Need help with some aspects of Bell’s theorem
  • Context: Graduate
  • Thread starter Thread starter miosim
    Theorem
The discussion revolves around Bell's theorem, focusing on its conceptual framework, implications for hidden variable theories, and the nature of correlations predicted by quantum mechanics (QM) versus those derived from classical approaches. Participants explore the distinctions between local and non-local hidden variable theories and their compliance with QM.
  • Some participants propose that Bell's theorem demonstrates the impossibility of local hidden variable theories making the same predictions as QM.
  • Others argue that hidden variable theories should comply with QM equations to be considered valid, questioning the use of classical approaches in correlation calculations.
  • A later reply emphasizes the need to distinguish between local and non-local hidden variable theories, stating that Bell's theorem applies specifically to local theories.
  • Participants discuss the implications of non-local hidden variable theories, suggesting that they can make the same predictions as QM, unlike local theories.
  • There is a question regarding how a single photon can have definite polarization at multiple angles, with references to the EPR paper's claims about elements of reality.
Participants express differing views on the nature of hidden variable theories and their relationship to QM. There is no consensus on whether hidden variable theories must comply with QM or the implications of Bell's theorem regarding local versus non-local theories.
Participants highlight the complexity of defining hidden variable theories and the assumptions underlying their predictions. The discussion reflects varying interpretations of Bell's theorem and its implications for quantum mechanics.
This discussion may be of interest to those studying quantum mechanics, philosophy of science, or the foundations of quantum theory, particularly in relation to Bell's theorem and hidden variable theories.
  • #31
miosim said:
in general we should not use the same reasoning for classical objects (socks, magnets, etc.) and for quantum entities
Yes.
miosim said:
(as LHV models are).
No; LHV models are not "quantum entities". That's the whole point of Bell's theorem, to show that they can't be.
  • #32
PeterDonis said:
he was reasoning about all of them by reasoning only about properties that all of them must possess.
PeterDonis said:
No, because any such LHV model must have the properties Bell used to derive his theorem
So what are these key properties of HV theories? As I understand, they are just a fact that values of spin, polarization, etc., are predetermined prior interacting with detector.
As I understand, the final value of spin, polarization, etc. are affected by a position of detector but we don't know much about specific mechanisms of these interactions - wave function doesn't tell us much and the results we calculate is just a guess - no experimental conformation that our HV model is correct. It is why I am not easy about jumping to calculate correlation based on simplified assumption of what HV are. They could be as wired as QM itself.
However let’s try again a simple example of HV. Say, if particle has HV that measure position of detector that “helps particle to pass”. I think that correlation for this model could be as high as we need if we can plug this “helps particle to pass” algorithm into HV.
  • #33
Nugatory said:
It's a fun exercise (I've done it just for fun - but also google for "quantum Randi challenge") to actually code up a computer simulation in which you can plug in any functions you please to assign any values you please to any variables associated with each particle; and use any functions you please to calculate the probability of a simulated particle passing its polarizing filter. You will find yourself unable to violate the Bell inequalities.
Is it web application? I didn't find it.
  • #34
"Quantum Randi challenge" should find plenty of hits. If you mean my simulation I've never posted it, as it's only a few hundred lines of Java code and writing it is 90% of the value.
  • #35
No, they are that the probability distribution of measurement results at detector A cannot depend on the settings of detector B, and vice versa. That was Bell's key assumption. It is usually referred to as "locality", and is why the conclusion of the theorem applies only to "local" hidden variable theories.
Given that assumption, it doesn't matter what else determines the results at detector A: they could be predetermined, they could be sampled from a random number generator, they could depend on the phase of the moon--as long as that information is available at detector A to be taken as input at the time of measurement. (Note that detector B's settings are not available at detector A at the time of measurement if the measurements are spacelike separated.)
I don't understand what you mean by "helps particle to pass", but as long as the algorithm for detector A does not take detector B's settings as input, and vice versa, you will be unable to produce results that violate the Bell inequalities. If you think you can, then start programming.
  • #36
PeterDonis
Let me think about your response.
  • #37
miosim said:
So what are these key properties of HV (local) theories?
