT/c) is greater than 1, this total proper time will naturally be larger than twin2's total proper time from start to finish, i.e. BT + (c/a)*sinh(a*BT/c) + t. So, twin1 will be older than twin2 at the moment twin2 stops his acceleration and we compare their ages in the final rest frame.
  • #195
Since you said I am stupid in the other thread, what would make you think I could follow this unless you are stupid.
You are inconsistent.
  • #196
I didn't say you were stupid, I said your argument was stupid. An intelligent person can make a stupid argument if they are too confident of their own correctness and are too quick to be snidely dismissive of the counterarguments made by others and not really pay attention to what people tell them, as seems to be the case with you on all of these threads.
  • #197
Yes, maybe read this to yourself.
You can already tell I understand SR.
Have you considered yet I might be seeing something?
Answer the time dilation in the other thread and I will run you into a contradiction.
I think you can see this though.
Anyway, you said I was stupid. No matter, I am not.
But, I am going to look through your length argument here.
I will confess, you seem to have something with it.
Note how I am not so arrogant as to assume I know everything.
  • #198
LOL. Are you aware that length contraction is a major part of SR?
  • #199
LOL, what is that?
  • #200
No, I certainly wouldn't agree with that, you seem to understand some things but then you make really basic mistakes, like arguing that the past light cone would not look like a contracting light sphere if you plotted it over time. If you want to understand SR, I think you really need to find a text that develops it in a step-by-step manner (http://www.oberlin.edu/physics/dstyer/Einstein/SRBook.pdf . Your posts on relativity seem to be a fine example of this.
No, in fact I did not, I said your argument was stupid and that's all that I meant (if you want my real opinion of you, I think you are probably fairly intelligent but suffering from the type of overselfconfidence issue discussed above). But you love to tell me I'm wrong about the content of my own statements and opinions, apparently.
  • #201
Yea, anyway, let's operate in the sphere thread with this logic.
  • · Replies 42 ·
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 43 ·
  • · Replies 85 ·
  • · Replies 36 ·
  • · Replies 137 ·
11K
