Need help with a couple of BVP's.
  • Thread starter Thread starter Grogs
    Couple
The discussion focuses on solving boundary value problems (BVPs) related to the 1-D Heat Equation and steady-state heat conduction in a 2-D square plate. The first problem involves the equation k \frac{\partial^2 u}{\partial x^2} = \frac{\partial u}{\partial t} with boundary conditions u(0, t) = 0 and u(L, t) = 0, and initial conditions that present challenges in applying Fourier series due to discontinuities. The second problem addresses the Laplacian \frac{\partial^2 u}{\partial x^2} + \frac{\partial^2 u}{\partial y^2} = 0 with specified boundary conditions, leading to a solution of u(x,y) = 5. The necessity of two initial conditions for the heat equation is debated, with the conclusion that the provided initial conditions lead to a unique solution.
  • Understanding of the 1-D Heat Equation and its boundary conditions
  • Familiarity with Fourier series and eigenfunction expansions
  • Knowledge of Laplace's equation in two dimensions
  • Basic concepts of boundary value problems (BVPs)
  • Study the application of Fourier sine series in solving boundary value problems
  • Learn about half-range expansions and their use in initial condition adjustments
  • Explore the implications of discontinuities in boundary conditions on solution uniqueness
  • Investigate the relationship between initial conditions and the order of differential equations
Mathematicians, physicists, and engineering students focusing on heat transfer, boundary value problems, and differential equations.
Grogs
I've got a couple of BVP's I'm working on that are giving me some problems. First, I'm asked to solve the 1-D Heat Equation:
in a thin rod of length L subject to the following:
BC1) u(0, t) = 0
BC2) u(L, t) = 0
IC) 2 different problems. For the first, u(x,0) = 1 - 2 cos(\frac{9 \pi x}{L}). For the second, u(x,0) = 3 cos(\frac{9 \pi x}{2 L}).
I can separate this problem into:
\frac{X''}{X} = \frac{T'}{k T} = - \lambda
easily enough and apply the 2 BC's to get:
u_{n} (x,t) = A_{n} \sin(\frac{n \pi x}{L}) \exp(\frac{-k n^2 \pi^2 t}{L}) , n=1,2,3,...
My problem is with applying the Initial condition and solving for u(x,t):
u(x,t) = \sum \limits_{n=1} ^ {\infty} A_{n} \sin(\frac{n \pi x}{L}) = IC
My book shows me how to do a half-range expansion here, but according to my professor, I shouldn't need to. He even sent us an e-mail changing one of the IC's "so it would be an eigenfunction." How do I get there from here? Is there some easy trig identity to convert those IC's to a sin function I'm just missing?My 2nd question involves steady state heat conduction in a 2-D square plate of side L:
Subject To:
BC1) \frac{\partial u}{\partial x} = 0 at x = 0
BC2) \frac{\partial u}{\partial x} = 0 at x = L
BC3) \frac{\partial u}{\partial y} = 0 at y = 0
BC4) u(x,L) = 5
I separate the Laplacian into:
\frac{X''}{X} = \frac{-Y'}{Y} = - \lambda
and solve using the first 3 BC's, I get X = c_{1} and Y = c_{4} for \lambda = 0 and
<br /> X(x) = c_{2} \sin(\frac{n \pi x}{L})
Y(y) = c_{4} \cosh(\frac{n \pi y}{L})
for \lambda &gt; 0.
Using superposition, I end up with:
u(x,y) = A_{0} + \sum \limits_{n=1} ^ {\infty} A_{n} \sin(\frac{n \pi x}{L}) \cosh(\frac{n \pi y}{L})
When I apply the final BC, u(x,L) = 5, I end up with a solution of u(x,y) = 5. I guess I'm just looking for some sanity checking here. I can certainly see how u = 5 works here, but is it the only solution?
Thanks in advance,
Grogs
BC1) u(0, t) = 0
BC2) u(L, t) = 0
\frac{X&#039;&#039;}{X} = \frac{T&#039;}{k T} = - \lambda
That should be a sum above, it's just not showing up for some reason.
(To get the sigma to show use \sum with a small "s".)
For your first problem, there is a difficulty with your initial conditions: you don't have enough! Since the equation is second order in t, you need two initial conditions. Perhaps you were also told that u_t(x,0)= 0? That is, that the thin rod was deformed to the given initial position and then released "from rest".
The "complication" is that, since u= 0 at both endpoints, you have written u(x,t) as a sine series in x which is always an odd function by your initial conditions are even functions. That isn't really a problem since your interval is from 0 to L but notice that, according to the first initial condition, u(0, 0)= 1- 2cos(0)= -1 and for the second initial condition, u(0,0)= 3cos(0)= 3, while, according to the boundary conditions, u(0,0)= u(0,t)= 0! You necessarily have a discontinuity at the boundary points.
Subject To:
BC4) u(x,L) = 5
\frac{X&#039;&#039;}{X} = \frac{-Y&#039;}{Y} = - \lambda
for \lambda &gt; 0.
u(x,y) = A_{0} + \Sum \limits_{n=1} ^ {\infty} A_{n} \sin(\frac{n \pi x}{L}) \cosh(\frac{n \pi y}{L})
Thanks in advance,
Grogs
Again, you can't expect the solution to be continues at y= L because the initial conditions aren't. Yes u(x,y)= 5 is the only solution.
Halls, thanks for the reply.
I'm not sure where you're getting that. This is the heat equation (u = temperature,) not the wave equation. It's 1st order in t -> 1 IC required. The 2 IC's I posted are for 2 different problems where everything is the same, save for the IC's.
Hmm, interesting. I see where you're coming from with the cosines. There's a mathematical discontinuity between 2 cos(0) and 0 at x = 0. Looking at that leads me to believe there's no way this problem can be solved in the same way as an IC of say, 3 \sin(\frac{5 \pi x}{L}. So would using the half-range expression:
A_{n} = \frac{2}{L} \int \limits_{0} ^ {L} sin(\frac{n \pi x}{L}) f(x) dx
where f(x) is the IC be the only way to find u(x,y) in this case?
  • · Replies 18 ·