PeterDonis said:
... they are that the probability distribution of measurement results at detector A cannot depend on the settings of detector B, and vice versa. That was Bell's key assumption. It is usually referred to as "locality", and is why the conclusion of the theorem applies only to "local" hidden variable theories.
Indeed the probability distribution of measurement results at detector A should not depend on the settings of detector B, and vice versa. Therefore if we rotate the first detector the probability distribution at second detectors shouldn't change. Does it contradict with the QM prediction? Does it contradict with experiment?
  • #38
Yes. That's what Bell showed, by showing that any probability distributions (of the results at A and B) that meet the conditions will have correlations (between the results at A and B) that satisfy the Bell inequalities. Specifically, he showed that the correlation function between A and B, if A's and B's distributions meet the conditions, must factorize into a product of a function depending only on A's settings, and a function depending only on B's settings. Then he showed that any distribution that factorizes in this way must satisfy the Bell inequalities.
The QM prediction violates the Bell inequalities, as can be shown either by just looking at the correlation function it gives and its values at various angles, or by showing that it doesn't factorize in the way described above.
Yes, since experiments match the QM prediction.
  • #39
Bell's experiment is about CORRELATION between A and B. But what about measurements at one detector only. Does it depend on the position for other detector? Would the actual number of detections at detector A is changing from max to zero while we rotate detector B?
  • #40
The probability distribution at the second detector does not change - every incident particle has a 50% chance of passing and a 50% chance of not passing; the experimental results at each individual detector are as random as if they had been generated by flipping coins. This is both the quantum mechanical prediction and the experimentally observed result (and If it were not, we could use entanglement to send faster-than-light messages).
However, the probability distribution of the coincidences, which only becomes apparent when Alice and Bob get together after the fact and compare notes, does change. Bell's theorem states that the quantum mechanical prediction for the coincidences can only be produced by theories in which the probability of a detection at one detector is affected by the position of and result at the other detector.
You may be finding yourself confused by the claim that the probability distribution of the detections at either detector is completely random, yet the correlations between them may not be. Here's an easy example of how that could happen: You are watching someone tossing an honest coin, and you see a random sequence of heads and tails. I am also watching someone tossing an honest coin, and I see a random sequence of heads and tails. But when we get together afterwards and compare notes, we might find that the correlation is not random; for example if we happened to be watching the same guy flipping the same coin but we were looking at different sides of the coin, the every time that I saw a heads you would see a tails and vice versa. Yet the coin flips would still be as random as random can be.
  • #41
It is also my understanding.
I have no problem with this concept
Another word the correlation predicted by QM is higher that any local HV theory can offer. Is it correct?
  • #42
miosim said:
The correlation predicted by QM is higher that any local HV theory can offer. Is it correct?
For certain arrangements of the detectors, yes. For other arrangements (such as the ones where QM predicts and experiments confirm perfect correlation or perfect anti-correlation) a local hidden variable theory could in principle produce the same results.
  • #43
Understand.I have a question:
When photon pass the detector, is the polarization of photon that passed detector and orientation of detectors matches? If they match,
does the wave function collapse first produces a photon with some polarization, and then this original polarization is rotated by detector and then pass/or_not_pass result depends on match between orientation of the detector and the original polarization of photon?
  • #44
Or to make things a bit more interesting, imagine the two of you watching someone rolling a six-sided die, but from different directions, say from the top and from one side.
  • #45
I understand these examples. I just need a better understanding of physical side of the story.
  • #46
The best description in terms of wave function collapse says that neither particle has a definite polarization (we still have the superimposition) until one of them interacts with its detector. When this interaction happens, the particle acquires a definite polarization, either parallel to or perpendicular to the polarizer, and that's the moment of wave function collapse. The entire wave function collapses, so when the first photon acquires its definite polarization the second one immediate collapses into the corresponding state and the proceeds on to interact with its polarizer. In this model, if the first polarizer is set to angle ##\alpha## then the second photon will always interact with its polarizer as if its polarization is ##\alpha## or ##\alpha\pm\pi/2##, and this is the spooky action at a distance that you hear so much about.
