Optimizing Electric Potential Calculation for a Charged Particle in 1-Dim
  • Thread starter Thread starter Saladsamurai
    Operator
The discussion revolves around a programming issue related to evaluating a user-defined function, epotential, which is defined as f(x) = c/x, where c is a constant. The user is attempting to iterate through values from -0.5 to 0.5 in increments of 0.1, but wants to avoid evaluating the function at x = 0, where it is undefined. The initial approach using an if statement to skip the evaluation when dist equals 0 is failing due to the nature of floating-point arithmetic, where dist may not exactly equal 0 due to precision errors.Participants suggest alternative methods to handle this issue, such as checking if dist is within a small range around zero rather than checking for exact equality. They also discuss the implications of using integer conversion for comparisons and suggest using a loop that avoids the problematic value by mapping integers to the desired range. The conversation highlights the challenges of floating-point calculations in programming and emphasizes the importance of accounting for precision errors when performing comparisons.
Saladsamurai
so the following program uses a user defined function called epotential which is basically a function of the form f(x)=c/x where c is a constant.
I am using a for loop to evaluate the function from -0.5 to +0.5 and incrementing by 0.1
The problem is that I do not want it to evalute f(0) since it is undefined.
I thought that I could simply put "if (x!=0)...evaluate the function"
but this is not working and I do not see what is wrong with that logic.
Can someone help me out here?
Code:
#include <iostream>
#include <fstream>         // needed for outfile
using namespace std;
double epotential (double charge, double dist);     // function prototype
int main ()
    ofstream outfile;
    outfile.open ("ePotential.txt");           // opens textfile
    //declare and initialize objects
    double charge=8.0*0.000000001;
    double dist;
    double V;
    outfile <<"x= " << '\t' << "V= " <<endl << endl;         //cout to textfile
    cout << "x= " << '\t' << "V= " <<endl << endl;           //cout to screen
    double inc = 0.1;            // increment in for loop
    double left_bound = -0.5;    // left bound of domain of x
    double right_bound = 0.5;    // right bound of domain of x
    for (dist= left_bound; dist <= right_bound; dist+=inc)
           if (dist != 0)  // I do not want it to output V if dist = 0
                           // why does this not work?!
           V=epotential(charge, dist);               // loops over domain of x
           outfile << dist << '\t' << V << endl;     // sends output to textfile
           cout << dist << '\t' << V << endl;        // sends output to screen
    system ("PAUSE");                    // for Dev C++ compiler
    return 0;
//function that calculates the electric potential of a charged particle in 1-dim
double epotential (double q, double r)
       double V;
       double k=9.0*1000000000;
       V=k*(q/r);
       return (V);
Here is the output
x= V=
-0.5 -144
-0.4 -180
-0.3 -240
-0.2 -360
-0.1 -720
-2.77556e-017 -2.59407e+018
0.1 720
0.2 360
0.3 240
0.4 180
0.5 144
Technology news on Phys.org
How the compiler knows when to stop if?
Or, how would you write the following code?
int main ()
if condition met:
do something
do something all times
You can't compare the rest of a floating point calculation to 0
As dist is incremented it might equal 0.00000000000001 an so the test fails
You need to convert to an int or check for a range.
int main ()
if condition met:
do something
I am sorry I don't follow. I more or less have the following:
for x=-0.5 to 0.5 (increment by 0.1)
if x not equal to 0
evaluate V(x)
Sorry don't follow this either? I am an amateur, so bare with me. I am looping through the domain -0.5 to 0.5 and incrementing by 0.1 ... so at one point dist = 0 .
So what is the problem here?
if x not equal to 0
evaluate V(x)
Forgetting the brackets.
In my VS, if I don't include brackets, only first line below the if is considered a part of it. You have three lines and you define V to be under if, but then accessing V outside the scope of if condition. I only read that part of the code but wonder if this would create any problems
There's nothing like exact 0 , 0.5, or 0.1.
Okay, I think that I tried that. I understand now.
Do you mean when it adds 0.1 + -0.1 it does not equal EXACTLY zero ?
Is that what you are saying?
Yes. See ~third post:
http://idlastro.gsfc.nasa.gov/idl_html_help/Accuracy_and_Floating_Point_Operations.html
Gotcha. Thanks!
I am not sure, though, how I can convert this to int ...?
Either do
if ((int)dist == 0 ) or
if ( (dist > -0.00001) && (dist < 0.00001) )
mgb_phys said:
Either do
You mean if((int)dist != 0) right?
Since I do not want f(0)
This is getting silly.
If I replace if (dist != 0)with if ((int)dist != 0) nothing from the loop gets outputted
if I replace it with
if ((int)dist == 0) i get the same output as before
mgb_phys said:
Either do
if I want to use either of these, I have to tell the compiler that if (int)dist == 0
then DONT evaluate f(dist)
and I cannot figure out how to do that. Any ideas?
Ha ha! Gotcha!
Code:
           if ((dist > -0.00001) && (dist < 0.00001))
           {continue;}
           else
There has to be a way using int though...
Saladsamurai said:
Ha ha! Gotcha!
Code:
           {continue;}
           else
Well, int converts float to an integer: -1,0,1
so int (0.5) would obviously round down to 0 not 1.
I think one of the way to use int would be multiply by like 1000 before converting to int.
You don't need to use integers.
As you saw, two numbers that are the same on paper can be different on a computer. It is usually not a good idea to compare two doubles for equality. It is much safer to test for "reasonably close to the same", where "reasonably close" application specific. Here you are incrementing by 0.1 (more on this below) from -0.5, so the fifth increment should put you somewhere close to zero. So test for that -- zero plus or minus some small epsilon.
The problem here is that 0.1 (decimal) in binary is 0.000110001100011... It's binary representation is non-terminating, just as 1/3 has a non-terminating decimal expansion. A rational number with a non-terminating binary expansion cannot be represented exactly using the standard computer representation for doubles. By comparing with ==, you are acting as if the computation is exact. It isn't.
This would also be a good time to pull out the floor(), ceiling() and round() functions from math.h.
(Although come to think of it is it guaranteed that round( n ) == 0 where -0.5 < n < 0.5 ?)
You could always try a trick like this:
Code:
for(int i = 0; i < 11; i++)
   if(i != 0)
      double dist = (i - 5) * 0.1;
      // code...
Essentially, since you will be using a finite discrete number of values for dist, there exists a mapping from integers to reals. And since integers are computed exactly (in the ranges, anyway) this will work *every* time. You could even generalize the code to work with arbitrary bounds. For instance...
Code:
double proportionalMapping(double min, double max, int sampleSize, int i)
   return min + (max - min) * i / (sampleSize-1);
Then your original code could look like
Code:
const int sampleSize = 11;
const double min = -0.5, max = 0.5;
for(int i = 0; i < sampleSize; i++)
   if(i != 0)
      double dist = proportionalMapping(min, max, sampleSize, i);
  • · Replies 23 ·
13K
13K
10K
17K
