Need Help with Calculating Mass? Get Expert Assistance Here!
  • Thread starter Thread starter Air
    Calculation
The discussion revolves around calculating the mass of a system in equilibrium, involving concepts of forces and torques. Participants are exploring the relationship between tension, angles, and mass in a triangular setup.
  • Participants are attempting to establish equilibrium conditions and the relationship between forces and torques. Questions are raised about the assumptions regarding the massless frame and the application of forces at the pivot point.
The discussion is active, with participants clarifying assumptions and exploring the implications of equilibrium. Some have provided guidance on considering moments and forces, while others are questioning the feasibility of calculating tension without knowing the mass.
There appears to be a lack of information regarding certain dimensions and the setup of the system, which is affecting the ability to proceed with calculations.
Air
Find the mass:
Not Sure.
I don't know where to start as I believe that there is less information.
All that I have got upto is Tan-1(3/8) but I don't know if this is needed to find the mass? :confused:
I'm assuming the frame is massless, pivoted bout the right angle of the triangle and the system is in equilibrium, am I correct?
Yes, You are correct.
So, we know that since the system is in equilibrium, the sum of the moments about any point should be zero. However, let's consider the forces; if the system is not translating (i.e. moving up or down) what must be the vector sum of the vertical forces?
Erm...Not sure but guessing zero. :redface:
Sounds good to me :smile: and where will this reation force be applied?
Either at the angle at the end of Y or near the mass?
Normal forces are applied at the point where the system pivots. Just checking, is the side x attached to a wall of some kind?
Nope. The pivot is at the corner of x and y.
x and y dimensions are given if to calculate the angle (I think).
Okay, let us consider the torques about the pivot point;
0.08T\sin\left(\arctan\left(\frac{3}{8}\right)\right) = 0.4mg
Where T is the tension in the diagonal member. Do you follow?
Yes, I do. :smile:
Can Tension be calculated without mass? :confused:
You still have not set up the equalibrium of FORCES, only of torques..
Also, for your information,
\sin(\arctan(x))=\frac{x}{\sqrt{1+x^{2}}}
  • · Replies 20 ·