But do remember that this is an explanation in terms of wave function collapse and collapse is not a fundamental part of quantum mechanics; it's just one way of interpreting the statistical predictions that the theory makes. You'll hear this interpretation a lot because it makes a sort of intuitive sense (as long as you're willing to swallow the spooky bit) and because it is a very helpful way of thinking about many single-particle problems. However, it also has some very serious conceptual problems. The most serious might be that it only makes sense if we can say that one interaction unambiguously happened before the other, and as we discussed earlier in this thread, we cannot.
  • #47
I understang what are you saying and will try to use the language compatible with interpretation.
Nugatory said:
In this model, if the first polarizer is set to angle α \alpha then the second photon will always interact with its polarizer as if its polarization is α \alpha or α±π/2 \alpha\pm\pi/2, and this is the spooky action at a distance that you hear so much about.
After entangled photon pass their corresponding detector/polarizers what their mutual polarization are? Do they still have polarization differences ±π/2 as entangled pair or this symmetry is distorted due to interaction with detectors?
Or may be I should ask the more general question: What is polarization of a photon that pass polarizer in reference to orientation of this polarizer?
  • #48
Once the photon has cleared the polarizer, subsequent measurements of its polarization along that axis will yield the same result - the photon passes. (It's also no longer entangled with its partner).
In a collapse interpretation, that's because the wave function collapsed with the first interaction so now both particles are in non-superimposed polarization eigenstates. If you prefer a more ascetic interpretation, then the first measurement is a "preparation procedure" which prepares the system into a state such that a subsequent polarization measurement along that axis will be positive 100% of the time.
  • #49
Another word the photon pair after exiting corresponding polarizer lost symmetrical polarization. It is like polarizers align photons, after they lost entanglement, to follow polarizer's orientation. It seams the "ability" of photons to follow orientation of polarizers contributes into correlation making it higher than any local HV theory can be predict.
  • #50
Actually this language isn't compatible with description of QM system and should be reserved only for classical theories or to local HV theories.
In this case, per classical description, the predicted by QM correlation may be explained in terms of photon polarization sufficiently rotated by detector. Per local HV theory the the predicted by QM correlation may be derived from HV that measures orientation of the corresponding detector and change photon's polarization accordingly (using function similar to Malus' law). In this case there is no need for photon pair to influences each other over the distance to achieve sufficient correlation. Instead they need just "pay attention" to the orientation of local detector only.
Does it make sense?
  • #51
I don't understand what you're saying here.
Are you saying that the QM correlation can be derived from a hidden variable theory in which the result at one detector does not depend on the angle and result at the other detector? If so, you might want to try coding up a computer simulation - I expect that you'll find that it doesn't work.
  • #52
I guess I need to try this, but it would take time for me to do this.
Meanwhile, I have a question.
If the main goal of the Bell theorem is to prove non-locality of QM why does this prove relies on rejecting of local HV theory? The non-locality is a well known feature of QM. So if QM predicts correlation and this prediction is based on non-locality of wave function and the experiment conforms QM prediction - what else do we need? Why do we need to complicate this by mixing with disproving of local HV.
Is proving of non-locality indeed depends of disproving local HV theory? What if we wouldn't have the EPR paper?
  • #53
The goal of the Bell theorem is to show that local hidden variable theories cannot mimic QM.
Before Bell, it was not clear that the nonlocality in the wave function could not be mimicked by LHV.
Whether or not you think this is interesting is up to you.
  • #54
Aha...
I am getting closer in understanding your response while trying to mimic the correlation predicted by QM cos (a-b), as suggested by Nugatory. I am looking for the equivalent formula in which A and B are separated (meaning that particles A and B know orientation of the correspondent detector only, but not both). Doesn't look it is possible based on the trigonometry.
cos(A - B) = cos A cos B + sin A sin B
I need more time to think about this.
Thank you for response.
  • · Replies 80 ·
  • · Replies 75 ·
13K
  • · Replies 55 ·
  • · Replies 28 ·
  • · Replies 16 ·
  • · Replies 47 ·
  • · Replies 58 ·
